POV-Ray : Newsgroups : povray.general : Media, Intervals, samples and getting results Server Time
29 Mar 2026 21:06:34 EDT (-0400)
  Media, Intervals, samples and getting results (Message 1 to 10 of 25)
Subject: Media, Intervals, samples and getting results
Date: 3 Jan 2005 10:19:02
Message: <41d96266$1@news.povray.org>
Someone care to explain the following from the manual:
"It's usually best to only use one interval with method 3. Too many
intervals can lead to artefacts, and POV will create more intervals if
it needs them."
It seems with one interval, I don't get good results. If I up the
intervals to 5 or 10, it seems to work better, but is slower in general.
Anyone have any clue about the relationship and why the manual asks to
use only 1 interval?
~Mike
Subject: Re: Media, Intervals, samples and getting results
Date: 3 Jan 2005 13:19:36
Message: <41d98cb8$1@news.povray.org>
Well, more intervals causes more sampling since there are the same number of
samples per interval.
What the documentation is saying is that, if you need better results, you
should increase the sample count rather than the interval count.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 3 Jan 2005 13:47:49
Message: <41d99354@news.povray.org>
What I don't quite understand is why the number of samples has so much
effect over the overall brightness of the media (I'm thinking of dense
scattering media to simulate SSS). Sure, the sample number should affect
the quality and presence of possible artifacts, but why is "samples 15" so
much brighter than "samples 75" (method 3, intervals 1)? Is this maybe due
to some bad coding on my part?
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Date: 3 Jan 2005 13:57:22
Message: <41d99592@news.povray.org>
Interesting that the defaults for media would be set up as such:
aa_level     : 4
aa_threshold : 0.1
absorption   : <0,0,0>
confidence   : 0.9
emission     : <0,0,0>
 >> intervals    : 10
 >> method       : 3
ratio        : 0.9
 >> samples      : Min 1, Max 1
variance     : 1/128
SCATTERING
   COLOR        : <0,0,0>
   eccentricity : 0.0
   extinction   : 1.0
I'm beginning if they meant samples should be at 1 in the documentation
and not intervals.
I'm hopelessly confused.
~Mike
Date: 3 Jan 2005 14:01:36
Message: <41d99690$1@news.povray.org>
The better question is: Is there a really good tutorial on using media?
~Mike
Date: 3 Jan 2005 14:16:02
Message: <41d999f2@news.povray.org>
Hash: SHA1
affect
15" so
maybe due
	That's because the darkening you see is an artefact :) It's due to
the fact that when you don't take many samples, a lot of them
proportionnaly get taken deep inside the media where it's dark.
Increasing the number of samples ensures that more and more get taken
in the thin layer near the surface where the SSS effect occurs which
leads POV to notice that the result should be bright. BTW, you
shouldn't increase the number of samples too much. Instead you should
increase the aa_level and possibly decrease the aa_threshold. This
will ensure that the additional samples get taken in places where
they will have a useful impact on the result.
		Jerome
*      Jerome M. Berger      *
* mailto:jbe### [at] ifrancecom *
*  http://jeberger.free.fr/  *
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
iD8DBQFB2ZnwqIYJdJhyixIRAjCoAJ9Mh12iDLjNYBtmUPJZg5HthQ5zTwCeIjar
AuqaKLzmlYjCRPrfbUjynlA=
=2sxH
-----END PGP SIGNATURE-----
Date: 3 Jan 2005 14:35:22
Message: <41d99e79@news.povray.org>
According to this, more samples -> brighter media. But I see the opposite,
as if the influence of the samples was "averaged" (since most samples are
deep inside, the effect of the surface ones is weaker). I would have
thought that the sampling algorithm (and colour calculation) would be
smarter than that, but maybe that's not so easy...
> BTW, you
I couldn't get the same effect... Even if the "darkening" due to many
samples (or intervals) is an artifact, I didn't find a reliable way to get
what I needed other than increasing the number of samples.
Date: 3 Jan 2005 17:29:02
Message: <41d9c72e$1@news.povray.org>
Hash: SHA1
	That is correct. If you push this to the extreme, you'll get this
image (10 samples):
http://jeberger.free.fr/mpov/sphere_bl.png
	Increasing the number of samples (to 200) gives this one:
http://jeberger.free.fr/mpov/sphere_no.png
samples are
	Do you have a sample code that produces this effect?
|>BTW, you
to get
	It takes some trial and error, but it should be possible to get the
same effect with a much faster render. Of course, it all depends on
whether you can afford to waste more time fiddling with the
parameters or simply letting the computer render in the background
while you're doing something else ;) To make accurate comparisons,
you also need to make sure that the maximum number of samples is the
same in both cases (I'm not talking of the second parameter of the
"samples" keyword here, but of the number of potential samples which
is something in the order of min_samples * 2^aa_level). Then if you
set aa_threshold to 0 the results should be the same (and take
*forever* to render) so all you need to do is find a value that's low
enough to get the effect you want while not being exactly 0.
	Note that this only applies to subsurface scattering simulations: eg
in cases when you have a very dense nearly uniform media. If you have
a density with areas of very dense media and other areas that are
empty, you will need the increased number of samples
		Jerome
iD8DBQFB2cctqIYJdJhyixIRAh5MAJwNx+lC7Jw+TJml4MXtT7bAedh8MgCdHgrM
GTqdVZYfJXewymGtk1yKX4Y=
=uGCQ
Date: 3 Jan 2005 18:25:53
Message: <41d9d47f@news.povray.org>
> samples are
Yep, try this (povray 3.6.1, custom compile):
camera { location <0, 0, -10> look_at 0 }
light_source { <-20, 20, -20>, rgb 1 }
sphere {
  0, 3
  hollow
  pigment { color transmit 1 }
  interior {
    media {
      scattering { 5, rgb 3 }
      method 3
      intervals 1
      samples 10 // try also with 200
I've attached two images: "test1" has samples 10, "test2" has samples 200.
In my experiments, I did not see any significant difference in the output by
fiddling with aa. According to your explanation, "samples 10 aa_level 8
aa_threshold 0.0001" should give similar results to "samples 160 aa_level 4
aa_threshold 0.0001", and I don't see that with the above example. Could
you give a more clear example?
Yes, my experiments are confined to uniform media. I wonder if this adaptive
sampling and antialiasing is only valid for non-uniform media (opposite to
your sentence above), maybe uniform media makes adaptive sampling
unnecessary...
Or maybe I'm making some mistakes.
Download 'test1.jpg' (3 KB) Download 'test2.jpg' (3 KB)
Preview of image 'test1.jpg'
Preview of image 'test2.jpg'
Date: 3 Jan 2005 21:01:35
Message: <41d9f8ff@news.povray.org>
You should see the thread "default media setting inconsistancies (?)" on
12/27/2004 (about 15 threads down). Assuming I gave correct information in
that thread (and I may be wrong; no one's confirmed), it should clarify
things for you.
 - Slime
