POV-Ray : Newsgroups : povray.general : Announce Virtual Choreographer 0.1 Server Time
4 Oct 2024 18:15:43 EDT (-0400)
  Announce Virtual Choreographer 0.1 (Message 1 to 4 of 4)
Subject: Announce Virtual Choreographer 0.1
Date: 1 Oct 2003 11:30:30
Message: <3f7af316@news.povray.org>
Virtual Choreographer is a specification language and a tool for
modeling and animating graphical and sonic objects.
     It is currently designed to render graphical elements with OpenGL
(for interactive rendering), and POVray and Renderman (for off-line
rendering). Sound rendering is designed for communication with Max
patches, whatever the platform (currently PureData, JMax, and Max/MSP
are used).
     Source files and samples at:
http://www.limsi.fr/Individu/jacquemi/VirChor/index.html
     Film rendered with POVray:
http://www.limsi.fr/Individu/jacquemi/SCEINES/
Subject: Re: Announce Virtual Choreographer 0.1
Date: 4 Oct 2003 10:31:18
Message: <3f7ed9b6@news.povray.org>
de news: 3f7af316@news.povray.org...
Looks promising! I downloaded it and tried to compile it on a Debian PPC
linux of mine.
I ran into the following troubles :
missing packages: I had to install the following packages (Did I say I love
the Debian packaging system ?)
mesag3
glutg3-dev
libtiff-dev
libjpeg-dev
Build Problems:
1)  I ran into an automake/autoconf problem that seems to be related to the
autotools version :
    During the automake phase, it aborts with "AC_Dest macro undefined", at
the AC_OUTPUT macro in configure.in.
Workaround :
 in configure.in, changed AC_OUTPUT( <file1> <file2> ...)
 with
  AC_CONFIG_FILES(<file1>)
  AC_CONFIG_FILES(<file2>) ...
  AC_OUTPUT
2) fr-sound.cpp -> gcc aborts due to isdigit() : missing #include <ctype.h>
3) link phase: -L/usr/X11R6/lib was missing in the "libtool mode=link"
command
4) After installation, and downloading Spheres.conf & Spheres.xml, when I
launch VirChor
I get :
 Loading Spheres.conf
 Aborted
Any thought ?
Pascal.
Date: 8 Oct 2003 16:55:02
Message: <web.3f84791b110aeeefb2f73030@news.povray.org>
>linux of mine.
Thank you so much Pascal for your help. I will make the
suggested changes to the configure.in file.
>mesag3
>glutg3-dev
>libtiff-dev
>libjpeg-dev
One of my former colleague (Nicolas Sabouret) is a Debian
developper... I know that package updating is very easy
with Debian.
>Build Problems:
>autotools version :
>Workaround :
> with
>  AC_OUTPUT
>command
>launch VirChor
>I get :
> Aborted
Strange. It looks like if you had an incorrect character at the
end of the Spheres.conf file. I assume that it could
come from the Mac character encoding in which the end-of-file
character has a different value different from PC linux systems
(DOS encoding also works fine). Could you send me by email
the Spheres.conf and Spheres.xml files so that I can test
them on my PC (mailto:Chr### [at] limsifr).
Did you edit and saved these files before using them?
About PPC, a friend of mine has been able to compile VirChor
directly in MacOSX and make it run on the sample files.
I can suggest him to write a short notice on how he
managed to compile the application if you wish.
You can also use an empty file for Spheres.conf. You will not
get the expected result because you will get all the default
presets of the parameters. But it works. I have just checked it.
If such a message happens with the xml file,
I would suggest to change the value of the attribute
trace_input_file of the <trace> tag to "true" in the
configuration file (Spheres.conf):
<trace trace_input_file="true" ....etc.
You will get a trace of the input file on the standard output
and check where the parsing problem occurs.
I hope it helps.
Sorry for my late reply. And thanks again.
-Christian
Date: 9 Oct 2003 03:10:02
Message: <web.3f850988110aeeefb7b590890@news.povray.org>
>Workaround :
> with
>  AC_OUTPUT
I made these modifications on my Mandrake distribution and
it does not work. I will investigate more on this.
changed.
>command
I think I changed it, not sure.
>launch VirChor
>I get :
> Aborted
I think I found the problem: char comparison with EOF
does not work on PPC. I have transformed all the char types
into int. Should work properly now.
http://lists.debian.org/debian-devel-announce/2002/debian-devel-announce-200201/msg00008.html
Could you please try again and let me know, new distrib
is online at
Thank you again for your comments.
-Christian
Message: <web.3f84795c110aeeefb2f73030@news.povray.org>
>linux of mine.
>mesag3
>glutg3-dev
>libtiff-dev
>libjpeg-dev
with Debian.
>Build Problems:
>autotools version :
>Workaround :
> with
>  AC_OUTPUT
>command
>launch VirChor
>I get :
> Aborted
I hope it helps.
-Christian
Date: 9 Oct 2003 03:15:02
Message: <web.3f8509c0110aeeefb7b590890@news.povray.org>
>Workaround :
> with
>  AC_OUTPUT
changed.
>command
>launch VirChor
>I get :
> Aborted
is online at
-Christian
