![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
POV-Ray's read ignores "//" and chokes when it finds a reserved word
so how do I read a *.pov or *.inc file without errors?
#fopen Data "ANY.pov" read
#read ( Data, In )
#debug concat("\n** ", In," **\n")
#fclose Data
Parse Error: Expected 'float, vector, or string literal', camera found
instead.
Enclosing the whole file in quotes gets you a "String too long"
message.
So I've got this large POV file of 7K+ balls, outputed by another
application of the form object{ sphere,0 1 scale 1of2 texture{ 1of5 }
translate There }. I thought it would be easy to use POV-Ray to read,
scan and re-write to a 2nd file using 5 simple unions. I'm sure I've
done it with my own INCs a couple of years or so ago but don't
remember how :(
Alf
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
You don't.
#read only reads comma-separated values, nothing more.
<1,1,3>hollow}text{ttf"timrom""Warp".1,0translate<-1,-.1,2>}// - Warp -
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Warp" wrote:
> You don't.
Yes. Of course, I should have remembered.
OK - I've figured what I did before. The original output format was
strict, a scene setup followed by many objects. Instead of trying to
retrieve data, I deleted unwanted data with find and delete or replace
using my favourite text editor - Notespad - freeware from
http://www.bremercorp.com/
I'll post before and after stats in a few days.
Alf
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hmmm... that link seems down ATM.
Try here http://www.newbie.com/NotesPad/ for V8.0
Alf
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
To satisfy my own curiosity re memory requirements (and as an
excercise), this is the result of playing with a MolPov output file.
I used a text editor to Cut and Save the scene setup.
Careful use of search and replace or delete on the remainder modifies
each object as shown in <Before> and <After>, leaving a string and 3
vectors. POV-Ray then reads this file and writes/appends a union{} for
each pigment in one pass to a second *.POV file. The original scene
setup is then pasted in.
<Before>
// Object: description ...
object
{ sphere {<0, 0, 0>, 1.0 }
texture
pigment
{ color Gray
scale < 1.65, 1.65, 1.65>
translate < 1.404333, 0, 0>
</Before>
<After> (a temp file)
"// Object: description ...
<1.75,0.75,0.75>
,< 1.65, 1.65, 1.65>
,< 1.404333, 0, 0>
</After>
Before and after stats, -d
Finite objects: 7378
Original *.pov 1790KB (#included "colours.inc")
Peak memory used: 8685329 bytes
CPU time used: kernel 0.13 seconds, user 1.67 seconds, total 1.80
seconds
Modified *.pov 591KB ("colours.inc" not #included)
Peak memory used: 2577761 bytes
CPU time used: kernel 0.13 seconds, user 1.36 seconds, total 1.48
seconds
Alf
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> <Before>
> object
> texture
> pigment
> { color Gray
> </Before>
> <1.75,0.75,0.75>
> ,< 1.404333, 0, 0>
> </After>
If you're only interested in filtering out the vectors (and maybe
comments) in this, then I guess it would be a one-liner in Perl. Could
save you some work :)
HTH,
Florian
camera{look_at-y*10location<8,-3,-8>*10}#local a=0;#while(a<999)sphere{
#local _=.01*a-4.99;#local p=a*.01-5;#local c=.01*a-4.995;<sin(p*pi)*5p
*10pow(p,5)*.01>sin(c*c*c*.1)+1pigment{rgb 3}}#local a=a+1;#end
/******** http://www.torfbold.com ******** http://www.imp.org ********/
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Could save you some work :)
Ahhh ... but its much more fun using POV-Ray ;)
Alf
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
That's of course true :)
Florian
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
