POV-Ray : Newsgroups : povray.general : Endogenic height field Server Time
30 Sep 2024 03:18:24 EDT (-0400)
  Endogenic height field (Message 1 to 7 of 7)
Subject: Endogenic height field
Date: 3 Dec 2006 14:55:12
Message: <45732ba0$1@news.povray.org>
Hi.
The tutorial for the height_field primitive makes the user generate a sample
height field by rendering a trivial scene with a plane and a wrinkles
pattern.
I often felt the need of such a purely random height field, to serve as a
natural floor for a scene. I find the need for an external file somewhat
annoying: the file must either be carried around with the scene, or
re-generated, it is cumbersome.
I just found that patterns and pigments could be programatically queried
through the use of user-defined functions. Something like:
#declare height = function { pattern { wrinkles } }
This opens the possibility to use it directly as a height field, either with
an iso_surface (function { y - height(x, z, 0) }) or by building a mesh
(less elegant, but seems to be faster).
Are there drawbacks in doing so? Or more elegant solutions to this problem?
Subject: Re: Endogenic height field
Date: 3 Dec 2006 15:03:24
Message: <45732d8c@news.povray.org>
  Read the documentation more carefully. You can create a height_field
from such a function without the need for an external image file.
Date: 3 Dec 2006 15:29:24
Message: <457333a4$1@news.povray.org>
Warp  wrote in message <45732d8c@news.povray.org>:
There is indeed something directly in the height field, thanks for pointing
it.
But it is not in the doc. The doc says:
# HEIGHT_FIELD:
#     height_field{
#       [HF_TYPE]
#       "filename"
#       [HF_MODIFIER...]
#       [OBJECT_MODIFIER...]
# HF_TYPE:
#     gif | tga | pot | png | pgm | ppm | jpeg | tiff | sys | function
# HF_MODIFIER:
#     hierarchy [Boolean]  |
#     smooth               |
#     water_level Level
(copypasted from http://www.povray.org/documentation/view/3.6.1/279/)
And the keyword "function" is nowhere to be seen in the explanation. After a
look in the source code, I find that the correct syntax is something like
that:
height_field {
  function 200, 200 { height(2 * x - 1, 2 * y - 1, 0) }
  pigment { Cyan }
  scale <2, 1, 2>
  translate <-1, 0, -1>
  translate dist * z
With the 200, 200 being the size of the height field. Please note that it is
not conform to the documented syntax, since the "filename" field is said to
be mandatory.
I believe there is a problem in the documentation about this feature.
Date: 4 Dec 2006 00:27:06
Message: <GMTisRADD7cFFwer@econym.demon.co.uk>
Here's a comparison of using an isosurface vs using height_field with a
function.
http://www.econym.demon.co.uk/isotut/patterns.htm#hf
Mike Williams
Gentleman of Leisure
Date: 4 Dec 2006 02:50:57
Message: <4573d361@news.povray.org>
  That may indeed be true. The function feature is a quite new addition
and the documentation is not always up-to-date.
Date: 4 Dec 2006 04:10:29
Message: <4573e605$1@news.povray.org>
Mike Williams  wrote in message <GMT### [at] econymdemoncouk>:
> function.
This whole page is quite interesting. Regarding isosurface vs. height_field,
it says pretty much what should be expected: height_field is faster but
requires more memory, but isosurface is more detailed and
resolution-independent.
Date: 4 Dec 2006 09:20:08
Message: <45742e98$1@news.povray.org>
>> feature.
In the "Quick Reference" I think it's well described (from
http://www.povray.org/documentation/view/3.6.1/528/)
HEIGHT_FIELD:
     height_field { HF_IMAGE [HF_MODIFIERS] }
HF_IMAGE:
     FUNCTION_IMAGE | [HF_TYPE] FILE_NAME
HF_TYPE:
So indeed the filename is optional with a function image. Maybe the
Quick Reference gets updated more often...
The function image is in fact not described under heightfield but rather
under Textures->Patterns here
http://www.povray.org/documentation/view/3.6.1/379/
I know it was in there because I used it once and I would never have
figure it out without the docs ;-)
Regards
Vincent
