POV-Ray : Newsgroups : povray.general : max_trace_level and objects with ior=1 Server Time
22 May 2026 11:06:13 EDT (-0400)
  max_trace_level and objects with ior=1 (Message 1 to 8 of 8)
Subject: max_trace_level and objects with ior=1
Date: 19 May 2004 09:27:26
Message: <40ab60be$1@news.povray.org>
Hello,
  is any way how to not use max_trace_level when object has ior=1? It
can be very useful for scenes where you have for example 200 bitmap
trees on polygons at one side of road and some glass things. When you
set max_trace_level too low, you will get errors at polygons with trees.
When you set max_trace_level to neccesasry value for trees (200, in this
   case and worst camera setttings), the glass will render
unneccessarilly slow.
   I think, that there is no reason why use max_trace_level for objects
with ior=1 and no reflection, because there is no way how to reach
infinite depth of raytracing, as in the case of glass box with ior != 1.
Regads
Vaclav
Subject: Re: max_trace_level and objects with ior=1
Date: 19 May 2004 10:02:02
Message: <40ab68da@news.povray.org>
  Each surface hit and consequent new ray will cause a recursive call.
You don't need an infinite amount of recursions for the program to run
out of stack space: Just put some thousands of transparent surfaces in
a row and trace a ray through them.
  One solution is to use adc_bailout to limit the recursion depth in
glass (supposing the glass filters the rays even a bit).
Date: 20 May 2004 05:46:41
Message: <40ac7e81$1@news.povray.org>
This can be solved by separate max_trace_level for surfaces with ior=1
and no reflection. Also, but this is not so trivial change to POV code,
for such a surfaces there is no need to shoot another ray (but another
way how to deal with scene bounding is needed in this case, all
intersections of objects with ray are neccessary here, not only first
one). It can be also a speedup, I think.
Yes, this is good idea how to solve it without chnaging POV code.
Date: 23 May 2004 14:21:12
Message: <cjameshuff-2470A0.13213823052004@news.povray.org>
In article <40ab68da@news.povray.org>, Warp <war### [at] tagpovrayorg>
Note that this isn't strictly necessary...those intersections have
already been done...when there isn't any refraction, it is possible to
step through transparent layers in sequence. However, POV just finds the
"best" intersection and starts over again. This might make a nice
optimization for media containers or other uses of transparent
non-refracting objects, like lens flares...
http://tag.povray.org/
Date: 24 May 2004 09:06:47
Message: <40b1f367@news.povray.org>
  Wouldn't this kind of optimization mean that POV-Ray would have to keep
all the intersections of a ray and the scene in memory?
  Does it do that already? If yes, I don't understand why. POV-Ray only
uses the closest intersection so why would it need to keep in memory
all the intersections?
  If no, then how would this kind of optimization affect memory consumption
and speed? After all, a ray can intersect the scene in thousand and
thousands of places...
Date: 24 May 2004 13:33:55
Message: <cjameshuff-37F73B.12342224052004@news.povray.org>
In article <40b1f367@news.povray.org>, Warp <war### [at] tagpovrayorg>
No, it doesn't keep all the intersections...that's the point: it
currently throws them away when they could still be useful.
Leading to a few thousand intersections, which really isn't that much
memory. And that's if you don't limit the length of the list.
As for speed...the list can be built in logarithmic time. Repeatedly
doing the intersection tests increases in quadratic time. For 10
surfaces, the last surface is tested 10 times, the one before it 9
times, the one before that 8...if they are all stored in a list, they
are all tested once. And note that the list only has to go up to the
first refracting or opaque intersection, any intersections past that can
be thrown away immediately.
Date: 24 May 2004 14:35:13
Message: <40b24060@news.povray.org>
If you need all the intersections, wouldn't that slow down rendering
of meshes?
  If I'm not mistaken, POV-Ray searches for the closest intersection
with a mesh in a smart way (using the octree subdivision of the mesh),
skipping most of the intersection tests (even for those triangles which
the ray would intersect if there weren't triangles in front of them).
  If you need all the intersections, POV-Ray could not skip testing
those triangles it already knows are behind the closest found.
Date: 24 May 2004 14:47:59
Message: <cjameshuff-0EEB5B.13482524052004@news.povray.org>
In article <40b24060@news.povray.org>, Warp <war### [at] tagpovrayorg>
> of meshes?
No. You only need all the intersections if the mesh is transparent and
non-refracting, otherwise, just grab the first intersection, and if it
comes before the last intersection in the list, use it to terminate the
list. And in the case where all intersections are needed, finding all
intersections at once will still be faster than finding the first
intersection multiple times.
