POV-Ray : Newsgroups : povray.general : Unconvincing TV raster texture using existing PNG Server Time
20 Apr 2026 07:33:21 EDT (-0400)
  Unconvincing TV raster texture using existing PNG (Message 1 to 4 of 4)
Subject: Unconvincing TV raster texture using existing PNG
Date: 26 Nov 2003 18:01:26
Message: <3fc530c6@news.povray.org>
Here it is.  Any improvements?
#declare slidetext1=
        texture{ pigment{image_map {png "mimeslide020593.png" map_type 0
once }}finish{ambient .4 diffuse 0}}
        texture{pigment{rgbf <1,1,1,1>}}
#declare slidetext2=
once }}finish{ambient <1,3,1> diffuse 0}}
    box{<0,0,-0.0001>,<1,1,-0.0002>
        texture{
                gradient y
                texture_map{
                        [0.25 slidetext1]// finish{ambient rgb<1,1.5,1>}]//
pigment{rgbf <1,1.0,1,0.95> } ]
                        [0.25 slidetext2]// finish{ambient rgb
100}]//<1,0.5,1>}]// pigment{rgbf <1,1.0,1,0.95> } ]
                        //[0.25 pigment{rgbf <1,26.0,0,0.95>}]
                        frequency 50                        }
        scale 400
        translate 600*z}
Subject: Re: Unconvincing TV raster texture using existing PNG
Date: 26 Nov 2003 23:35:01
Message: <web.3fc57e3e518574243a5fb9ba0@news.povray.org>
I'm trying to come up with a way to make a pre-existing image show up on a
TV screen in my image with some sort of distortion.  All the ideas I can
come up with make it look like the people are hiding behind a fence instead
of duplicating a gross rastered effect.
Any tips from those who have mastered this effect?
Date: 27 Nov 2003 23:48:51
Message: <3fc6d290.3794444@localhost>
On Wed, 26 Nov 2003 18:01:27 -0500, "Greg M. Johnson"
	I could not get this to work.  Hoever, if by
TV, you mean that scanline effect, try this:
---- cut here ---- save as a pov file ----
/* best render this with no anti-aliasing at all! */
/* it is assumed that the input image aspect ratio
   and the output image aspect ratio are identical */
#version 3.5;
global_settings {
  assumed_gamma 2.2 // set same as your display_gamma setting
  noise_generator 1
  orthographic
  location 0
  direction <0, 0, 1>
  right <1, 0, 0>
  up <0, 1, 0>
  translate <0, 0, -10>
#declare pic_pig = pigment {
  image_map {
    sys "screen.bmp" // your image here
    interpolate 2 // or not
  translate <-0.5, -0.5, 0>
#declare scanline = pigment {
  average
  pigment_map {
    [ 1 pic_pig ]
    [ 1 color rgb 0 ]
plane {
  <0, 0, -1>, 0
    gradient <0, 1, 0>
    frequency (image_height / 2) // the trick
    pigment_map {
      [ 0.5 scanline ]
      [ 0.5 pic_pig ]
  finish { ambient 1 diffuse 0 }
/* actual end of this file */
---- cut ----
	For a neat trick, render this at different
sizes and see what happens (or rather, what does not
happen) to the size of the scanlines
Peter
Date: 28 Nov 2003 21:49:08
Message: <3fc80924@news.povray.org>
AVERAGE!!
Of course, thank you.
