![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hi there,
while working on something hairy, I stumbled over several includes and
macros available throughout the net. But unfortunately all seem to work
only in conjunction with external programs like the MeshCompressor (by
C. Colefax if I renember wright).
Is it possible (or planned) to access the internal data structure of a
mesh through SDL. (like MESH_IDENTIFIER.vertex[number_of_vertex] or
MESH_IDENTIFIER.face[number_of_face] etc. ?
This would make it possible to write macros for placing things evenly
distributed on a mesh, which could also had been created by an macro in
first place, without the need of external programs, writing the whole
mesh crap to disk or the neccessarity of writing an own mesh parser in SDL.
answers are welcome ;-)
.... dave
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"David El Tom" <dav### [at] t-online de> wrote in message
news:432d2eb9@news.povray.org...
> Hi there,
> only in conjunction with external programs like the MeshCompressor (by C.
> first place, without the need of external programs, writing the whole mesh
> .... dave
Hello Dave,
I'm not aware of anything that gives you direct access to the internal data
structures from the SDL. However, I've used a couple of ways of achieving
the sort of thing you describe.
One is to use trace() to fire a random series of rays at an object to detect
points and normals (for growing hairs out of).
The other has been to generate points into an array and then generate a mesh
from that. Then you can use the same array for other tasks, such as
distributing things evenly on the surface of the mesh.
Chris B.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Chris B wrote:
> Hello Dave,
> Regards,
> Chris B.
thank you for your suggestions,
the problem I had was to distribute a number of points evenly on a
complex mesh.
The method of shooting rays in a random fashion is well known to work
well with simple meshes or nearly planar heightfields. The drawback of
this method is that you normaly miss the hidden surfaces and all
surfaces which are perpendicular to the ray.
In the meanwhile I came up with methode which is quite analogue to your
second suggestion. I wrote a PERL script which reads an include with a
mesh in mesh2 format and drops me an include with arrays of points,
normals and corresponding uv's (if aviable).
take a look at p.b.images + p.b.utilities for details.
.... dave
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
