POV-Ray : Newsgroups : povray.general : Aspect ratio & resolution.ini Server Time
12 Jun 2026 00:22:38 EDT (-0400)
  Aspect ratio & resolution.ini (Message 1 to 10 of 10)
Subject: Aspect ratio & resolution.ini
Date: 28 Dec 2005 18:43:36
Message: <43b32328$1@news.povray.org>
I have been making a variety of animation which are being exported to
video.  I've been exporting to both DVD (1.33:1) and HDTV (16:9)
formats.  I've been using commands within the camera to set the aspect
ratio; for example DVD aspect ratio is done as follows:
   location <0,12,-12>
   look_at <0,8,0.01>
   up <0,1,0>
   right <1.33,0,0>  //this would be 1.85 for HDTV
   angle 60
Unfortunately, this means that I have to manually adjust both the aspect
ratio (in the camera command) and the image resolution (in the drop-down
menu for resolution.ini).  I'm a little forgetful, which means that I've
rendered several animations where the aspect ratio and resolutions did
not match.  Which means that I loose hours of time rendering videos
which are totally distorted.
So is there some way I can add the aspect ratio into the resolution.ini
file so that when I pick the resolution the appropriate aspect ratio is
also picked?
Thanx
Bryan
Subject: Re: Aspect ratio & resolution.ini
Date: 28 Dec 2005 21:35:01
Message: <web.43b34b48f75ef728b1d0d1fd0@news.povray.org>
where image_width and image_height are built in variables in which Pov
stores the width and height of the image as defined in the drop menu or ini
file.
JYR
Date: 29 Dec 2005 01:24:06
Message: <pan.2005.12.29.06.24.04.558205@internode.on.net>
> file.
> JYR
This will create an image with square pixels.  DVD needs non square
pixels, the image resolution could be 702*480,720*480,720*576,720*576
among others all at an aspect ratio of 4:3.
If you always set specific resolutions for standard or HDTV, you could
test for those and set the aspect ratio to 4/3 or 16/9 accordingly.
#if ( (image_width = 720) & (image_height = 576) )
  aspect = 4/3
#else
  aspect = 16/9
Date: 29 Dec 2005 02:10:00
Message: <web.43b38afcf75ef7285c0503730@news.povray.org>
Or you could also declare your aspect ratio as a constant within the ini
file:
Declare = asp_rat = 1.33333
and then refer to that constant in the scene.
See the help section 3.1.2.5.1  Constant
Charles
Date: 29 Dec 2005 03:48:12
Message: <43b3a2cb@news.povray.org>
  Using that is not a good idea. There are several reasons:
  If the aspect ratio of the image is adjusted automatically like this,
it means that if someone renders the image with a resolution having a
different aspect ratio than what the author intended, the resulting image
will be either cropped or parts of the scene not seen in the original will
come into view. In many cases this is a bad thing because it affects (usually
negatively) the composition of the scene: Important parts of the scene may
get cropped out of view, or parts of the scene not intended to be seen
(eg. because of lack of modelling) suddenly come into view. If someone
does this he might often not even notice that there's something wrong with
the image.
  If the viewing angle is adjusted with the 'angle' keyword
(as is rather usual), it introduces a rather unwanted effect when
used in addition to the automatic aspect ratio setting with 'right':
The aspect ratio of the image will in this case always be done
in the vertical direction, either by cropping or extending the image in
the upper and lower sides. This means that if you try to eg. render a
"widescreen" version of the scene, you will only end up cropping the
image from the upper and lower sides (instead of adding new scenery
to the left and right sides). More often than not, scenes are designed
to be rather "panoramic" in nature, ie. the image can be expanded
horizontally. However using the automatic aspect ratio correction along
with a fixed 'angle' setting will not achieve this.
  The automatic aspect ratio correction given above assumes that pixels
are square. There are cases where one *wants* to render an image
for a resolution with non-square pixels (examples include the Windows98
startup screen, which uses a resolution of 320x400, and a DVD movie,
where the video has always an aspect ratio of 1.78:1 although it can then
be stretched to the intended aspect ratio, eg. 2.35:1 by the player). If
the automatic aspect ratio correction is used, it would not be possible
to render an image with non-square pixels without modifying the scene.
  The usage of the keywords image_width and image_height are due to change
in future versions of POV-Ray because they break the frontend-backend
boundary, which can cause problems when more complex ways of rendering
scenes are introduced to the program.
Date: 29 Dec 2005 11:34:28
Message: <43b41014@news.povray.org>
>   aspect = 4/3
> #else
>   aspect = 16/9
> #end
Thanx, that'll work perfectly (with a bit of modification).  I just need
to adapt it so that it'll work properly with the lower-resolution "test"
settings...
Bryan
Date: 29 Dec 2005 11:38:39
Message: <43b4110f$1@news.povray.org>
> file.
> JYR
Won't work.  The way you are calculating aspect ratio assumes square
pixels (i.e. aspect of 1:1, or 1.0), whereas DVD/HDTV/TV use rectangular
pixels.  In the case of DVD the aspect ratio of each pixel is 4:3
(1.33), and for HDTV it is 16:9 (1.85).
If you work out the ratio you calculate you get 1.5 for DVD resolution
images, quite a bit off of the 1.33 standard.  The HDTV is even more
warped if you calculate the aspect ratio based on horizontal/vertical
pixels.
It's irritating as hell - most computer media players don't play back
the animation with non-square pixels, so it looks warped on the
computer, but fine on the output...
Bryan
Date: 30 Dec 2005 03:21:40
Message: <pan.2005.12.30.08.21.39.197129@internode.on.net>
> file:
> Charles
Cool, I didn't know about that one. (Starts reading docs again)
Date: 19 Jan 2006 07:39:54
Message: <43cf889a@news.povray.org>
sorry for my noobiness, but isn't 16:9 = 1.78? i often use the terms
"1.33" and "1.85" when talking about my dvds, but i never before
actually *calculated* what 16:9 equals. am i wrong?
bob
Date: 19 Jan 2006 09:11:58
Message: <43cf9e2e@news.povray.org>
  16:9 is 1.777...:1
  1.85:1 is the least wide format commonly used in movies nowadays
(from what I have seen it seems to be getting rarer, in favor of 2.35:1).
