POV-Ray : Newsgroups : povray.general : But *how* to do the constant energy solution for particle physics? Server Time
4 Oct 2024 08:18:44 EDT (-0400)
  But *how* to do the constant energy solution for particle physics? (Message 1 to 10 of 17)
Subject: But *how* to do the constant energy solution for particle physics?
Date: 27 Feb 2004 10:13:21
Message: <403f5e91$1@news.povray.org>
Could someone pseudo-code it out for me.
First, I'll share my non-energy conservation system that I used in my
flocking algorithm ( http://www.geocities.com/pterandon/boids.html ), and in
planetary orbiting simulations.
dt=1  (we're stepping along povray frame by povray frame)
p= vector for current position
v=velocity
a=acceleration, or sum of forces at current position (based on gravity of
sun, "repulsion" of neighbors in flock),
----- for each frame----
p2=p1+v1 *dt
a2= constant * (sum of new forces based on new location).
v2=v1+a2
--- repeat ad nauseum ---
As I've shown before, (
http://news.povray.org/povray.binaries.images/thread/%3C3A65E429.18F2DC62%40my-dejanews.com%3E/?ttop=184334&toff=4400
it's impossible to have a "stable orbit" with this because this model
doesn't conserve energy.  I could however probably do a 1-D case for energy
conservation quite easily.
So, in povray, how would one pseudo-code out a model that conserves energy
and accounts for multiple fields (gravity of sun *plus* other planets,
repulsion of *all* neighbors in a flock).
p2=p1+v1 *dt
v2=v1+a2
KE2=constant(vlength(v2)^2)
... I'm stumped.
Subject: Re: But *how* to do the constant energy solution for particle physics?
Date: 28 Feb 2004 05:11:57
Message: <4040696d$1@news.povray.org>
> p2=p1+v1 *dt
> v2=v1+a2
> ... I'm stumped.
I've don't have a real clue on how you might solve this. Some interesting
links while googling where these:
About Energy as a whole, very straightforward and simple:
<http://rabi.phys.virginia.edu/105/2003/ps2s.html>
About some ballmenu for a Website, but right at the end, there's something
about energy conservation:
http://hep.itp.tuwien.ac.at/~ipp/aboutballmenuphysics.html
I'm not all too deep into these energy-theories etc and their scripting. But
if I'm not mistaken, you should just look to it that when two particles
exchange forces, their sum is zero. So, for example, you might just take all
movement vectors, and add them up. If the particles started from a resting
state, then they should add up to zero (unless there are things like
stationary particles or so). The resulting vector is the extra amount of
energy added to the system, and needs to be diminished. In turn, you might
just add a fraction of that vector to every particle, so that, in the end,
you get zero total energy.
But I'm really quiet fuzzy about this all and would just experiment with the
above technique to see if it works. If it doesn't, then google is back! :-)
"Tim Nikias v2.0"
Email: tim.nikias (@) nolights.de
Date: 28 Feb 2004 07:23:30
Message: <40408842@news.povray.org>
> in planetary orbiting simulations.
> v=velocity
> p2=p1+v1 *dt
> v2=v1+a2
Hmm... I thought I had replied to this... Was my post lost somehow? I can't
find it anywhere :/
Well, I'll write it again.
First, shouldn't it be:
  v2=v1+a2*dt ?
Second, as I mentioned, there are several algorithms used for integrating
the equations of motion (that's what you're trying). An algorithm that
minimizes numerical errors is the so-called "velocity Verlet" [Swope et al.
J. Chem. Phys. 76 (1982) 637]:
  Calculate all forces on all particles, for each particle:
    a1 = (total force at p1)/(real or fictitious mass)
1 Calculate new positions for all particles:
    p2 = p1 + v1*dt + 1/2*a1*(dt^2)
  Calculate intermediate velocities (at t1+1/2*dt) for all particles:
    v' = v1 + 1/2*a1*dt
  Calculate all forces on all particles at their new position:
    a2 = (total force at p2)/(real or fictitious mass)
  Caluclate the new velocities for all particles:
    v2 = v' + 1/2*a2*dt
  Goto 1 (p2 -> p1, v2 -> v1, a2 -> a1)
This should conserve energy. What is not conserved is kinetic energy
(temperature). If a simulation at constant temperature is desired, there
are some "tricks" available, the simplest one is just re-scaling all
velocities so that kinetic energy remains constant. After calculating the
new velocities, do:
  f = sqrt(2*Ek/sum(mass*v2^2))
  v2(scaled) = f*v2
where Ek is the desired constant kinetic energy.
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Date: 28 Feb 2004 18:39:31
Message: <404126b3@news.povray.org>
AFAIK there is no simple "energy conservation algorithm".
You and some others around here seem to have the misconception
that the energy of each particle is conserved.
However this is only the case if you only have one central
force (the sun for example), but no additional forces between
your particles (but in this case you would need no numerical
integration at all).
If you have 3 or more particles interacting with forces, only the
sum of the energy of all particles is conserved. So there is no easy
way to use it directly.
Using a better integration algorithm, like runge-kutta, should solve
your problem.
Lutz-Peter
Date: 28 Feb 2004 23:23:24
Message: <4041693c$1@news.povray.org>
First of all thanks Jelby for that link in the other thread.  I went to it,
but it was a program in some other language.  I'm one of those idiots who's
not only unable to program in anything in but povray but also
philosophically chooses to do number crunching in the program. (Yeah, I
know, povray is a raytracer, not a physics software language [take it easy,
McCoy  ]).
I think some of you were answering the question about the conservation of
energy after collisions  based on an entire system of particles, or after a
three-way collision.  Thanks, but that was not actually the problem of my
interest.
When I tried two years ago, I wasn't able to set up a correct model of the
solar system, (perhaps it might help to say to do an "AI" model?),  without
the planets either sinking into the sun or leaving the system altogether.  I
think I tried pretty hard, and i could not find a gravitational constant (or
a sufficiently small time slice) where particles didn't do one or the other.
I was wondering if it were the case that one cannot do it with a computer.
By that I mean that as a travel any finite step obliquely across a gravity
well,  there's a difference between real life and my model.  My model just
re-computes new force at position 2,  whereas a real-life particle would
have the gravity acting on it both "instantaneously" and "continuously".
Someone noted way back then that I wasn't conserving energy. I think others
with nice intentions pointed me to theories that were over my head, and I
suspect, not applicable.
Then I saw the concern in Tim's thread about conserving energy and wondered
if there were some trick.
Jelby, in your second post,  you offer an interesting idea.
But is fundamentally any different from going to a smaller time slice?  And
I was hoping for a solution where dt= one povray frame.
So I'm falling back to three ideas:
1) it is in fact impossible
2) there's some way to do this where you do an actual integration of the
forces as one moves from p1 to p1+v1dt.   I hope I'm not too dense and
haven't missed Jelby explaining exactly how to do this.
3) Perhaps there was an algorithmic error on my part. In my earlier attempt,
http://news.povray.org/povray.binaries.scene-files/thread/%3C3A65E45C.907F6BB7%40my-dejanews.com%3E/?ttop=184097&toff=400
                #declare actorp[n]=actorp[n]+.05*actorv[n];
                #declare actorv[n]=actorv[n]+Grav*(actoravoid[n]);
I was only moving the particles 5 percent of their velocity, because I'd
seen that it made for a smoother curve, and in my head I was thinking it was
like miles/s and the frames were just seconds.  But perhaps I lost
responsiveness (and gained energy loss) from this technique.    I'm doing
some experiments now with this set at 1.0
Thanks for all your consideration and interest.
Date: 28 Feb 2004 23:59:43
Message: <cjameshuff-186E57.00003729022004@news.povray.org>
In article <4041693c$1@news.povray.org>,
> interest.
Any 3-way interaction, actually. Even just gravitational interaction.
There is no way to compute an exact solution for 3 or more
gravitationally interacting bodies. However, you can compute a very
close approximation. I did a simulation (in C++) that was able to
simulate the orbits of the planets from Mercury to Jupiter for several
Jovian years (several dozen Earth years), with very little drift. (I
simply haven't entered the data for the other planets)
There are some rather complex algorithms needed to do this with both
accuracy and efficiency, however. And there will always be cumulative
errors, the simulation will diverge from reality over time, there is no
way around that.
This basically assumes that acceleration will be constant over the time
interval, and takes that into account for the new point. I take it you
were originally using p2 = p1 + v1*dt?
This does give a more accurate result, but is still not exact. You can
get even better results by doing this one step, then backing up and
using the average of the acceleration at the original position and the
first approximation of the new position to compute the real new
position, thus taking into account the fact that the acceleration
changes over the time step. This isn't as good as you can get either,
but it's easy to compute.
That is probably a bad idea. The accuracy of the simulation will then
depend on the number of frames in the animation. You may get very
different results when you do a longer render.
Exact solutions are impossible. "Close enough" solutions are quite
possible.
http://tag.povray.org/
Date: 29 Feb 2004 00:30:30
Message: <404178f6$1@news.povray.org>
Okay cool.
Here's a question related to my ability to detect a "failed model".
Take a "sun".
Take any mass and throw it in any direction not exactly at its center at any
velocity.
If the mass doesn't sink into the sun,  will it:
i)  undertake an "orbit"  "right there" in the sense that it will undertake
an elliptical orbit which intersects that point of release,
OR
ii) will a particle "destined" for a stable orbit sometimes "drift" out
towards the radius of its stable orbit.
I'm ultimately trying to interpret my :
http://news.povray.org/povray.binaries.images/thread/<3A65E429.18F2DC62@my-dejanews.com>/?ttop=184334&toff=4400
If I had  been much, much more patient, might some of those orbits which
looked like they were decaying be just wandering off to something "close
enough" to their own stable orbit?
> possible.
> Christopher James Huff <cja### [at] earthlinknet>
> http://home.earthlink.net/~cjameshuff/
Date: 29 Feb 2004 07:26:10
Message: <4041da62@news.povray.org>
> way around that.
Exactly. In fact, such systems have a chaotic behaviour. By "chaotic" I
don't mean they're undeterministic, but they show a strong dependence on
initial conditions and divergence. If you don't mimic the *exact* initial
conditions and don't solve *exactly* the movement equations, after some
(maybe short) time, the solution you get is completely different from the
real solution. It's the same thing that happens with weather forecast,
although the equations look simpler.
>> And
Yep, like all others this is only an approximation. It is designed to be
cheap in computation power and storage. Position is computed using a simple
second-order approximation. Velocity is computed using a first-order
approximation, but taking the average of the acceleration. There are other
algorithms, called "predictor-corrector", which basically do what you
suggest.
Incidentally, the program I mentioned (Moldy) uses one of these algorithms.
Even if it's written in C(++?), the algorithm is outlined in its manual,
it's worth a look, I believe.
In the field of molecular dynamics, you usually don't store the data every
time-step. To get a precise enough solution you need small dt, but then the
configurations are too similar to be interesting. I'd aim for a frame every
100*dt, more or less, and see what happens.
Date: 29 Feb 2004 11:32:52
Message: <cjameshuff-9D42D1.11334729022004@news.povray.org>
In article <404178f6$1@news.povray.org>,
> Take a "sun".
> velocity.
In a 2-mass system, just the sun and the orbiting mass, it will either
do exactly that or escape the system entirely.
> OR
2 body systems are stable. Maybe you're mistakenly thinking of
elliptical orbits as unstable?
If a 2-body system drifts significantly, it is your simulation which is
unstable. In the real world, none of the planets in our solar system
follow perfect elliptical orbits, and they do drift around and transfer
energy to each other, but the level of instability is too small to
matter. When the sun goes into its red giant stage and swallows up the
inner planets, they will still be in very similar orbits to what they
have today.
The p2 = p1 + v1*dt + 1/2*a1*(dt^2) equation will give a more accurate
simulation than p2 = p1 + v1*dt, but for my simulation of the inner 5
planets, I found it insufficient. The two-step method I described was
sufficient, the simulation was stable for at least several decades
without trying very hard.
Date: 29 Feb 2004 16:09:33
Message: <cjameshuff-173A45.16102829022004@news.povray.org>
In article <cjameshuff-186E57.00003729022004@news.povray.org>,
> possible.
BTW, here's a demo of several different integrators and orbit types:
http://www.princeton.edu/~rvdb/JAVA/astro/galaxy/Galaxy.html
