POV-Ray : Newsgroups : povray.general : Burn mark on an isosurface Server Time
22 Nov 2025 16:27:40 EST (-0500)
  Burn mark on an isosurface (Message 1 to 5 of 5)
Subject: Burn mark on an isosurface
Date: 10 Sep 2004 11:47:30
Message: <4141cc92$1@news.povray.org>
I would like to make it look like there's a slight burn mark
on an isosurface object. How would you go about making
it look like that?
=Bob Clueless=
Subject: Re: Burn mark on an isosurface
Date: 10 Sep 2004 16:12:45
Message: <41420abd$1@news.povray.org>
"=Bob=" <robertUNDERSCOREdobbinsATmailDOTtdsDOTnet> schrieb im Newsbeitrag
news:4141cc92$1@news.povray.org...
> it look like that?
i made a small scene with a sphere-iso which has a
(very simple) symbol dented into it. Is that what
you had in mind ?
In general i would try to think of a function which
has positive values where i later want my bumps to
appear and everywhere else zero (or close to zero).
Then you have to do a coordinate transformation
so that your dents appear in the right place with
the right orientation and scaling.
In the example i used a kind of 3d-gaussian-bell-
falloff-function and added four differently placed
copies of it to the rest of the isofunction.
If you have a more specific shape in mind, tell me.
> =Bob Clueless=
Thies
global_settings {assumed_gamma 1.0}
  location  <-1.0, 1.5, -3.0>
  direction 1.5*z
  look_at   <0.0, 0.0,  0.0>
light_source {0 color rgb 1 translate 30*<-1,1,-1>}
#declare tex1 =   texture {
      radial
      frequency 8
      color_map {
        [0.00 color rgb <1.0,0.4,0.2> ]
        [0.33 color rgb <0.2,0.4,1.0> ]
        [0.66 color rgb <0.4,1.0,0.2> ]
        [1.00 color rgb <1.0,0.4,0.2> ]
    finish{
      specular 0.4
#declare fn_mark = function(x,y,z) {
  exp(-(pow(x,2)+pow(y,2)+pow(z,2)))
isosurface {
  function {
    x*x+y*y+z*z-1*1 +
    0.2*fn_mark(30*(x+1/4),4*y,30*(z+sqrt(1-1/4*1/4)))+ // Left
    0.2*fn_mark(30*(x-1/4),4*y,30*(z+sqrt(1-1/4*1/4)))+ // Right
    0.2*fn_mark(4*x,30*(y+1/4),30*(z+sqrt(1-1/4*1/4)))+ // Bottom
    0.2*fn_mark(4*x,30*(y-1/4),30*(z+sqrt(1-1/4*1/4)))  // Top
  contained_by { sphere{0,1.05}}
  accuracy 0.01
  max_gradient 7
  //evaluate 2, 1.2, 0.95
  texture { tex1 }
Date: 10 Sep 2004 17:33:10
Message: <41421d96$1@news.povray.org>
"Thies Heidecke" <h3i### [at] gmxnet> wrote in message news:41420abd$1@news.povray.org...
: "=Bob=" <robertUNDERSCOREdobbinsATmailDOTtdsDOTnet> schrieb im Newsbeitrag
: news:4141cc92$1@news.povray.org...
: > I would like to make it look like there's a slight burn mark
: > on an isosurface object. How would you go about making
: > it look like that?
: Hi,
: i made a small scene with a sphere-iso which has a
: (very simple) symbol dented into it. Is that what
: you had in mind ?
Yes.
: In general i would try to think of a function which
: has positive values where i later want my bumps to
: appear and everywhere else zero (or close to zero).
: Then you have to do a coordinate transformation
: so that your dents appear in the right place with
: the right orientation and scaling.
Ok, I will try.
: In the example i used a kind of 3d-gaussian-bell-
: falloff-function and added four differently placed
: copies of it to the rest of the isofunction.
: If you have a more specific shape in mind, tell me.
: > =Bob Clueless=
: Thies
Thanks! I will try it out!
=Bob=
Date: 11 Sep 2004 11:32:30
Message: <41431a8e@news.povray.org>
Try an image map as a pigment function and use that with your isosurface
function.
Mick
Date: 13 Sep 2004 11:12:01
Message: <4145b8c1@news.povray.org>
"Mick Hazelgrove" <mic### [at] mhazelgrovefsnetcouk> wrote in message
news:41431a8e@news.povray.org...
: Try an image map as a pigment function and use that with your isosurface
: function.
: Mick
Thanks Mick! I will try it.
=Bob=
