POV-Ray : Newsgroups : povray.general : how to make an ellipsoid at exact place? Server Time
28 Feb 2026 03:46:19 EST (-0500)
  how to make an ellipsoid at exact place? (Message 1 to 4 of 4)
Subject: how to make an ellipsoid at exact place?
Date: 20 Aug 2006 11:35:19
Message: <44e88137@news.povray.org>
I tried to make two ellipsoids at the opposite corner of a cube.
box { <3,3,3>,<-3,-3,-3>,
    pigment { color Red }
sphere { <3,3,3>,1
    pigment { color Blue }
    scale <2,0,0>
sphere { <-3,-3,-3>,1
    scale <2,0,0>
"scale" stretchs the sphere twice longer along the x-axis.
but the center coordinate of ellipsoid is stretched as well.
They should at the <3,3,3> and <-3,-3,-3> but they are at <6,3,3> and
<-6,-3,-3>
How can I make ellipsoid at the exact place?
JH
Subject: Re: how to make an ellipsoid at exact place?
Date: 20 Aug 2006 12:01:34
Message: <44e8875e$1@news.povray.org>
44e88137@news.povray.org...
> <-6,-3,-3>
> Cheers
> JH
If you create your spheres a <0,0,0> , stretch them , THEN translate them at
<3,3,3> and <-3,-3,-3>, they'll be where you want
Marc
Date: 20 Aug 2006 12:10:00
Message: <web.44e888224a0349d4b48318060@news.povray.org>
In POVRay all transformations (translating, scaling and rotating) are in
relation to the origin. So scaling an object which isn't located at the
origin will also scale its position. An object not located at the origin
will 'orbit' around the coordinate axes when being rotated.
Hence: Create the objects at the center, scale/rotate there and translate
afterwards.
Also it should be scale <2,1,1> instead of <2,0,0>. POVRay should print out
a warning message about that issue.
sphere { <0,0,0>,1
    scale <2,1,1>
    translate <3,3,3>
sphere { <0,0,0>,1
    scale <2,1,1>
    translate <-3,-3,-3>
or somewhat shorter:
box { -3, 3
sphere { 0,1
    scale 2*x
    translate 3
sphere { 0,1
    scale 2*x
    translate -3
Hope this helps
Regards Roman
Date: 20 Aug 2006 20:04:15
Message: <44e8f87f@news.povray.org>
Mathematically, if you scale-down a sphere in y
to become an ellipsoid, the foci along the x-axis become
+- MR*e*sqrt(-e/(e*e-1))
where e is the eccentricity (scale amount), and
where MR is the major radius.
