POV-Ray : Newsgroups : povray.general : Saved data in two-pass radiosity Server Time
22 Nov 2025 22:22:03 EST (-0500)
  Saved data in two-pass radiosity (Message 1 to 5 of 5)
Subject: Saved data in two-pass radiosity
Date: 4 Oct 2005 20:47:57
Message: <434322bd@news.povray.org>
What data is saved in the first pass? Is it specific to that camera
position, direction, up, right etc? Or does it calculate radiosity
throughout the entire scene, even off camera?
Is the data specific to the image size, or can I do the first pass at
800x400 and the second at 1600x800 (even if accuracy is lost) or will
that apply the save radiosity to the (eg) upper left corner of the
resulting render?
Cheers!
Rick Measham
Subject: Re: Saved data in two-pass radiosity
Date: 4 Oct 2005 21:06:43
Message: <43432723$1@news.povray.org>
The radiosity is calculated only in places that are visible from the current
camera position (or through reflection/refraction). However, that data is
stored in 3D space, so you can reuse that data even if you move the camera.
In theory only the newly visible areas will be recalculated if you load the
original data. I haven't tested this.
> resulting render?
The data is not linked to the image size. It's possible that increasing the
resolution will require more radiosity calculations on top of the original
data in order to account for the greater level of detail. Again, I haven't
tested this.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 5 Oct 2005 01:03:30
Message: <43435ea2@news.povray.org>
Has anyone else tested this? If this is the case, on the second pass,
should I save the data as well as load it? (so that the extra data is
added) then it might just be a case of running the second pass for most
renders ..
Cheers!
Rick Measham
Date: 5 Oct 2005 04:32:45
Message: <43438fad@news.povray.org>
"Rick Measham" <rickm*at%isite.net.au> wrote in message
news:43435ea2@news.povray.org...
> renders ..
Hi Rick, have you seen Tim's page regarding two-pass radiosity?
http://www.nolights.de/projects/radiosity/radiosity.html
There's a lot of great info on there which should answer many of your questions.
Tim also provides a sample scene to experiment with two-pass radiosity.
Lance.
thezone - thezone.firewave.com.au
Date: 10 Oct 2005 03:48:45
Message: <434a1cdd@news.povray.org>
"Rick Measham" <rickm*at%isite.net.au> schreef in bericht
> renders ..
I had the same question for my interpretation of windows_room, and yes, my
conclusion is that you can render the second pass at a larger scale. No need
to save the data again, although... that could help for later renders
probably.
