POV-Ray : Newsgroups : povray.general : Need of a macro or a trick Server Time
1 Oct 2024 05:15:43 EDT (-0400)
  Need of a macro or a trick (Message 1 to 7 of 7)
Subject: Need of a macro or a trick
Date: 24 Jul 2005 16:36:18
Message: <42e3fbc2$1@news.povray.org>
Hi ! I need the help of good POVers. Here is my problem.
I've a big .ini file (generated by ARBARO), most of this file looking like
this
#declare leaves=union {
    object {leave} matrix <....>
...   ... about 24000 lines like that
I'd like to paint the leaves with several textures. So I need to split this
big union into, say, 3 unions of about 8000 lines.
BUT ! the lines are ordered, so I wanted to take about 8000 random line in
this list, or one line every three, cut them in the editor and paste them
elsewhere. Looks very tricky for me.
Do you know if it is feasible with macros in the GUI, or with an external
editor ? I really don't want to move all lines one by one at hand...
Thanks a lot, il will greatly help me !
Subject: Re: Need of a macro or a trick
Date: 24 Jul 2005 17:07:44
Message: <42e40320$1@news.povray.org>
> this
Well, my instinct would be to go external.  My tool of choice for
parsing files is Python. I think the text manipulation tools are quite
powerful and intuitive.  I no longer speak programmerese well, but the
ease seems to come from its abilities to shift data typing without a lot
of fuss. Beyond that there is a lot of flexibility for substr indexing
type work. I am sure similar scripting languages do this too but Python
is the one I can vouch for. And the file access is simple and okay for
writing little personal tools like this.  Believe me, if I could learn
this language, it is a very shallow learning curve.
I think some people here would also use Excel for the sort of thing you
want to do.  But I don't know much about it.
SDL could also handle this with a little coaxing.  Seems to me Mike
William's posted a routine for producing mesh2 and obj. format using sdl
that also featured some tight syntax for reading and processing files
easily. But I can't seem to find it now, so maybe I was just dreaming :|
Date: 25 Jul 2005 00:55:47
Message: <42e470d3$1@news.povray.org>
42e40320$1@news.povray.org...
OpenOffice.org is my working tool. I did a try with OOo Calc and it works
perfectly !!!!!! Thanks a lot for the idea.
One day, I'll look at Python, it seems quite simple and powerful...
Date: 25 Jul 2005 15:20:00
Message: <web.42e53b4cd595e87477c7c2360@news.povray.org>
send it to me, I will handle it.
Chr### [at] compuservede
Chrisir
Date: 25 Jul 2005 16:22:56
Message: <42e54a20$1@news.povray.org>
> perfectly !!!!!!
That's what I said! "OO Calc!" What did you think I said? ;)
Thank Gilles as usual.
Can't hurt.
Date: 25 Jul 2005 17:19:24
Message: <42e5575c@news.povray.org>
Hash: SHA1
	If you have one line per object and nothing else in the file
(not even the "#decleare leaves=union {" and "}" lines, then the
following python code should do what you want:
from random import shuffle
f = open ("file.inc", "r")
l = f.readlines()
f.close()
shuffle (l)
f = open ("one.inc", "w")
f.writelines (l[:len(l)/3])
f.close()
f = open ("two.inc", "w")
f.writelines (l[len(l)/3:(2*len(l))/3])
f.close()
f = open ("three.inc", "w")
f.writelines (l[(2*len(l))/3:])
f.close()
	Note that if you have kept the first and last lines in the input
file, you can get rid of them by replacing line 4 by:
"l = f.readlines()[1:-1]"
		Jerome
*      Jerome M. Berger      *
*  mailto:jeb### [at] freefr   *
*  http://jeberger.free.fr/  *
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.0 (GNU/Linux)
iD8DBQFC5VdbqIYJdJhyixIRAmkXAJ4la65rHfh0j5LWGQOE6HxZG28y3wCfVZIU
DuAnJWsIWX1PBg6GQwJQ3AU=
=SEn/
-----END PGP SIGNATURE-----
Date: 26 Jul 2005 01:33:38
Message: <42e5cb32$1@news.povray.org>
Impressive ! Couldn't imagine it was soooooo easy. Thanks.
@Chrisir. Thanks for your kind proposition, but my problem is solved. And I
had to know how to do it, I'll have the same problem later, so...
42e5575c@news.povray.org...
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> l = f.readlines()
> f.close()
> shuffle (l)
> f.close()
> f.close()
> f.close()
> Jerome
> =SEn/
