POV-Ray : Newsgroups : povray.general : lack of memory Server Time
15 Jan 2025 01:26:55 EST (-0500)
  lack of memory (Message 1 to 7 of 7)
Subject: lack of memory
Date: 24 Aug 2006 04:43:21
Message: <44ed66a9$1@news.povray.org>
I made about 1,700,000 cubes and it occupied 65% of 2G memory of my machine.
and I should make 14,000,000 cubes but the memory should be overflowed.
How can I solve this problem without considering buying more memory?
JH
Subject: Re: lack of memory
Date: 24 Aug 2006 05:37:58
Message: <44ed7376@news.povray.org>
  Are there any groups of cubes which repeat, or are all the cubes
completely distinct from each other?
  If there are groups of cubes (say, like eg. groups of 10000 cubes)
which repeat, then you can make a mesh consisting of 10000 cubic shapes
and then just copy this mesh.
  What are you trying to do? Perhaps there's a better way of doing it.
Date: 24 Aug 2006 12:00:52
Message: <44edcd34$1@news.povray.org>
There is no cube which is the same as others.
It's not easy to explain but I have to make such many objects.
Thanks.
JH
news:44ed7376@news.povray.org...
>> machine.
>                                                          - Warp
Date: 24 Aug 2006 12:51:27
Message: <44edd90f@news.povray.org>
> machine.
> overflowed.
How much memory use the vista and light buffers? Try rendering your
scenes without them.
(Look at http://www.povray.org/documentation/view/3.6.1/223/, the
commandline options are -MB -UL -UV)
Date: 25 Aug 2006 17:33:46
Message: <44ef6cba@news.povray.org>
> machine.
That's... wow. How many cubes per pixel?
/me counts...
Jonathan.
Date: 25 Aug 2006 19:53:14
Message: <44ef8d6a$1@news.povray.org>
>machine.
If you have a lot of cubes that aren't visible, you could cull them, as long
as they
aren't in the line of sight, or in the line of sight from the light sources
(shadows),
and they aren't reflective, or opaque, and you aren't using radiosity...
then the
image should end up the same.
Date: 10 Sep 2006 05:10:01
Message: <web.4503d620eba108adc2d4f2880@news.povray.org>
> JH
There might be ways to reduce the memory requirements, but it depends on
your scene.  A few questions first:
1) Are your cubes simple box shapes, or are they superellipsoids?
2) Does EACH cube need a different texture?
3) Are any of the textures partially transparent?
4)  Are you using a #while loop to randomly place the cubes in your scene?
Ken W.
