POV-Ray : Newsgroups : povray.general : glass panes Server Time
11 Jan 2026 03:29:01 EST (-0500)
  glass panes (Message 1 to 6 of 6)
Subject: glass panes
Date: 21 Jan 2005 17:13:05
Message: <41f17e71$1@news.povray.org>
I'm wondering what would be a good texture,finish and interior for you
average windowpane glass?
I'm currently using the settings below, but I woner if it could be
optimised:
// Glass of window panes
#declare T_Glass=texture{
   pigment{
     color rgbt 1
   finish{
     ambient 0.1
     diffuse 0.04
     reflection{ 0.5 fresnel on }
     conserve_energy
#declare I_Glass=interior{
   ior 1.5
   fade_power 2 //1.5
   fade_distance 1
   fade_color <0.70, 0.7, 0.9>
   //dispersion 1.01
   //dispersion_samples 100
Maurice
Subject: Re: glass panes
Date: 21 Jan 2005 17:16:06
Message: <41f17f26$1@news.povray.org>
Maurice wrote:
> Hi,
I forgot to mention that I'm particularly struggeling with the
fade_power, fade_distance and fade_color values. The manual is rather
cryptic about those. I guess fade_power would have to be 2 in order to
be physically correct, but the fade distance of window pane glass I have
no idea what it should be. Also the fade_color.
Date: 21 Jan 2005 18:04:36
Message: <41f18a84$1@news.povray.org>
"Maurice" <cel### [at] nospamhotmailcom> wrote in message
news:41f17e71$1@news.povray.org...
> Hi,
> optimised:
>    pigment{
>      color rgbt 1
>    finish{
>      ambient 0.1
>      diffuse 0.04
>      conserve_energy
i think glass would have "ambient 0"
for reflection, i think it would be a variable reflection. My reason is that
if you look straight at the glass, you can see pretty much straight through
it (depending on the type of glass i guess) and if you look at it at a
shallow angle it is more reflective. This effect is very pronounces with
water anyway. glass too i think. i'm not sure of the physical values, but
something like "reflection {0.1, 0.5 fresnel on}"
>    ior 1.5
>    fade_power 2 //1.5
>    fade_distance 1
>    //dispersion 1.01
fade stuff... hopefully someone else can help you on that :) I would have
left it at defaults. I've only ever really used them for lights. i've used
fade_color for murky water once...
good luck!
Date: 21 Jan 2005 21:44:57
Message: <41f1be29$1@news.povray.org>
Maurice nous apporta ses lumieres en ce 2005-01-21 17:13:
> Hi,
> optimised:
>   pigment{
>     color rgbt 1
>   finish{
>     ambient 0.1
>     diffuse 0.04
>     conserve_energy
>   ior 1.5
>   fade_power 2 //1.5
>   fade_distance 1
>   //dispersion 1.01
You can probably get by without any fade, unless your glass is very thick. Plate glass
is slightly
greenish, not pure white. Normal glass is not perfectly transparent:
  color rgbft<0.95, 0.99, 0.94, 0.7, 0.23> can give you a good glass pane.
Date: 25 Jan 2005 15:16:06
Message: <cjameshuff-7D6F49.15160925012005@news.povray.org>
In article <41f1be29$1@news.povray.org>,
> Plate glass is slightly
If you see the glass at a shallow angle or see a thin edge of it, the
fading will be important because of the contribution of "trapped" rays.
It is not very computationally expensive, so I usually use fading with a
perfectly transparent surface pigment. (Unless the surface is dirty,
that is.)
http://tag.povray.org/
Date: 25 Jan 2005 18:07:47
Message: <cjameshuff-828B7D.18075025012005@news.povray.org>
In article <41f17f26$1@news.povray.org>,
fade_color is the apparent color of the material. For red glass, it
should be red. A side note: I rarely use pure colors, I'd use tiny
values of green and blue as well, for more realistic response to very
bright light.
fade_power controls the function of distance used. Most realistic is a
fade_power of 1000, which tells POV to use exponential attenuation.
(Yeah, that's a terrible syntax for this...)
fade_distance controls the density...doubling it will make it reach a
given proportion of the fade_color color in half the distance.
What I usually do is set fade_power to 1000, pin down the approximate
color I want, then tweak fade_distance until it's the right density.
