POV-Ray : Newsgroups : povray.general : color (pigment) as an absolute function of coordinates Server Time
11 Sep 2025 05:40:45 EDT (-0400)
  color (pigment) as an absolute function of coordinates (Message 1 to 5 of 5)
Subject: color (pigment) as an absolute function of coordinates
Date: 22 Nov 2004 06:35:13
Message: <41a1cef1@news.povray.org>
Hi all,
Is there a good way to have the pigment dependent on the absolute (x,y,z)
position? I want to create a height-field and a sphere where the pigment is
determined as a function of the <x,y,z,> vector....
thanks,
gert
Subject: Re: color (pigment) as an absolute function of coordinates
Date: 22 Nov 2004 08:52:28
Message: <41a1ef1c@news.povray.org>
"Gert Van den Eynde" <gvd### [at] hotmailcom> schrieb im Newsbeitrag
news:41a1cef1@news.povray.org...
> Hi all,
is
As a first short answer, have a look at the POV-Documentation at
  '3.4.11.15  Function as pattern'
If you have more questions feel free to ask!
> thanks,
> gert
Thies
Date: 22 Nov 2004 10:10:30
Message: <41a20166@news.povray.org>
>> Hi all,
> Hi,
> is
thanks, missed that one.
note to self: rtmom (read the manual once more)
bye,
gert
Date: 23 Nov 2004 10:43:44
Message: <41a35ab0@news.povray.org>
>>> Hi all,
>> Hi,
>>> (x,y,z) position? I want to create a height-field and a sphere where the
>>> pigment
>> is
hmm, did that and it isn't really clear to me how to proceed. Below is (in
Octave) my color function. The variable v in the script is to be the height
of the height-field (y-value). vmin and vmax are 0 and 1 in the case of a
height_field, no? How do I put this function in povray and have it used as
the pigment of my heightfield?
thanks for any tips,
gert
function [r,g,b] = mapcolor(v,vmin,vmax)
if (v < vmin),
    v = vmin;
end
if (v > vmax),
    v = vmax;
end
dv = vmax-vmin;
r = 1; g = 1; b = 1;
if (v < (vmin + 0.25 * dv)),
    r = 0.0;
    g = 4.0*(v-vmin)/dv;
elseif (v < (vmin + 0.5*dv)),
    r = 0.0;
    b = 1.0+4.0*(vmin+0.25*dv-v)/dv;
elseif (v < (vmin +0.75*dv)),
    r = 4.0*(v-vmin-0.5*dv)/dv;
    b = 0.0;
else
    g = 1.0+4.0*(vmin+0.75*dv-v)/dv;
    b = 0.0;
end
Date: 25 Nov 2004 16:28:36
Message: <41a64e84$1@news.povray.org>
news:41a35ab0@news.povray.org...
height
i borrowed the average-pigment-idea by Slimes answer to the thread
'3d color function' in povray.newusers which looks like this:
  average
  pigment_map {
    [1 function {f_r(x,y,z)} color_map {[0 rgb 0][1 rgb <1,0,0>*3]}]
    [1 function {f_g(x,y,z)} color_map {[0 rgb 0][1 rgb <0,1,0>*3]}]
    [1 function {f_b(x,y,z)} color_map {[0 rgb 0][1 rgb <0,0,1>*3]}]
now you need the 3 functions for rgb;
i think the difficulty in converting your function to POV-SDL are the
if-else-constructs. These can be modeled in a function with the
 'select'-function. Your function converted then looks like this:
#declare f_r = function(v)
    select(
      v-0.5,
      0,
      select(
        v-0.75,
        4*v-2,
        1
#declare f_g = function(v)
    select(
      v,
      0,              // v<0
      select(         // v>0
        v-1,
        select(       //   0<v<1
          v-0.25,
          4*v,        //     0<v<0.25
          select(     //     1>v>0.25
            v-0.75,
            1,        //       0.25<v<0.75
            4-4*v     //       1>v>0.75
        0             //   v>1
#declare f_b = function(v)
    select(
      v-0.25,
      1,
      select(
        v-0.5,
        2-4*v,
        0
of course you can write this in one line if you want, i just
formatted it for better readibility.
For your specific rgb-function though i would do it with the
following functions, which do the same job, just a bit more
elegant:
#declare f_r = function(v) { min(max(4*v-2,0),1) };
#declare f_g = function(v) { min(max(2-abs(4*(v-0.5)),0),1) };
#declare f_b = function(v) { min(max(2-4*v,0),1) };
If you want to avoid the discontinuities at 0.25, 0.5 and 0.75
you'll have to use more smooth functions like the cosine.
no problem
> gert
Thies
