![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Comparing the render time of the same model with versions 3.5 and 3.6 I
always get that 3.6 takes around 30% more time to render than 3.5.
I'm using the Windows version on a P4 2.4GHz with 512MB and I always tested
with files that doesn't need to page memory.
There is anything to tune? Is it normal?
Thx
Groucho
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Could you be a bit more specific?
What kind of scene is it?
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
It happens with all type of scenes but I'll give you an example. It uses
transparencies, only one simple light and radiosity.
global_settings {
assumed_gamma 1.0
radiosity{}
location <0,0,-3>
look_at <0,0,0>
light_source {
<0,0,0>
rgb 1
#declare r=seed(2);
#declare i=0;
#while (i<100)
#declare x1=2*rand(r)-1;
#declare x2=2*rand(r)-1;
#declare x3=2*rand(r)-1;
#declare r1=sqrt(x1*x1+x2*x2+x3*x3);
#if (r1<1)
sphere { <x1,x2,x3> rand(r)*0.2
pigment {rgbt <rand(r),rand(r),rand(r),rand(r)>}
finish { phong 0.2
phong_size 10
ambient 0.05
interior {ior 2}
#declare i=i+1;
Groucho.
"Apache" <apa### [at] hotmail com> wrote in message
news:40d76cae$1@news.povray.org...
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Mon, 21 Jun 2004 23:34:46 +0200, "Groucho" <gro### [at] tripod com> wrote:
Well, "files that doesn't need to page memory" can be something you can think
happen but it can be otherwise. I can easily write scene in a few lines which
needs more memory that all computer I have ever seen had. Size of the scene
file doesn't determine memory usage during rendering.
In the scene you have about 100 spheres all with some transparency. Every
surface on the ray path increases memory usage. Spheres can be overlaped and
bounding hierarchy (something related to raytracing algorithm) can be harder
to walk.
I would do as follow:
1. Turn off transparency and compare speed between versions
2. Turn off overlaping spheres and compare between versions
3. Determine dependency between number of spheres and slowdown.
None of above could be of much help for you but it could give us some overview
what could be problematic. Be sure you use 3.5 and 3.6 under the same
conditions of your OS and be sure that difference is really large. Note that
talking abou difference of 30% in case of 10 second long render is somehow
misleading because there is so many OS related activity that it influence
rendering time. It could be worth to compary some longer renders.
ABX
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I have not done a rigorous test (ie - me with a topwatch
rendering one scene with each version) but I think sometimes
I get a slowdown also ... not all the time though.
I think it's that pesky p4. I have a p4 and they are slower
than an AMD chip running at the same clockspeed. My guess is
that p4s have a sucky floating point implementation.
version 3.5 had some sort of routine for optimization on a
p4. It used to display a line of text every time it
rendered that said something like "SSE2 detected - using
SSE2 optimizations". I don't see this line of text when
rendering with 3.6.
I wonder this also.
>Thx
>Groucho
to all the companies who wait until a large user base becomes
dependant on their freeware, then shafting said happy campers with
mandatory payment for continued usage. I spit on your grave.
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Tue, 22 Jun 2004 13:30:04 GMT, pov### [at] bestweb net almost (povray)
OK. I've since done some testing. Good thing I did because
that statement I made (above) is just *not* correct.
I didn't use a stopwatch but instead used the Total time
displayed by povray. I selected some files and rendered each
file in v3.5 and v3.6 and noted the times. All rendered at
320x240, aa 0.3 ...
file pov 3.5 total pov 3.6 total note
dice_attempt_01.pov 5 min 32 secs 2 min 47 secs rad + pho
function_pigment_speedtest 38 secs 34 secs
krokar_01 51 secs 49 secs rad
sweet_01 1 min 9 secs 1 min 7 secs
(the above needs a normal usenet (ie fixed width) font to view)
In all four renders, 3.6 was faster. The most dramatic performance
increase was when photons and radiousity were both in use.
So even on my sucky P4 CPU, v3.6 is faster. Nice. :)
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <40d83285.3381650@localhost> , povray@bestweb.net.almost (povray)
> rendering with 3.6.
Just because you don't see something like that does not imply it is not
there.
Thorsten
e-mail: tho### [at] trf de
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
On Wed, 23 Jun 2004 19:33:04 +0200, "Thorsten Froehlich"
>> rendering with 3.6.
>there.
Yes! too true! My experiments (after that post)
revealed that! Just color me embarassed. :o
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Watching carefully at your tests, I have understood that the reason why I
get worst results with 3.6 must be out of the pov file. So it must be some
parameter.
The only parameter that I'm using is the antialiasing. And here it is:
ver 3.5 +a0.3: 30 secs
ver 3.6 +a0.3: 30 secs
ver 3.5 +a0.01: 64 secs
ver 3.6 +a0.01: 93 secs
So, antialing management in version 3.6 takes more time than in 3.5.
Does anybody know if at least it works better. I cannot see any difference
in the result.
Cheers,
Goucho
"Groucho" <gro### [at] tripod com> wrote in message
news:40d75460@news.povray.org...
tested
> Thx
> Groucho
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
In article <40dac371@news.povray.org> , "Groucho" <gro### [at] tripod com>
No, we fixed bugs related to antialiasing. It does not take more time
because of any of the changes, it now takes as long as it should always
have.
Thorsten
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
