POV-Ray : Newsgroups : povray.general : Can't rotate texture? Server Time
22 May 2026 09:34:46 EDT (-0400)
  Can't rotate texture? (Message 1 to 3 of 3)
Subject: Can't rotate texture?
Date: 24 May 2004 03:49:32
Message: <40b1a90c$1@news.povray.org>
I created a texture to put lighter edges on an object using the slope
pattern. Applied the texture at the origin, but when I rotate the object
into position the texture doesn't rotate with it. Can't create the texture
already rotated because I will have many instances of the object in
different positions.
Is this normal behavior for slope pattern?  I thought that once applied a
texture transforms with the object, no?
Here's a sample scene, how do I make this work?
// slope pattern sample
global_settings{
 assumed_gamma 1
#declare Ft=1;
#declare In=Ft/12;
    location <-3,2.5,-3.5>
    look_at <0,.5,0>
    angle 60
light_source { <-5,15,-15> rgb 1.35 }
light_source { <-10,8,-5> rgb 1.35 }
background { rgb <.5,.6,.7> }
#declare T_Dark_Lite = texture {
        slope -y
        pigment_map {
            [0.00 rgb .15 ]
            [0.20 rgb .95 ]
            [0.80 rgb .95 ]
            [1.00 rgb .15 ]
    finish { ambient 0 diffuse .55 phong .7 phong_size 75 metallic 1 }
#declare W_Rad = 1.55*Ft;
#declare C_Rad = W_Rad*.65;
#declare L_Rad = .85*In;
#declare W_Wid = 2.5*In;
#declare Wheel = difference {
    cylinder { 0 <0,W_Wid,0> W_Rad }
    torus { C_Rad C_Rad*.425 scale <1,.15,1> translate y*W_Wid }
    torus { W_Rad L_Rad scale <1,2.35,1> translate y*W_Wid }
    texture { T_Dark_Lite }
object { Wheel  // as is, texture looks fine
     //rotate -x*90 // after rotate, texture is wrong
// end slope pattern sample
Thanks, RG
Subject: Re: Can't rotate texture?
Date: 24 May 2004 06:05:54
Message: <40b1c902$1@news.povray.org>
I think the slope pattern is indeed rotated, but it does not produce the
effect you expected. No matter the transform applied to it, slope always
compute the value returned with the dot product of the object's normal
and the direction specified. The problem is that the slope's direction
vector does not get transformed. And thus the color repartition after
the transformation does change. This is what is needed most of the time,
when you use slope to mimic a layer deposed on the object, such as snow
on heightfield,...
Even if you rotate the texture at its creation, the results will be the
same.
The only way I can think of, to get the effect you want, would be to
turn your whole texture statement into a macro, with the direction of
the slope as an argument. Then for each object, you could pass a
different direction to this macro, depending on the object's transform.
I have not tested it though, so I cannot assure you it works fine...
Hope this will help
Vincent
Date: 24 May 2004 16:50:00
Message: <web.40b25fbab3392ae9a0c272b50@news.povray.org>
Thanks for the reply. After further experimentation, I think you're right,
the texture rotates but the slope vector doesn't change.
I had also thought of doing it as a macro, but by my understanding of how
textures are stored, that would essentially mean creating a new texture
definition for every object.  As the actual texture I'm using is a lot more
complex than the one in the sample, and since the object is a wheel for a
railroad car, by the time I build a 60 car train I'll be out of memory.
Well, on to plan b...
RG
