POV-Ray : Newsgroups : povray.general : Mesh2 & textures memory problem Server Time
15 Jan 2026 05:48:40 EST (-0500)
  Mesh2 & textures memory problem (Message 1 to 4 of 4)
Subject: Mesh2 & textures memory problem
Date: 24 Oct 2004 10:02:05
Message: <417bb5dd@news.povray.org>
Hello,
   I'am using mesh2 for creating bush into terrain visualisation. I have
one mesh2 bush object and I need to place several tens of thousands of
instances into the scene. When I use mesh2 without textures, I have no
problem with memory. But when I try to assign some textures to mesh2
object, memory requirements are very high (several hundreds of MB). I
have nine textures predefined before and they are randomly assigned to
leaves in the bush.
   When I'am thinking about it, it looks like all nine textures are
copied for each instance of my mesh2, but I'am unable to see any reason
for it.
   Is anowhere some way how to solve this?
Thanks for any advices :)
Vaclav
Subject: Re: Mesh2 & textures memory problem
Date: 24 Oct 2004 14:11:06
Message: <417bf03a@news.povray.org>
Vaclav Cermak wrote:
> Hello,
> leaves in the bush.
> for it.
> Vaclav
This is what I use in PoseRay (http://user.txcyber.com/~sgalls/) to
decrease the amount of memory required if several materials use the same
map.
Declare the map once like this:
#declare map1=pigment{image_map{jpeg "your image.jpg" interpolate 2}}
then declare the material:
#declare mat1=texture{pigment{map1}}//add a finish if you want
then use the material in mesh2{}:
texture_list{
1,
texture{mat1}} //add more if you use more materials
This should allocate room for the map once.
good luck,
FlyerX
Date: 24 Oct 2004 17:15:30
Message: <417c1b72@news.povray.org>
Are you using a texture_list or are you defining a texture global to
the entire mesh?
Date: 25 Oct 2004 04:11:59
Message: <417cb54f@news.povray.org>
I'am using texture_list.
> the entire mesh?
