POV-Ray : Newsgroups : povray.general : merging renders from a cluster Server Time
12 Sep 2025 05:06:10 EDT (-0400)
  merging renders from a cluster (Message 1 to 4 of 4)
Subject: merging renders from a cluster
Date: 13 May 2004 06:39:33
Message: <40a35065$1@news.povray.org>
Greetings,
            I will have to render my next project on a cluster. Is there
anyone out there who has a good trick to merge partial renders
(using -SC0.0 -EC0.05 and so forth...), either under linux or using windows.
            I have been using the old copy and paste when I break the picts
into 4 procs, but this time I will probably need to break it into 16-36
chunks.
Cheers,
Christian
Subject: Re: merging renders from a cluster
Date: 13 May 2004 06:56:35
Message: <k0l6a0dq0troq1ceepj83pgntr74gvapkj@4ax.com>
On Thu, 13 May 2004 07:39:27 -0300, "bongotastic" <cbl### [at] csdalca> wrote:
> Is there
http://www.it-berater.org/smpov.htm
http://www-public.tu-bs.de:8080/~y0013390/povany/
http://pvmpov.sourceforge.net/
http://www.imp.org/
http://astronomy.swin.edu.au/~pbourke/povray/parallel/
http://astronomy.swin.edu.au/~pbourke/povray/gena/
and probably a few others interesting sites
ABX
Date: 13 May 2004 10:11:10
Message: <40a381fe$1@news.povray.org>
Thanks, I must have used the wrong keywords in Google.
"ABX" <abx### [at] abxartpl> wrote in message
news:k0l6a0dq0troq1ceepj83pgntr74gvapkj@4ax.com...
wrote:
> > Is there
windows.
> http://www.imp.org/
> ABX
Date: 13 May 2004 10:12:33
Message: <40a38251@news.povray.org>
>>Is there
> http://www.imp.org/
It is in a very early stage of the development but you could find useful
to check also: http://jcgrid.sourceforge.net/
David Bucciarelli
Pisa
Italy
