POV-Ray : Newsgroups : povray.general : making perfectly transparent object with color Server Time
23 Dec 2025 20:49:13 EST (-0500)
  making perfectly transparent object with color (Message 1 to 3 of 3)
Subject: making perfectly transparent object with color
Date: 17 Jul 2006 12:04:07
Message: <44bbb4f7@news.povray.org>
At first, make a white ball and then make a red box, which is bigger than
the ball, in front of the ball.
If I use the command "filter" or "transmit", I could see the ball through
the box.
But the color of ball(white) seem to be redder and dimmer than its original
because the light traverse through the red box.
If I put more red boxes in front of the ball, I will not be able to see the
ball because many boxes screen the light emitted from the white ball.
How can I see the white ball even if there are many boxes between the ball
and the camera?
Thank you.
JH
 Yonsei University, Department of Astronomy
 Seoul, South Korea
 Graduate Student, Room #703
 Joo Heon Yoon in GEM
 jhy### [at] galaxyyonseiackr
Subject: Re: making perfectly transparent object with color
Date: 17 Jul 2006 13:45:00
Message: <web.44bbcbfa8936040dc150d4c10@news.povray.org>
> the box.
> and the camera?
> Thank you.
> JH
Try not to multipost in different groups, if someone has an answer, they'll
eventually respond.
For your problem, use filter as 1  (i.e., rgbf <1,0,0,1>) and everything
will be filtered red.  Using transmit with a value of 1 will not alter any
colours.  Using values less than 1 will fade light passing through by the
f/t component.
You should be able to put as many boxes as you want wnd still see the sphere
behind just as bright, but filtered aslong as you have max_trace_level high
enough, filter set to 1 and no fading added to the box interior.
Example:
//start
global_settings {max_trace_level 15}
  location  -10*z
  look_at   0
light_source{<0,100,-100>  rgb 1}
sphere{0 1
  texture{
    pigment{rgb 1}
    finish{ambient 0 diffuse 0.6}
box{<-1.2,-1.2,-1.2><1.2,1.2,-1.3>
  texture{
    pigment{rgbf <1,0,0,1>}
box{<-1.2,-1.2,-1.4><1.2,1.2,-1.5>
  texture{
box{<-1.2,-1.2,-1.6><1.2,1.2,-1.8>
  texture{
//end
-tgq
Date: 20 Jul 2006 11:23:16
Message: <44bf9fe4$1@news.povray.org>
Thank you.
However, it doesn't work.
I can't see any red boxes if I follow your comment.
"Trevor G Quayle" <Tin### [at] hotmailcom> wrote in message
news:web.44bbcbfa8936040dc150d4c10@news.povray.org...
>> the box.
>> original
>> the
>> ball
>> and the camera?
>> Thank you.
>> JH
> they'll
> eventually respond.
> f/t component.
> sphere
> high
> Example:
> //start
> camera {
>  location  -10*z
>  look_at   0
> sphere{0 1
>  texture{
>    pigment{rgb 1}
>  texture{
>  texture{
>  texture{
> //end
> -tgq
