POV-Ray : Newsgroups : povray.general : Media/Photons/Glass Question Server Time
12 Jun 2026 10:14:53 EDT (-0400)
  Media/Photons/Glass Question (Message 1 to 5 of 5)
Subject: Media/Photons/Glass Question
Date: 5 Jan 2004 20:31:54
Message: <3ffa100a@news.povray.org>
I'm having some difficulty with scattering media:
The first problem has to deal with if I have spotlights instead of point
lights, the media turns to random noise.
The second problem is, When I get the scattering media just right, when I
wrap the object in a glass, it seems darker than it was.
The third problem, after compensating for the first problem, When photons
are turned on, it's either too dark or totally washed out and tends to look
a bit splotchy.
My current photons setup is as folows:
            photons
                spacing 0.05
                media 100
Any ideas?
Subject: Re: Media/Photons/Glass Question
Date: 6 Jan 2004 04:23:39
Message: <3ffa7e9b$1@news.povray.org>
"Michael Raiford" <mra### [at] hotmailcom> wrote in message
news:3ffa100a@news.povray.org...
Join the club ;) - media, particularily when you start mixing it with other
special effects, such as photons, can be tricky to get right.
Could you post a more complete scene? (not necessarily your actual scene - just
a simplified version but showing the problem).
Date: 6 Jan 2004 07:50:02
Message: <web.3ffaae78f47417fcf5476c680@news.povray.org>
I think I might have it close to where I want it. I'll post the scene
file(s) when I get home tonight.  I lowered the spacing on the photons
(afer adjusting my swapfile size so POVRay can take up about 300M of
memory), and it looked much closer to what I wanted, but if I'm able to get
any more tips for how to get it to look even better, then that's great.
It's spread across a few includes at the moment, and I have no problem
sharing what I have (I intend to post the includes I'm creating when they
are finalised on my website anyway).
Date: 6 Jan 2004 08:39:52
Message: <cjameshuff-C87C34.08395306012004@netplex.aussie.org>
In article <3ffa100a@news.povray.org>,
Increase the number of samples. You're just not using enough samples to
accurately render the variation in lighting from the spotlights.
You excluded the media from the area of the object by putting a
non-hollow object around it. Or there's something odd with the texture
you're using.
> a bit splotchy.
It gets dark when photons are on because the shadow of a transparent
object is then illuminated only by photons, light no longer passes
directly through the glass. In real life, the shadow is also illuminated
by diffusely scattered light and by other light sources, in POV-Ray you
can use radiosity and multiple light sources to get more accurate
lighting.
You'll need to post more of the scene to get more detailed help...
http://tag.povray.org/
Date: 6 Jan 2004 20:58:56
Message: <3ffb67e0@news.povray.org>
I've zipped-up the scene and posted it on p.b.sf, as well as the current
progress of the image (rendering is very slow: 12hrs and only half done.)
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3ffa7e9b$1@news.povray.org...
other
just
