POV-Ray : Newsgroups : povray.general : povray for reflector design? Server Time
1 Feb 2026 17:07:15 EST (-0500)
  povray for reflector design? (Message 1 to 10 of 10)
Subject: povray for reflector design?
Date: 28 Mar 2004 21:29:53
Message: <40678a21$1@news.povray.org>
I am an engineer designing a solar water heater.  The design uses a
reflector to reflect solar energy onto a tank.  I am trying to optimize
the rflector design such that a maximum amount of energy is reflected
onto the tank as the sun position changes throughout the day.  The
reflector under consideration is fixed (non-tracking).
I would like to know if Povray could be useful for modeling candidate
reflector geometries.
For example, if I define a tank object, reflector object(s), and a light
source(the sun), will Povray not only show the light that shines
directly on the tank from the sun, but also show the light that is
reflected onto the tank by the reflector?
If the answer to the question above is true, than I could use a series
of light positions to model the path of the sun through the day, and see
the resulting reflector performance?
I am only interested in seeing the pattern of light that results from
each candidate reflector geometry -- I do not need Povray to show light
intensities that are exactly true to the physics.
As is probably obvious, I don't know much about Povray, but did use it
years ago for a couple problems, and remember being favorably impressed
by its capabilities.  I am hoping that a Povray "guru" can take a quick
look at my problem, and tell me whether its worth relearning enough
Povray to give it a try.
Thanks -- Gary
Subject: Re: povray for reflector design?
Date: 28 Mar 2004 21:40:48
Message: <Xns94BB2F8FA9419raf256com@203.29.75.35>
cre### [at] montanadslnet news:40678a21$1@news.povray.org
Yes,
yes it will, this is done by the Photons special effect.
again yes, You might want to write script to calculate X,Y,Z pozition of
sun, or input data from external file
POV will probably do both things quite accurate
Btw, I'm writting to Yours email from adress - me {at} raf256 [.] com (in
case You are using anti-spam filters etc)
http://www.raf256.com/3d/
Computer Graphics
Date: 29 Mar 2004 07:27:56
Message: <4068164c$1@news.povray.org>
You can use the "sunpos.inc" included in the standard POV distribution.
Laurent ARTAUD (lau### [at] freefr)
Date: 29 Mar 2004 08:18:01
Message: <cjameshuff-581D63.08182729032004@news.povray.org>
In article <40678a21$1@news.povray.org>, Gary <cre### [at] montanadslnet>
It can render an image of the tank with light being reflected onto it.
With some added media, it can show the path the light takes through the
air (the optics.pov sample scene demonstrates this). It can't compute
the actual light intensities though...you can't get the amount of light
that hits the tank as a single numeric value, you get a picture of the
tank. You *could* hack that into the code, but it would require poking
around in the photon code...it'd be easier to write a custom simulation,
patch it into POV as a function and use the scene language as a control
language for it. Be interesting to use a genetic algorithm...
In that case, POV-Ray's photon mapping ought to be sufficient.
http://tag.povray.org/
Date: 29 Mar 2004 08:24:28
Message: <Xns94BB9CAE7F121raf256com@203.29.75.35>
cja### [at] earthlinknet
news:cjameshuff-581D63.08182729032004@news.povray.org
> It can't
> compute the actual light intensities though...you can't get the amount
> of light that hits the tank as a single numeric value, you get a
> picture of the tank. You *could* hack that into the code, but it would
> require poking around in the photon code...it'd be easier to write a
How about - put a camera directly above plane on with rays are reflected,
plane have diffuse 0, it is lighten only by photons, with some camera
tweeking (ortographic) You would probably get imge with intensity map
Computer Graphics
Date: 29 Mar 2004 10:26:46
Message: <cjameshuff-CB4B6B.10271229032004@news.povray.org>
In article <Xns94BB9CAE7F121raf256com@203.29.75.35>,
With high dynamic range output, this could work. However, the clipping
done to images in the official version would throw the results off.
Date: 29 Mar 2004 10:31:49
Message: <Xns94BBB244F753Braf256com@203.29.75.35>
cja### [at] earthlinknet news:cjameshuff-
I suggest rendering 2-3 images with different light_source brighness i.e.
0.01 0.1 and 1
btw some time ago I suggest and float-text format, this is another example
when it could be usable...
Computer Graphics
Date: 29 Mar 2004 13:12:42
Message: <cjameshuff-EFD7C0.13130729032004@news.povray.org>
In article <Xns94BBB244F753Braf256com@203.29.75.35>,
Too bulky. The files would be *big*, and not really any easier to
handle...see the recent debate on XML, text, and binary files for
details.
Date: 29 Mar 2004 13:37:33
Message: <Xns94BBD1C13EBE4raf256com@203.29.75.35>
> details.
But there would be option - text format (with given max. precision) or
binary format (with given format)... I ll tryto make an RFD
Computer Graphics
Date: 30 Mar 2004 08:23:23
Message: <opr5ofiascp4ukzs@news.povray.org>
On Mon, 29 Mar 2004 08:18:27 -0500, Christopher James Huff
Thanks I forgot this scene existed, helped clear up some questions I was
having understanding media, re Scattering media and photons thread in
p.general
Phil
All thoughts and comments are my own unless otherwise stated and I am
happy to be proven wrong.
