POV-Ray : Newsgroups : povray.general : Anyone use Povray for things other than making images? Server Time
31 Jul 2024 10:16:44 EDT (-0400)
  Anyone use Povray for things other than making images? (Message 1 to 10 of 20)
Subject: Anyone use Povray for things other than making images?
Date: 24 Jan 2008 19:50:00
Message: <web.47993223f12693de7bcf5ca50@news.povray.org>
I was considering writing a webserver, except I don't know how to suppress all
the text that scrolls by upon program launch.
Subject: Re: Anyone use Povray for things other than making images?
Date: 24 Jan 2008 20:55:51
Message: <479941a7@news.povray.org>
A Webserver made in POV-Ray SDL??
Date: 24 Jan 2008 22:05:01
Message: <web.479951cce9a305467bcf5ca50@news.povray.org>
Sure. A very basic minimal webserver just outputs text in a certain way.
Date: 24 Jan 2008 22:05:40
Message: <47995204$1@news.povray.org>
Nicolas Alvarez escreveu:
>> suppress all
lets give him his deserved geek gold medal... :)
Date: 24 Jan 2008 22:18:30
Message: <47995506@news.povray.org>
>all
You would need to find a version of POV compiled
with the splash removed to suppress all the windows on
your server... I think the Linux version is that way.
For the windows version you could do (from CMD)...
pvengine /EXIT +I"file.pov" -d -ga +W640 +H480
where -d turns off the render preview window,
and -ga turns off the output to the message window,
and set the Options | Other Settings | Use Editor to
off from inside POV to keep the editor from loading
but the splash screen and message startup will still show.
Of course you could set up a virtual PC and allow it
to pop up whatever it wants, since you can hide everthing
anyways. Crashes would be less likely to change anything
important then too.
http://www.microsoft.com/windows/products/winfamily/virtualpc/default.mspx
Date: 24 Jan 2008 22:31:57
Message: <4799582d$1@news.povray.org>
I wasn't aware SDL had the ability to listen on sockets. :-)
     It's not feature creep if you put it
     at the end and adjust the release date.
Date: 24 Jan 2008 23:16:44
Message: <479962ac$1@news.povray.org>
inetd?
Date: 25 Jan 2008 00:25:01
Message: <web.47997225e9a305467bcf5ca50@news.povray.org>
I was hoping not to have to muck around in the source code, but there's no way
to turn off the banner messages without doing so (even on the unix versions). Oh
well.
> >all
> important then too.
Date: 25 Jan 2008 11:23:18
Message: <479a0cf6$1@news.povray.org>
Tim Attwood nous apporta ses lumieres en ce 2008/01/24 22:18:
>> all
> important then too.
The splash only show once. So, after any operation, KEEP POV-Ray up and running.
NO /exit switch!
pvengine +I"file.pov" -d -ga +W640 +H480
or
pvengine /RENDER +I"file.pov" -d -ga +W640 +H480
To the world you may be one person, but to one person you may be the world.
Date: 25 Jan 2008 15:05:09
Message: <479a40f5$1@news.povray.org>
Yes,
For calculations with matrices, polynomials, vectors, complex numbers,
quaternions etc.
Tor Olav
http://subcube.com
