POV-Ray : Newsgroups : povray.general : fade_power documentation question Server Time
25 Dec 2025 03:57:14 EST (-0500)
  fade_power documentation question (Message 1 to 5 of 5)
Subject: fade_power documentation question
Date: 13 Dec 2005 05:30:56
Message: <439ea2e0$1@news.povray.org>
The documentation for POV 3.5 says "For realistic effects a fade power
of 1 to 2 should be used.", then "If you set fade_power in the interior
of an object at 1000 or above, a realistic exponential attenuation
function will be used"...this is confusing.  Which is the realistic
value, 1..2, or 1000+?
Tim Cook
Version: 3.12
Subject: Re: fade_power documentation question
Date: 13 Dec 2005 06:01:44
Message: <439eaa18@news.povray.org>
  1000 is not a true value. It's a hack. It just turns a different
algorithm on.
  A keyword should have been used instead, but for historic reasons
the hack still seems to be there.
Date: 13 Dec 2005 07:10:01
Message: <web.439eb9486b228396d3eb7f560@news.povray.org>
I think the most logical goal of a light source's fade settings is to model
its light's attenuation due to its energy spreading on ever-expanding
spherical wavefronts, which requires a fade_power of 2, since this effect
makes the light's intensity fall off proportionally to the inverse of the
distance travelled squared, the successive spheres' area being proportional
to the squares of their radii. However, this purpose doesn't make sense for
an interior fade_power, as it can't take the light's location into account,
so the feature should be used as a quick way to simulate light absorption
(without resorting to the fine calculations of media), which causes light
intensity to decrease exponentially, the way a fade_power 1000 or greater
sets up.
Date: 13 Dec 2005 09:00:01
Message: <web.439ed3526b2283966c4803960@news.povray.org>
The answer is both.  If you reread it, you'l see for the main fade function,
a value of 1-2 gives realistic results.  However, if you set it to 1000 or
above, a different function is used.
Date: 13 Dec 2005 11:48:08
Message: <439efb48$1@news.povray.org>
Sounds like you should add "instead" after "used" in the documentaton. :-)
    Sabotage? Communist conspiracy? Or just
    Microsoft again? Only time will tell.
