![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Hello-
I am trying to cover a surface with discs (flattened spheres), such that
each disc lies flat on the surface. I have the normals at each point
(thanks to Tim Nikias' Mesh-Maker-Macros), and need to know how to rotate
my spheres (discs) so that they will be perpendicular to the normal at each
point.
I have tried many approaches, but none are giving the result I want. Can
anyone help?
Thanks,
Leo
Leo Bleicher
http://porterbleicher.g2gm.net/computed-paintings.htm
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
each
> point.
Well, the normal should be the "up" vector of the disc, right?
What you could use <shameless plug> is my Look_At-Macro </shameless plug>
which returns the rotation vector needed to rotate the -z direction towards
the given position/vector. So
rotate Look_At(Insert_Normal)
should work when the top of the sphere/disc is facing -z.
There's also a macro called "Orient" or something within the
POV-Shipped-Includes, but I'm the self-made guy, so I can't help you much
with that...
Tim
"Tim Nikias v2.0"
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> anyone help?
Look at the documentation about transforms.inc in the POV-Ray
documentation.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Thank you. That has solved my problem nicely.
Leo
Leo Bleicher
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
