POV-Ray : Newsgroups : povray.general : show a line in 3D ? Server Time
22 May 2026 08:24:31 EDT (-0400)
  show a line in 3D ? (Message 1 to 10 of 15)
Subject: show a line in 3D ?
Date: 15 Jun 2004 21:20:56
Message: <40cfa078@news.povray.org>
newbe, I have just installed pov ray 3.6 and I seek has to visualize the
line of coordonees x, y, z such as x=y=z somebody can he help me?
I will need the textual file for "run";o)
Subject: Re: show a line in 3D ?
Date: 15 Jun 2004 22:18:02
Message: <40cfadda@news.povray.org>
That particular function (x = y = z) is quite simple; it could be
demonstrated by a thin cylinder from <-100,-100,-100> to <100,100,100>,
which would pass through points like <0,0,0>, <3,3,3>, etc.
If you have more complicated functions that you need to show, then graphing
the solution may be slightly more complex.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 16 Jun 2004 00:32:29
Message: <40cfcd5d@news.povray.org>
Yes ..... But, if you could give the exactly source code of the function, i
just have to run, it would help me to start ;o) Thanks you
news:40cfadda@news.povray.org...
graphing
>  - Slime
Date: 16 Jun 2004 01:40:48
Message: <40cfdd60@news.povray.org>
i
Well, the cylinder that I described is:
cylinder {
<-100,-100,-100>, // starting point
<100,100,100>, // ending point
0.1 // radius
pigment {rgb 1} // white
You'll also need a light source and a camera.
If this is new to you, then I strongly suggest you read the tutorials that
come with POV-Ray. Start by clicking on the button in POV-Ray that says
"Scene", which will bring you to the help files.
 - Slime
Date: 16 Jun 2004 03:25:36
Message: <40cff5f0@news.povray.org>
Thank you, i progress ;o)
news:40cfdd60@news.povray.org...
function,
> i
> cylinder {
> 0.1 // radius
>  - Slime
Date: 16 Jun 2004 15:09:42
Message: <40d09af6@news.povray.org>
Another approach is to use a sphere_sweep. If it is a straight
line then you only need to define the begin and end points.
Here is a POV script to make a line chart. It uses sphere_sweep
to draw lines between points to illustrate changes in the number of
children placed in foster homes (real data). Not elegant POV script
but it works.
Harold
//=========BEGIN POV===============================
//--- POV Ray Line Chart Scene File ---
global_settings { assumed_gamma 2.2 }
#include "textures.inc"
#include "shapes.inc"
// ---------- Lights, Camera, Action -----------
//  Single camera
#declare Camx=-0.1;
 camera {location <Camx, 0.6, -3> look_at <Camx,0.6,0> angle 40}
 light_source { < 10,10,-40> color rgb <1,1,1> }
 light_source { <-30,20,-40> color rgb <0.75,0.75,0.75> }
 light_source { <0.5,10,-12> color rgb <0.55,0.55,0.55> }
background {Black}
// Un-comment the following lines to check parameter values,
//   put the name of the parameter after Str(
//text {ttf  "crystal.ttf",  str(l1P1,8,4), 2, 0 translate <-1,1,-2>
texture{White_Marble}}
//text {ttf  "crystal.ttf",  str(l1P2,8,4), 2, 0 translate <-1,0,-2>
//text {ttf  "crystal.ttf",  str(l1P3,8,4), 2, 0 translate <-1,-1,-2>
//#declare VertScale =  0.03658 ;
// Line for Butte County out of home placements
sphere_sweep {linear_spline 16,
          <-.8, 1.0337, 0>, .01
          <-.7, 1.0155, 0>, .01
          <-.6, 1.0074, 0>, .01
          <-.5, 1.0398, 0>, .01
          <-.4, 1.0196, 0>, .01
          <-.3, 1.0115, 0>, .01
          <-.2, 1.058 , 0>, .01
          <-.1, 1.058 , 0>, .01
          < .0, 1.0721, 0>, .01
          < .1, 1.0742, 0>, .01
          < .2, 1.0984, 0>, .01
          < .3, 1.1065, 0>, .01
          < .4, 1.0863, 0>, .01
          < .5, 1.0519, 0>, .01
          < .6, 1.0438, 0>, .01
          < .7, 1.0641, 0>, .01
       texture {PinkAlabaster}
// Spheres to mark monthly data points
sphere {  <-.8, 1.0337, 0>, .02 texture {PinkAlabaster}}
sphere {  <-.7, 1.0155, 0>, .02 texture {PinkAlabaster}}
sphere {  <-.6, 1.0074, 0>, .02 texture {PinkAlabaster}}
sphere {  <-.5, 1.0398, 0>, .02 texture {PinkAlabaster}}
sphere {  <-.4, 1.0196, 0>, .02 texture {PinkAlabaster}}
sphere {  <-.3, 1.0115, 0>, .02 texture {PinkAlabaster}}
sphere {  <-.2, 1.058 , 0>, .02 texture {PinkAlabaster}}
sphere {  <-.1, 1.058 , 0>, .02 texture {PinkAlabaster}}
sphere {  < .0, 1.0721, 0>, .02 texture {PinkAlabaster}}
sphere {  < .1, 1.0742, 0>, .02 texture {PinkAlabaster}}
sphere {  < .2, 1.0984, 0>, .02 texture {PinkAlabaster}}
sphere {  < .3, 1.1065, 0>, .02 texture {PinkAlabaster}}
sphere {  < .4, 1.0863, 0>, .02 texture {PinkAlabaster}}
sphere {  < .5, 1.0519, 0>, .02 texture {PinkAlabaster}}
sphere {  < .6, 1.0438, 0>, .02 texture {PinkAlabaster}}
sphere {  < .7, 1.0641, 0>, .02 texture {PinkAlabaster}}
// Line for California out-of-home placements
          <-.8, 0.5581, 0>, .01
          <-.7, 0.5568, 0>, .01
          <-.6, 0.5586, 0>, .01
          <-.5, 0.5595, 0>, .01
          <-.4, 0.5585, 0>, .01
          <-.3, 0.5549, 0>, .01
          <-.2, 0.5537, 0>, .01
          <-.1, 0.5540, 0>, .01
          <  0, 0.5534, 0>, .01
          < .1, 0.5576, 0>, .01
          < .2, 0.5531, 0>, .01
          < .3, 0.5503, 0>, .01
          < .4, 0.5519, 0>, .01
          < .5, 0.5493, 0>, .01
          < .6, 0.5518, 0>, .01
          < .7, 0.5499, 0>, .01
       texture {Blue_Agate}
 // boxes to mark monthly data points
box { <-1, -1, -1>, <1, 1, 1> scale 0.02 rotate y*45 translate <-.8, 0.5581,
0> texture {Blue_Agate}}
box { <-1, -1, -1>, <1, 1, 1> scale 0.02 rotate y*45 translate <-.7, 0.5568,
box { <-1, -1, -1>, <1, 1, 1> scale 0.02 rotate y*45 translate <-.6, 0.5586,
box { <-1, -1, -1>, <1, 1, 1> scale 0.02 rotate y*45 translate <-.5, 0.5595,
box { <-1, -1, -1>, <1, 1, 1> scale 0.02 rotate y*45 translate <-.4, 0.5585,
box { <-1, -1, -1>, <1, 1, 1> scale 0.02 rotate y*45 translate <-.3, 0.5549,
box { <-1, -1, -1>, <1, 1, 1> scale 0.02 rotate y*45 translate <-.2, 0.5537,
box { <-1, -1, -1>, <1, 1, 1> scale 0.02 rotate y*45 translate <-.1, 0.5540,
box { <-1, -1, -1>, <1, 1, 1> scale 0.02 rotate y*45 translate <  0, 0.5534,
box { <-1, -1, -1>, <1, 1, 1> scale 0.02 rotate y*45 translate < .1, 0.5576,
box { <-1, -1, -1>, <1, 1, 1> scale 0.02 rotate y*45 translate < .2, 0.5531,
box { <-1, -1, -1>, <1, 1, 1> scale 0.02 rotate y*45 translate < .3, 0.5503,
box { <-1, -1, -1>, <1, 1, 1> scale 0.02 rotate y*45 translate < .4, 0.5519,
box { <-1, -1, -1>, <1, 1, 1> scale 0.02 rotate y*45 translate < .5, 0.5493,
box { <-1, -1, -1>, <1, 1, 1> scale 0.02 rotate y*45 translate < .6, 0.5518,
box { <-1, -1, -1>, <1, 1, 1> scale 0.02 rotate y*45 translate < .7, 0.5499,
// Vertical scale labels
 text {ttf "times.ttf","1.2", 0.5, 0 scale 0.05 texture {PinkAlabaster}
             translate <-0.9 , 1.2 , 0 >}
 text {ttf "times.ttf","1.1", 0.5, 0 scale 0.05 texture {PinkAlabaster}
             translate <-0.9 , 1.1 , 0 >}
 text {ttf "times.ttf","1.0", 0.5, 0 scale 0.05 texture {PinkAlabaster}
             translate <-0.9 , 1.0 , 0 >}
 text {ttf "times.ttf","0.9", 0.5, 0 scale 0.05 texture {PinkAlabaster}
             translate <-0.9 , 0.9 , 0 >}
 text {ttf "times.ttf","0.8", 0.5, 0 scale 0.05 texture {PinkAlabaster}
             translate <-0.9 , 0.8 , 0 >}
 text {ttf "times.ttf","0.7", 0.5, 0 scale 0.05 texture {PinkAlabaster}
             translate <-0.9 , 0.7 , 0 >}
 text {ttf "times.ttf","0.6", 0.5, 0 scale 0.05 texture {PinkAlabaster}
             translate <-0.9 , 0.6 , 0 >}
 text {ttf "times.ttf","0.5", 0.5, 0 scale 0.05 texture {PinkAlabaster}
             translate <-0.9 , 0.5 , 0 >}
 text {ttf "times.ttf","0.4", 0.5, 0 scale 0.05 texture {PinkAlabaster}
             translate <-0.9 , 0.4 , 0 >}
 text {ttf "times.ttf","0.3", 0.5, 0 scale 0.05 texture {PinkAlabaster}
             translate <-0.9 , 0.3 , 0 >}
 text {ttf "times.ttf","0.2", 0.5, 0 scale 0.05 texture {PinkAlabaster}
             translate <-0.9 , 0.2 , 0 >}
 text {ttf "times.ttf","0.1", 0.5, 0 scale 0.05 texture {PinkAlabaster}
             translate <-0.9 , 0.1 , 0 >}
 text {ttf "times.ttf","0.0", 0.5, 0 scale 0.05 texture {PinkAlabaster}
             translate <-0.9 , 0.0 , 0 >}
// Vertical scale lines
sphere_sweep {linear_spline 2, <-.81, 1.2, 0>, .002 < .71, 1.2, 0>, .002
sphere_sweep {linear_spline 2, <-.81, 1.1, 0>, .002 < .71, 1.1, 0>, .002
sphere_sweep {linear_spline 2, <-.81, 1.0, 0>, .002 < .71, 1.0, 0>, .002
sphere_sweep {linear_spline 2, <-.81, 0.0, 0>, .002 < .71, 0.0, 0>, .002
sphere_sweep {linear_spline 2, <-.81, 0.9, 0>, .002 < .71, 0.9, 0>, .002
sphere_sweep {linear_spline 2, <-.81, 0.8, 0>, .002 < .71, 0.8, 0>, .002
sphere_sweep {linear_spline 2, <-.81, 0.7, 0>, .002 < .71, 0.7, 0>, .002
sphere_sweep {linear_spline 2, <-.81, 0.6, 0>, .002 < .71, 0.6, 0>, .002
sphere_sweep {linear_spline 2, <-.81, 0.5, 0>, .002 < .71, 0.5, 0>, .002
sphere_sweep {linear_spline 2, <-.81, 0.4, 0>, .002 < .71, 0.4, 0>, .002
sphere_sweep {linear_spline 2, <-.81, 0.3, 0>, .002 < .71, 0.3, 0>, .002
sphere_sweep {linear_spline 2, <-.81, 0.2, 0>, .002 < .71, 0.2, 0>, .002
sphere_sweep {linear_spline 2, <-.81, 0.1, 0>, .002 < .71, 0.1, 0>, .002
// Month labels ( x axis labels )
text {ttf "times.ttf","Jul-01", 0.5, 0 scale 0.03 texture {PinkAlabaster}
             translate <-0.8-0.03 , -0.05 , 0 >}
text {ttf "times.ttf","Aug-01", 0.5, 0 scale 0.03 texture {PinkAlabaster}
             translate <-0.7-0.04 , -0.05 , 0 >}
text {ttf "times.ttf","Sep-01", 0.5, 0 scale 0.03 texture {PinkAlabaster}
             translate <-0.6-0.04 , -0.05 , 0 >}
text {ttf "times.ttf","Oct-01", 0.5, 0 scale 0.03 texture {PinkAlabaster}
             translate <-0.5-0.04 , -0.05 , 0 >}
text {ttf "times.ttf","Nov-01", 0.5, 0 scale 0.03 texture {PinkAlabaster}
             translate <-0.4-0.04 , -0.05 , 0 >}
text {ttf "times.ttf","Dec-01", 0.5, 0 scale 0.03 texture {PinkAlabaster}
             translate <-0.3-0.04 , -0.05 , 0 >}
text {ttf "times.ttf","Jan-02", 0.5, 0 scale 0.03 texture {PinkAlabaster}
             translate <-0.2-0.03 , -0.05 , 0 >}
text {ttf "times.ttf","Feb-02", 0.5, 0 scale 0.03 texture {PinkAlabaster}
             translate <-0.1-0.04 , -0.05 , 0 >}
text {ttf "times.ttf","Mar-02", 0.5, 0 scale 0.03 texture {PinkAlabaster}
             translate < 0.0-0.04 , -0.05 , 0 >}
text {ttf "times.ttf","Apr-02", 0.5, 0 scale 0.03 texture {PinkAlabaster}
             translate < 0.1-0.04 , -0.05 , 0 >}
text {ttf "times.ttf","May-02", 0.5, 0 scale 0.03 texture {PinkAlabaster}
             translate < 0.2-0.04 , -0.05 , 0 >}
text {ttf "times.ttf","Jun-02", 0.5, 0 scale 0.03 texture {PinkAlabaster}
             translate < 0.3-0.03 , -0.05 , 0 >}
text {ttf "times.ttf","Jul-02", 0.5, 0 scale 0.03 texture {PinkAlabaster}
             translate < 0.4-0.03 , -0.05 , 0 >}
text {ttf "times.ttf","Aug-02", 0.5, 0 scale 0.03 texture {PinkAlabaster}
             translate < 0.5-0.04 , -0.05 , 0 >}
text {ttf "times.ttf","Sep-02", 0.5, 0 scale 0.03 texture {PinkAlabaster}
             translate < 0.6-0.04 , -0.05 , 0 >}
text {ttf "times.ttf","Oct-02", 0.5, 0 scale 0.03 texture {PinkAlabaster}
             translate < 0.7-0.04 , -0.05 , 0 >}
// X axis tick marks
cylinder { <0, 0, 0>, <0, 0.01, 0>, 0.002 texture {Blue_Agate}
             translate <-0.8 , 0, 0 >}
             translate <-0.7 , 0, 0 >}
             translate <-0.6 , 0, 0 >}
             translate <-0.5 , 0, 0 >}
             translate <-0.4 , 0, 0 >}
             translate <-0.3 , 0, 0 >}
             translate <-0.2 , 0, 0 >}
             translate <-0.1 , 0, 0 >}
             translate < 0.0 , 0, 0 >}
             translate < 0.1 , 0, 0 >}
             translate < 0.2 , 0, 0 >}
             translate < 0.3 , 0, 0 >}
             translate < 0.4 , 0, 0 >}
             translate < 0.5 , 0, 0 >}
             translate < 0.6 , 0, 0 >}
             translate < 0.7 , 0, 0 >}
//linder { <0, 0, 0>, <0.007, 0, 0>, 0.002 texture {Blue_Agate}
//           translate < 0.8 , 0.005 , 0 >}
// Declare titles and labels
#declare MainTitle = text {ttf "times.ttf", "Out of Home Placements",
     1, 0  scale 0.10 texture {pigment{color rgb <1.9,1.2,0.15>}}}
#declare SubTitle  = text {ttf "times.ttf", "Butte County and California",
     1, 0 scale 0.06 texture {pigment{color rgb <1.2,1.1,0.05>}}}
#declare footnote  = text {ttf "timesi.ttf",
      "Source: California Department of Social Services, Research and
Development Division",
     1, 0 scale 0.025 texture {PinkAlabaster}}
#declare YLabel  = text {ttf "times.ttf", "Percent of Youth Population",
     1, 0 scale 0.045 texture {PinkAlabaster}}
#declare XLabel  = text {ttf "times.ttf", "",
     2, 0 scale 0.20 texture {PinkAlabaster}}
#declare ZLabel  = text {ttf "times.ttf", "",
     2, 0 scale 0.08 texture {PinkAlabaster}}
//==== Place text in the scene ====
 object {MainTitle translate -x*max_extent(MainTitle).x/2 translate <   0,
1.35, 0.2  > rotate x*-1}
 object {SubTitle  translate -x*max_extent(SubTitle ).x/2 translate <   0,
1.27, 0.23 > rotate x*-1}
 object {footnote  translate -x*max_extent(footnote ).x/2 translate
<-0.6,-0.10, 0.0  > rotate y*0}
 object {XLabel    translate -x*max_extent(XLabel   ).x/2 translate < 2.2, 0
,  0   > rotate y*10}
 object {YLabel    translate -x*max_extent(YLabel   ).x/2  rotate <-8,0,90>
translate < -0.95, 0.6,  0   >}
 object {ZLabel    translate -x*max_extent(ZLabel   ).x/2 translate <
0,-1.47,-4.5 > rotate x*5}
"Slime" <fak### [at] emailaddress> wrote in message
function,
> i
> cylinder {
> 0.1 // radius
>  - Slime
Date: 16 Jun 2004 15:19:32
Message: <40d09d44$1@news.povray.org>
If you try to run that code it may not work because the
text has been wrapped.
For example, this should be on one line and commented
but the mail/news reader has put it on two lines:
To fix you'd need to put "//" before "texture{White_Marble}}"
so POV knows not to parse it as a script line.
H
Date: 17 Jun 2004 14:00:19
Message: <40d1dc33@news.povray.org>
"1ternaut" <ded### [at] sparkwirecom> wrote in message
news:40cfa078@news.povray.org...
Look in povray.text.scene-files for an example scene with documentation
references
 -Shay
Date: 17 Jun 2004 21:50:37
Message: <40d24a6d$1@news.povray.org>
Hi Harold,
you definitely should learn to use while loops,
arrays and macros; I don't think your chart script
is helpful for beginners.
Your code is very edit-unfriendly -- just try to
leave out the first three months and append three
new months at the end. In your script extensive
rearrangements would be required, in my version
below only the data arrays need to be changed.
Or assume you want other symbols for the blue
graph: this would require changing 16 textures.
In my code this is concentrated in a single place:
the declaration of Box, used in the statement
Sweep (CaliData, Box, Blue_Agate)
Of course much more could be done: automatic
adaption to the number of data points and the
number of graphs, automatic determination of the
range of the values and of nice min/max/stepsize
for the y-axis, automatic fitting to the aspect
ratio of the picture, ...
This whole post is a POV-Ray scene file -- just
render it at 800 by 600 with options
// +SP4 +EP4 +GD +A0.3 +AM2 +R3 -FN
to see an almost exact replica of your chart; then
change the macros and have fun!
I hope this didn't sound too rude, but as this was
offered as help to a beginner, I had to react ...
   Sputnik
// ---------- Data -----------
#declare ButteData = array [16] {
  1.0337,
  1.0155,
  1.0074,
  1.0398,
  1.0196,
  1.0115,
  1.058 ,
  1.058 ,
  1.0721,
  1.0742,
  1.0984,
  1.1065,
  1.0863,
  1.0519,
  1.0438,
  1.0641 }
#declare CaliData = array [16] {
  0.5581,
  0.5568,
  0.5586,
  0.5595,
  0.5585,
  0.5549,
  0.5537,
  0.5540,
  0.5534,
  0.5576,
  0.5531,
  0.5503,
  0.5519,
  0.5493,
  0.5518,
  0.5499 }
#declare Months = array [16] {
  "Jul-01",
  "Aug-01",
  "Sep-01",
  "Oct-01",
  "Nov-01",
  "Dec-01",
  "Jan-02",
  "Feb-02",
  "Mar-02",
  "Apr-02",
  "May-02",
  "Jun-02",
  "Jul-02",
  "Aug-02",
  "Sep-02",
  "Oct-02" }
// ---------- macro to draw a data line and symbols -----------
#macro Sweep (DataArray, Symbol, Tex)
  union {
      #local Index = 0;
      #while (Index<16)
        <Index/10-.8, DataArray[Index], 0>, .01
        #local Index = Index+1;
      #end//while
    #local Index = 0;
    #while (Index<16)
      object { Symbol translate <Index/10-.8, DataArray[Index], 0> }
    #end//while
    texture {Tex}
#end//macro Sweep
// ---------- untextured symbols for data points -----------
#declare Sphere = sphere { 0, 0.02 }
#declare Box = box { -0.02, 0.02 rotate y*45 }
// ---------- macro to draw vertical labels and lines -----------
#macro LabelsAndLines (LabelTex, LineTex)
  #local Index = 0;
  #while (Index<=12)
    text {ttf "times.ttf",str(Index/10,3,1), 0.5, 0
      scale 0.05
      texture {LabelTex}
      translate <-0.9, Index/10, 0 >
      <-.81, Index/10, 0>, .002
      < .71, Index/10, 0>, .002
      texture {LineTex}
  #end//while
#end//macro LabelsAndLines
// ---------- macro to make centered text -----------
#macro CenteredText (TTFFont, TextString, Thick)
  #local Txt = text {ttf TTFFont, TextString, Thick, 0 }
  #local Mid = max_extent(Txt)/2;
  object { Txt translate -Mid*x }
#end//macro CenteredText
// ---------- macro to draw months and x-ticks -----------
#macro MonthsAndTicks (MonthThick, MonthTex, TickTex)
  #local Index = 0;
  #while (Index<16)
    object { CenteredText ("times.ttf", Months[Index], MonthThick)
      scale 0.03
      texture {MonthTex}
      translate <Index/10-0.8, -0.05, 0>
    cylinder { 0, 0.01*y, 0.002
      texture {TickTex}
      translate (Index/10-0.8)*x
  #end//while
//  Single camera
#declare Camx=-0.1;
background {Black}
// draw it all (short, readable, editable, isn't it?)
Sweep (ButteData, Sphere, PinkAlabaster)
LabelsAndLines (PinkAlabaster, Blue_Agate)
MonthsAndTicks (0.5, PinkAlabaster, Blue_Agate)
object { CenteredText ("times.ttf", "Out of Home Placements", 1)
  scale 0.10
  translate <   0, 1.35, 0.2  >
  rotate x*-1 // why this?!?
object { CenteredText ("times.ttf", "Butte County and California", 1)
  scale 0.06
  translate <   0, 1.27, 0.23 >
  rotate x*-1
text {
  ttf "timesi.ttf",
  1, 0
  scale 0.025
  translate <-1.05, -0.1, 0>
object { CenteredText ("times.ttf", "", 2)
  scale 0.20
  translate 2.2*x
  rotate y*10
object { CenteredText ("times.ttf", "Percent of Youth Population", 1)
  scale 0.045
  rotate <-8,0,90>
  scale 0.08
  translate <0,-1.47,-4.5 >
  rotate x*5
// ========= That's all =================
Date: 17 Jun 2004 22:59:50
Message: <40d25aa6@news.povray.org>
Here's a simple 3d coordinate symbol; you'll need to change the colors
to something that 's on your system.
//xyz coordinates symbol
//d = diam of 'lines'
//l = length of leg from origin
#macro coordSys(d,l)
   union {
     cylinder {
       <-l,0,0>,<l,0,0>,d
         pigment {color lightRed} finish {flat} //xline
   cylinder {
     <0,-l,0>,<0,l,0>,d
       pigment {color lightGreen} finish {flat} //yline
   cylinder {
     <0,0,-l>,<0,0,l>,d
       pigment {color lightBlue} finish {flat} //zline
