POV-Ray : Newsgroups : povray.general : crash with isosurface Server Time
25 Dec 2025 09:50:23 EST (-0500)
  crash with isosurface (Message 1 to 3 of 3)
Subject: crash with isosurface
Date: 1 Aug 2005 11:17:07
Message: <42EE3D0E.70207@t-online.de>
I'm having a crash problem with isosurface
using pov-ray 3.6.1 for windows on windows XP:
// PoVRay 3.6 Scene File "isocrash.pov"
#include "functions.inc"
camera{  angle 10
          location  <20.0 , 20.0 ,-20.0>
          look_at   <0.0 , 0.5 , 0.0>
light_source{< -3000, 3000, -3000> color rgb<1,1,1>}
isosurface {
   function{
   sqrt(  0.5*x*x + y*y + z*z - 1)
   - f_noise3d( x*12, y*12, z*12 )
   contained_by { box { -2.5, 2.5 } }
   accuracy 0.002
   max_gradient 15
   texture{ pigment{ color rgb<0.45,0.9,0.1>}
                 finish { reflection 0.1}
} // end of isosurface -----------------------------
sphere { <0,0,0>, 0.75
                 pigment{ color rgb< 1, 0.0, 0.0>}
            translate<2.00,0,0>
        }  // end of sphere -------------------------
box { <0, 0,0>,< 1, 1, -1>
       pigment{color rgb<1,1,1>}
       translate<2.5,0,0>
     } // end of box --------------------------------
//------------------------------------- end of scene
Rendering the scene without the sphere and the box
works well.
If we uncomment the sphere POV-Ray crashes, throwing
out an error message (see below!).
If we uncomment only the box no crash!
If we set "reflection 0.0" it does not crash,
also with the sphere.
There is no problem with this scene, if we render it
with POV-Ray version 3.5 !
Error message: //--------------------------------------------
The POV-Ray core rendering code threw an unhandled exception.
The backend thread has been shut down and you will not be
able to perform any further renders.
It is STRONGLY RECOMMENDED that you save your work and exit
POV-Ray now. Note that if internal structures have been
damaged POV-Ray may crash immediately after you click OK).
system specs:
POV-Ray 3.6.1a.icl8.win32
Windows XP Home Edition (SP2)
Pentium IV 3.20 GHz
2 GB Ram
200 GB hard disk
The above scene crashes also on all my computers at home
and the computers in my school!
Does anybody know where the problem is?
Greetings to all!
email: Fri### [at] t-onlinede
homepage: http://www.f-lohmueller.de/index.htm
Subject: Re: crash with isosurface
Date: 1 Aug 2005 11:45:01
Message: <dclg04$2j5$1@chho.imagico.de>
Renders without error in all variations using official 3.6.1 here (on Linux)
But note:
tries to calculate the square root of a negative number for some values
of x,y and z, the result of this is not defined (and can vary from
platform to platform - i even get different results with different
builds here).
You almost certainly want:
sqrt( 0.5*x*x + y*y + z*z ) - 1
http://www.tu-bs.de/~y0013390/ (Last updated 24 Jul. 2005)
Date: 1 Aug 2005 12:49:13
Message: <42EE52A5.2060100@t-online.de>
Hi Christoph,
> But note:
> builds here).
Thanks a lot, that solves the problem!
Friedrich
