POV-Ray : Newsgroups : povray.general : Vectoring Warp Turbulence Server Time
24 Dec 2025 21:05:06 EST (-0500)
  Vectoring Warp Turbulence (Message 1 to 6 of 6)
Subject: Vectoring Warp Turbulence
Date: 31 May 2006 06:09:47
Message: <447d6b6b$1@news.povray.org>
I was wondering if anyone knows how to vector the effects of Warp in a
single directtion.
For instance, if I use "warp { turbulence <0,1,0> } the warp pushes in both
+x and -x, is there anyway to push only in the +x direction?
POV Tips and Hints at ...
http://povman.blogspot.com/
Subject: Re: Vectoring Warp Turbulence
Date: 31 May 2006 07:22:48
Message: <20060531122247.78f0293d@mekanori.mon.istic.org>
> single directtion.
I think most of the POV team has been trying to vector Warp's efforts in
a single direction for some years, but he's far more stubborn than that.
"It is  inconsistent with the  most rudimentary  notions  of fairness to
blindfold a man and then impose a standard  which only the sighted could
hope to meet." -- Lord Bingham of Cornhill -+- http://surreal.istic.org/
 www.publications.parliament.uk/pa/ld200506/ldjudgmt/jd051208/aand-1.htm
Date: 31 May 2006 11:03:58
Message: <447db05e$1@news.povray.org>
>> single directtion.
Strange, I was thinking the same thing...
Tim Cook
Version: 3.12
Date: 7 Jun 2006 09:19:38
Message: <4486d26a$1@news.povray.org>
> single directtion.
> in both +x and -x, is there anyway to push only in the +x direction?
I assume you mean -y and +y for a turbulence of <0,1,0>.
But anyway, isn't what you're asking for equivalent to using turbulence plus
translation?
Rune
http://runevision.com
Date: 7 Jun 2006 10:07:00
Message: <4486dd84$1@news.povray.org>
> plus translation?
I see that I'm not making myself clear, and yes I meant -y +y.  ( perhaps I
should re-read these before posting sometimes)
Imagine a spherical pattern, apply warp <0,1,0>.  Some of the disturbed
pattern appears above the original sphere, but some also appears below the
sphere. What I would like is to push the the disturbance in only the +y
direction.
Date: 7 Jun 2006 10:20:23
Message: <4486e0a7@news.povray.org>
>> turbulence plus translation?
> perhaps I should re-read these before posting sometimes)
> disturbed pattern appears above the original sphere, but some also
> appears below the sphere. What I would like is to push the the
> disturbance in only the +y direction.
Yes. So apply warp <0,0.5,0> only and then translate by <0,0.5,0> or
whatever is needed to make sure that none of the disturbances remain
negative.
Rune
