POV-Ray : Newsgroups : povray.general : [docu] image map properties Server Time
27 Dec 2025 07:50:52 EST (-0500)
  [docu] image map properties (Message 1 to 8 of 8)
Subject: [docu] image map properties
Date: 24 Jan 2004 10:48:39
Message: <401293d6@news.povray.org>
Either I just cannot find it in the docu or it is not there.
povdoc_206.html states for image_map:
IMAGE_MAP:
    pigment
        image_map
            [BITMAP_TYPE] "bitmap[.ext]"
            [IMAGE_MAP_MODS...]
        [PIGMENT_MODFIERS...]
BITMAP_TYPE:
    gif | tga | iff | ppm | pgm | png | jpeg | tiff | sys
IMAGE_MAP_MOD:
    map_type Type | once | interpolate Type |
    filter Palette, Amount | filter all Amount |
    transmit Palette, Amount | transmit all Amount
The following IMAGE_MAP_MODs are recognized by POVRay and not mentioned
in the docu:
    repeat <u,v>
    offset <u,v>
I suggest adding them to the docu together with some explanation on
what they are good for.
Wolfgang
Subject: Re: [docu] image map properties
Date: 24 Jan 2004 12:07:56
Message: <4012a66c@news.povray.org>
In article <401293d6@news.povray.org> , Wolfgang Wieser <wwi### [at] gmxde>
> in the docu:
>     repeat <u,v>
>     offset <u,v>
As there "features" are the result of an apparent accident probably when
merging some ancient MegaPOV sources into 3.5 during its development, it
would be fatal to declare them to official features just because they exist.
Without testing, they should neither be added nor used at all!  Nor should
their design be regarded final or acceptable without review.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 24 Jan 2004 12:22:06
Message: <4012a9bd@news.povray.org>
>> in the docu:
>>     repeat <u,v>
>>     offset <u,v>
> exist.
I see.
The problem is that in order to test them, it would be good to
have some docu which clearly states what they are meant to do.
Otherwise they may end up in being some undocumented secred feature
or people forget about it...
Wolfgang
Date: 24 Jan 2004 12:52:03
Message: <blnae1-dk.ln1@triton.imagico.de>
The interesting thing is that this 'feature' is not in MegaPOV 0.7.
There is 'ImagePhasePatch' which adds frequency and phase keywords for
image_maps but no repeat and offset.
Last updated 11 Jan. 2004 _____./\/^>_*_<^\/\.______
Date: 24 Jan 2004 13:03:39
Message: <4012b37b@news.povray.org>
  Mysterious... Where did these keywords appear? From outer space? :P
Date: 24 Jan 2004 13:40:59
Message: <4012bc3b@news.povray.org>
In article <4012b37b@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
Very good question!  Were they every mentioned anywhere?  I don't recall
ever reading about them.  On the other hand, there had been soooo many
internal discussions about POV-Ray 3.5 features, it is almost impossible to
remember every single one several years later :-)
    Thorsten
e-mail: tho### [at] trfde
Date: 24 Jan 2004 14:15:35
Message: <cjameshuff-7C83D6.14160824012004@news.povray.org>
In article <4012a9bd@news.povray.org>, Wolfgang Wieser <wwi### [at] gmxde>
Well, if they were supposed to be in the public beta, they would have
been documented. Because they weren't supposed to be there, they weren't
documented or tested, and should not be considered to be official
features.
http://tag.povray.org/
Date: 24 Jan 2004 14:56:56
Message: <4012ce08@news.povray.org>
> features.
Well, as every human being tends to make mistakes, wouldn't it be
a probable assumption that they were simply forgot?
Wolfgang
