POV-Ray : Newsgroups : povray.general : idea to speed up radiosity in some cases Server Time
30 Sep 2024 13:18:12 EDT (-0400)
  idea to speed up radiosity in some cases (Message 1 to 5 of 5)
Subject: idea to speed up radiosity in some cases
Date: 12 Apr 2006 18:53:17
Message: <443d84dd$1@news.povray.org>
I was playing with radiosity, because it's fun :), and suddenly I
thought of something: radiosity-effects are added to the current color
of the pixel, radiosity can never make a pixel darker than it would be
without radiosity.  So if you're not rendering to a HDRI, and if
clipping is done before anti-aliasing (which, I know, isn't at the
moment), POV-Ray could actually stop doing it's radiosity-calculations
once a pixel has become completely white (or has become "close enough"
to completely white).
Ok, a lot of if's there, but especially for test-renders, those if's
shouldn't be too much of a problem, should they?
just an idea of course, and quite possibly not worth even taking the
time to consider implementing, given that it could only help in very few
cases, but still, maybe worth considering to be considered? :p
cu!
Subject: Re: idea to speed up radiosity in some cases
Date: 12 Apr 2006 21:24:51
Message: <443da863$1@news.povray.org>
Zeger Knaepen nous apporta ses lumieres en ce 12/04/2006 18:53:
> I was playing with radiosity, because it's fun :), and suddenly I thought of
something: radiosity-effects are added to the current color of the pixel, radiosity
can never make a pixel darker than it would be without radiosity.  So if you're not
rendering to a HDRI, and if clipping is done before anti-aliasing (which, I know,
isn't at the moment), POV-Ray could actually stop doing it's radiosity-calculations
once a pixel has become completely white (or has become "close enough" to completely
white).
> Ok, a lot of if's there, but especially for test-renders, those if's shouldn't be
> just an idea of course, and quite possibly not worth even taking the time to
consider implementing, given that it could only help in very few cases, but still,
> cu!
What about some negative pigment? or negative ambient? Those can darken your
surrounding pixels.
Also, if you have a recursion_limit of more than 1, pixels whiter than white will
illuminate the
surrounding area more than those that are "only" white.
I love you not because of who you are, but because
of who I am when I am with you..
Date: 12 Apr 2006 23:06:33
Message: <443dc039$1@news.povray.org>
Radiosity is calculated on surfaces in 3D space, not per pixel. Since a
surface which is white from one point of view might be grey when, say,
reflected off a dull mirror (reflection .5), continuing to increase its
brightness is important.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 13 Apr 2006 03:46:26
Message: <443e01d2@news.povray.org>
"Alain" <ele### [at] netscapenet> wrote in message
news:443da863$1@news.povray.org...
darken your surrounding pixels.
white will illuminate the
didn't think of all that :(
Date: 14 Apr 2006 23:53:20
Message: <44406e30$1@news.povray.org>
Radiosity scenes with negative ambient values in textures:
Subject: Radiosity test (60kbu)
Date: 6 Aug 2000 18:24:21
http://news.povray.org/povray.binaries.images/thread/%3C398DAC6E.810C4E7%40inapg.inra.fr%3E/
Subject: Radiosity test #2 70 kbu
Date: 7 Aug 2000 16:42:33
http://news.povray.org/povray.binaries.images/thread/%3C398EE60E.DCFE0C7E%40inapg.inra.fr%3E/
Tor Olav
http://subcube.com
