POV-Ray : Newsgroups : povray.general : Parsed SDL Server Time
30 Sep 2024 17:23:15 EDT (-0400)
  Parsed SDL (Message 1 to 4 of 4)
Subject: Parsed SDL
Date: 1 Feb 2006 11:42:18
Message: <43e0e4ea$1@news.povray.org>
Does anyone know of a way to see the  parsed SDL for a scene ( if it
actually gets created at all ).  I know that the base SDL I've typed in gets
parsed, and was wondering if POV-Ray engine internally generates an
intermediate SDL file in memory.  If it does, I'd like to output it.
For instance, if I have a macro that generates 100 spheres, is there ever a
version of the SDL that contains 100 sphere definitions?
POV Tips and Hints at ...
http://povman.blogspot.com/
Subject: Re: Parsed SDL
Date: 1 Feb 2006 13:02:54
Message: <43e0f7ce$1@news.povray.org>
No.  You're probably used to other programming languages (C++, for
instance) that have a separate preprocessor and compiler.  In POV-Ray,
SDL files get "compiled" at the same time as being "preprocessed".  So,
macro substitution occurs as the file is being evaluated.
It would be simple (but tedious) to insert #debug statements into your
code to let you know what's going on.  For instance, in your macro that
generates 100 spheres, you could do:
#debug "Macro generating 100 spheres...\n"
-or-
#local c_x = str(sphere_center.x, 0, 0);
#local c_y = str(sphere_center.y, 0, 0);
#local c_z = str(sphere_center.z, 0, 0);
#debug concat("Macro generated sphere at ", c_x, ", ", c_y, ", ", c_z, "\n"
...Chambers
Date: 2 Feb 2006 05:16:26
Message: <43e1dbfa@news.povray.org>
Thanks Chambers, good answer, not what I wanted to hear, but thanks anyway.
Date: 2 Feb 2006 09:48:49
Message: <43e21bd1@news.povray.org>
  The current SDL parser is a very direct interpreter: It immediately acts
upon the commands it parses, without converting nor saving them anywhere.
  (The only exception are the user-defined functions, which use their own
separate parser and interpreter which works quite differently. There might
have been some obscure trick to get the byte-compiled functions printed,
but I don't remember at all how it might have been done... :P )
