POV-Ray : Newsgroups : povray.general : Determining the size of a picture Server Time
13 Apr 2026 17:30:49 EDT (-0400)
  Determining the size of a picture (Message 1 to 10 of 10)
Subject: Determining the size of a picture
Date: 5 Oct 2005 20:55:00
Message: <434475e4$1@news.povray.org>
I want to create a simple 'picture frame' macro that will take an image
file as its parameter and return a nicely framed picture, however I
can't see any way to get the size of the picture, they're resized to 1pu
x 1pu.
Is there any way to do this? Or do I need to specify the size in my
parameters?
Cheers!
Rick Measham
Subject: Re: Determining the size of a picture
Date: 6 Oct 2005 02:30:14
Message: <4344c476@news.povray.org>
  Not with the current povray.
> Or do I need to specify the size in my parameters?
  That's probably the only way.
Date: 6 Oct 2005 05:21:47
Message: <4344ecab$1@news.povray.org>
news:4344c476@news.povray.org...
I'm far from an expert in pic files formats but isn't there a way to extract
image size from the image header?
A SDL macro could be very usefull (at least to automate image ratio)
Marc
Date: 6 Oct 2005 05:29:21
Message: <4344ee71@news.povray.org>
  Not with the current SDL.
Date: 6 Oct 2005 06:49:45
Message: <43457FD7.C6D3E94E@kh.rim.or.jp>
Maybe, if you can read .ini file directry.
You can get many parameters from .ini file, I think.
Y.Tanabe
Kobe,Japan
Date: 6 Oct 2005 06:54:31
Message: <43450267$1@news.povray.org>
news:43457FD7.C6D3E94E@kh.rim.or.jp...
Yes but in this case it is for an "input" image i.e. for an image_map for
example and not an output image
Marc
Date: 6 Oct 2005 07:20:20
Message: <43458702.41C6EFF9@kh.rim.or.jp>
Dear Marc
I'm sorry I mistook a topic.
May I remeber for treating with input image by SDL as follows.
But this sample is not my original and I can not remember original writer.
Anyway I attach sample file.
Would you please arrange for technoflux.inc.
> Marc
Download 'iso-2022-jp' (8 KB) Download 'iso-2022-jp' (1 KB)
Date: 7 Oct 2005 08:41:15
Message: <43466ceb@news.povray.org>
"Rick Measham" <rickm*at%isite.net.au> wrote in message
news:434475e4$1@news.povray.org...
> x 1pu.
> parameters?
> Cheers!
> Rick Measham
Here's a macro to do it. It scans the centre lines of the image looking for
the smallest dot it can find, so it can make mistakes with some images if
they're made up of large blocks of color, ie if the centre lines don't hit a
pixel sized color change.
To change the image type you'll need to update the macro, as I couldn't get
it to work as a variable. It's currently set to 'jpeg'. For bmp use 'sys'.
Takes about a second to scan a 640x480 image.
Hope it's useful,
Chris B.
Download 'detectimagesize.pov.txt' (4 KB)
Date: 7 Oct 2005 09:32:40
Message: <40uck1916ppsvq5c6us9amgokure3tk2pe@4ax.com>
On Thu, 06 Oct 2005 10:55:00 +1000, Rick Measham <rickm*at%isite.net.au>
> x 1pu.
If you do not mind to use patched version then such feature is available in
MegaPOV (as long as I understand you correctly).
See http://megapov.inetart.net/manual-1.2.1/expressions.html#images_sizes
ABX
Date: 7 Oct 2005 12:26:11
Message: <4346a1a3$1@news.povray.org>
I bet you could do it with SDL for images in PPM format.
    Neither rocks nor slush nor salted rims
    shall keep us from our appointed rounds.
