POV-Ray : Newsgroups : povray.general : GAH! Media and such Server Time
1 Feb 2026 07:34:19 EST (-0500)
  GAH! Media and such (Message 1 to 10 of 10)
Subject: GAH! Media and such
Date: 22 Jul 2004 16:37:06
Message: <41002572$1@news.povray.org>
Okay, folks... media question:
Apart from being next to impossible to get right, it seems ;) media is
excruciatingly slow to get any decent results out of it. I've noticed
that both intervals and samples can have a drastic effect on things.
Is there any way to get good speed on media?
Ohh, yeh, The "and such":
A winning combination of focal-blur, very small (not micro) normals,
refraction, photons and dispersion is very very slow. ;)
~Mike
Subject: Re: GAH! Media and such
Date: 22 Jul 2004 23:10:07
Message: <4100818f@news.povray.org>
But not so slow you can't bog it down a little more by adding a few area
lights and radiosity!
Don't know how to speed up your media, sorry.
RG - maybe we should have a slowest code contest...
Date: 23 Jul 2004 02:49:40
Message: <4100b504$1@news.povray.org>
I can write a one-line scene that literally takes forever to parse. :)
Tim.
Date: 23 Jul 2004 03:57:00
Message: <4100c4cc@news.povray.org>
>> Tim.
It would have to result in some nice image though (in the end)
Date: 23 Jul 2004 07:37:22
Message: <4100f872$1@news.povray.org>
Haha, I have that too... 2 days and 14 hours so far, and just barely
half through. I keep telling myself it'll be worth it!
Bah...
Heheh... I think I could maybe win hands-down ;)
~Mike
Date: 23 Jul 2004 08:05:02
Message: <4100feee@news.povray.org>
  Don't forget to put 'normal on' in your radiosity block for extra effect.
Also "forgetting" 'adaptive' from the area lights also helps.
Date: 23 Jul 2004 13:06:55
Message: <410145af$1@news.povray.org>
Hash: SHA1
	You are of course using "method 3" in your media?
		Jerome
*      Jerome M. Berger      *
* mailto:jbe### [at] ifrancecom *
*  http://jeberger.free.fr/  *
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.2.4 (GNU/Linux)
iD8DBQFBAUWuqIYJdJhyixIRAno7AJ9WiF8/8+UKwE61abQsitKSWXO0zQCgjtVT
wTHhiDMnVHFhf39G6pDe+yQ=
=eDKa
-----END PGP SIGNATURE-----
Date: 23 Jul 2004 18:20:25
Message: <41018f29$1@news.povray.org>
Yes, I do have method 3 turned on in media. But if my samples aren't
high enough, the clouds look "flat"
Date: 24 Jul 2004 03:35:11
Message: <4102112f$1@news.povray.org>
Hash: SHA1
	What kind of method are you using for your clouds and what kind of
effect are you trying to get? If all you want are scattered clouds,
the best way to do that is to have one container object and one media
for each cloud. If you want a denser cloud cover, you will need a
bigger container object with one media. If the second, you'll
probably notice that as you lower the samples, problems appear first
near the horizon before they appear closer. In this case, you can
lower your sample count and add some transparent objects to force pov
to take more samples near the horizon (and raise the max_trace_level
accordingly, I hope you don't have to many glass objects in your
scene). Another solution is to use megapov 0.7 and the sample_spacing
keyword to do the same thing without needing to raise the max trace.
	Finally, you may want to take a look at Gilles Tran's web site on
clouds:
http://www.oyonale.com/ressources/english/sources13.htm
		Jerome
iD8DBQFBAhEtqIYJdJhyixIRApGWAKCIf+2EUtThszyJACIT8i9KAlG02QCgmUWi
b4ocYiN/qRwT3wlsegdbb+Y=
=Deq3
Date: 24 Jul 2004 03:59:42
Message: <410216ee@news.povray.org>
  That's the default, so there's no need to.
