POV-Ray : Newsgroups : povray.general : POV crash with functions Server Time
22 May 2026 21:23:29 EDT (-0400)
  POV crash with functions (Message 1 to 10 of 15)
Subject: POV crash with functions
Date: 10 Nov 2003 14:30:06
Message: <3fafe73e@news.povray.org>
I tried to post this message three times in P.bugreports and it didn't
work, sorry if I'm multiposting.
So I wrote the following:
#macro F_Plane ()
   #local fn_p=function (x,y,z) { y };
   fn_p
//  function (x,y,z) { fn_p (x,y,z) }
#local F1= F_Plane();
#declare fn_crash = function(x,y,z) { F1(x,y,z) }
and got a POV access violation (official Win32 POV (MegaPOV crashes
too)). Commented code is a workaround.
I hope that helps,
JC
Subject: Re: POV crash with functions
Date: 10 Nov 2003 15:12:02
Message: <c08581-a4b.ln1@triton.imagico.de>
povray.bugreports is moderated, postings will only occur there if it is
a confirmed bug.
> #macro F_Plane ()
>   fn_p
> #end
It should not crash of course but your code isn't valid syntax, it can't
work.
Last updated 25 Oct. 2003 _____./\/^>_*_<^\/\.______
Date: 10 Nov 2003 15:40:07
Message: <3faff7a7@news.povray.org>
> work.
  I have to admit that I'm not sure why it's not valid syntax... (Perhaps
you should have specified why? :) )
Date: 10 Nov 2003 16:10:00
Message: <web.3faffdc7cd1be767d6c93cf30@news.povray.org>
>#macro F_Plane ()
>   fn_p
>#end
>I hope that helps,
>JC
FYI
I tried the code as provided on Windows XP Professional, and received the
same error.
Date: 10 Nov 2003 16:32:19
Message: <3fb003e3@news.povray.org>
I can confirm the access violation using the above code with both
official WinPOV 3.5 and MegaPOV 1.0 on WindowsME.
HTH,
Florian
//=================[web: http://www.torfbold.com]==================\\
#local a=-5;#while(a<5)sphere{<sin(a*pi)*5a*10pow(a,5)*.01>sin(a*a*a*
.1)+1pigment{rgb 9*z}}#local a=a+.01;#end camera{look_at-y*10location
<8,-3,-8>*10}// [www.povray.org]     [www.imp.org]     [www.irtc.org]
Date: 10 Nov 2003 16:52:02
Message: <ehd581-m2l.ln1@triton.imagico.de>
>>work.
Are you serious?
#local F1= fn_p;
Date: 10 Nov 2003 17:00:00
Message: <3fb00a5f@news.povray.org>
> Are you serious?
> #local F1= fn_p;
  Sorry, but I still don't see it. Perhaps I'm unusually dumb today.
  The only thing which I can think of is that you can't create an
identifier and directly assign a function to it (ie. #local F1 = fn_p;),
but if that's so, it's illogical and works differently from any other
identifier type.
  (Compare it to this: You have a #local A = sphere { 0,1 }; and
then you can do #local B = A; and you don't have to do it like
#local B = object { A };)
Date: 10 Nov 2003 17:52:02
Message: <d5h581-cts.ln1@triton.imagico.de>
> identifier type.
This is to make it easy to distinguish between function calls and
function declarations:
#local X=function (Y) { Y }
#local Y=0;
#local Val1=X(0);
#local Val2=X(Y);
#undef Y
#local Fn1=function (Y) { X(Y) }
I assume it would be possible to allow the '#local B = A' form for
functions as well (although it might be difficult to implement) but
possibilities for obfuscation are already sufficient IMO.
Date: 10 Nov 2003 19:15:26
Message: <3fb02a1e@news.povray.org>
In article <3faff7a7@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
>> work.
A local function is returned by value.  However, you cannot return a
function by value, you can only return a function result by value.  So after
the parser notices that this is a function assignment, it attempts to assign
it, but does of course fail because by the time it can notice, the macro has
already been left and the function no longer exists.  The reason is that
functions are not copied like other identifiers, but referenced (even if it
would be copied, the problem would remain to decide whether to copy or
evaluate).  However, the parser cannot decide what to do prior to leaving
the macro either.  Hence, this syntax cannot legal.
That said, I have no good idea how to tell the parser to detect such a case
yet (without some brain-dead ugly hack, of course).  Most likely this
problem will persist until POV-Ray 4.0.
    Thorsten
e-mail: tho### [at] trfde
Date: 10 Nov 2003 19:21:13
Message: <3fb02b79$1@news.povray.org>
In article <3fafe73e@news.povray.org> , "JC (Exether)" <no### [at] spamfr> wrote:
> #macro F_Plane ()
>    fn_p
> #end
This isn't legal syntax and POV-Ray cannot currently detect this properly.
To do what you want, use #declare instead of #local like this:
#macro F_Plane ()
   #undef fn_p
   #declare fn_p=function (x,y,z) { y };
   fn_p
    Thorsten
