POV-Ray : Newsgroups : povray.general : sphere and torus syntax Server Time
2 Mar 2026 07:06:15 EST (-0500)
  sphere and torus syntax (Message 1 to 8 of 8)
Subject: sphere and torus syntax
Date: 14 Apr 2004 14:28:22
Message: <407d82c6$1@news.povray.org>
Just wondering why we cannot state in the definition of a torus it's
"centre" as we do for a sphere?
Is this because the torus does not have a centre as such, but it does have
an origin.
Subject: Re: sphere and torus syntax
Date: 14 Apr 2004 15:32:51
Message: <407d91e3$1@news.povray.org>
> an origin.
The major building parts for a torus are just the major and minor radius. A
box, for example, also has an origin, but you still just position the two
corners. I guess for the sphere, the center position just can easily be
integrated into the solving process, whereas for a torus it would be a
matrix-transformation anway, but that's just an educated guess and may be
incorrect.
"Tim Nikias v2.0"
Date: 16 Apr 2004 07:38:31
Message: <407fc5b7$1@news.povray.org>
> an origin.
You could always write a macro to do that for you.  Or you could
translate it to where you want in the definition.
Date: 17 Apr 2004 17:40:53
Message: <4081a465$1@news.povray.org>
My guess is that a torus requires more parameters anyways compared to a
sphere, so to keep it simple they left out the specifying of an origin
and you use a translate later instead if you need to.
Date: 18 Apr 2004 07:06:39
Message: <4082613f$1@news.povray.org>
> an origin.
I guess it is only because of it has been allways that way. I see no
clever reason why there is not/should be the center parameter. It also
_might_ have to do with the fact that the orientation of a torus is
predefined. If one wanted to rotate torus, it allways has to be first in
the origin.
Severi
Date: 18 Apr 2004 10:20:36
Message: <40828eb4@news.povray.org>
Severi Salminen <sev### [at] not_thissibafi> wrote:
> I see no clever reason why there is not/should be the center parameter.
  I do.
  AFAIK all primitives are created with no transformation matrix by
default. The transformation matrix only slows down the raytracing if
it's unneeded and thus it's not created by default to any primitive.
For instance, a sphere with a center (located anywhere) and a radius
can be raytraced without a transformation matrix.
  Even when you transform a primitive POV-Ray will try to avoid
creating a transformation matrix if it can. For example, if you
translate or scale uniformly a sphere (and probably even when
you rotate it) it will not create a transformation matrix for it
but only modify its center and radius.
  A torus is a quartic. I don't remember if you can specify a location
offset for the torus quartic, but whether or not you can, the torus
implementation was probably designed to be as fast as possible by
not introducing more complexity to the quartic. Thus any transformation
you apply to the torus (even a translate) will generate a transformation
matrix for it. This means that if the torus syntax would have a center
parameter, a transformation matrix would always be created for it.
  Granted, this would probably not matter anything, but the torus
probably just follows the same principle as all the other primitives:
No transformation matrix by default.
  (And no, I haven't checked if it's true that no primitives get a
transformation matrix by default, so I may be wrong here. :) )
Date: 18 Apr 2004 15:27:49
Message: <iul5801r94q455sph8illpec1u35s5bo0m@4ax.com>
>  I do.
There's something about this that certainly sounds right.
My First Subgenius Picture Book:
http://www.imbjr.com
Date: 19 Apr 2004 06:55:14
Message: <cjameshuff-B483C0.06561919042004@news.povray.org>
In article <40828eb4@news.povray.org>, Warp <war### [at] tagpovrayorg>
Cones and cylinders do. It's easier to solve for a cone or cylinder
aligned along an axis, and rotate/translate it into position.
http://tag.povray.org/
