POV-Ray : Newsgroups : povray.general : Feature question Server Time
22 May 2026 22:34:06 EDT (-0400)
  Feature question (Message 1 to 10 of 10)
Subject: Feature question
Date: 29 Sep 2003 09:28:45
Message: <3f78338d$1@news.povray.org>
IIRC, we could with an earlier version of POV-Ray place command line
options within the scene file. I'm curious why this feature was removed,
or if it never existed, why it does not. This would be nice for those of
us using editors besides POV-Win.
 -Shay
Subject: Re: Feature question
Date: 29 Sep 2003 09:37:51
Message: <0ucgnv8qrdk01tuv4b2hma6fbja83mt8uk@4ax.com>
On Mon, 29 Sep 2003 08:28:44 -0500, "Shay" <sah### [at] simcopartscom> wrote:
You probably mean "ini_option" feature of old MegaPOV. There were reasons
(enumerated a few times) why it wasn't implemented in POV-Ray
(http://news.povray.org/povray.unofficial.patches/6592/). Note that, solution
with command-line within GUI is not reserved for POV-Win, see:
http://pyvon.sourceforge.net/
ABX
Date: 29 Sep 2003 10:13:18
Message: <3f783dfe@news.povray.org>
  You remember wrong. No official version of POV-Ray has ever supported this.
Date: 29 Sep 2003 10:43:32
Message: <3f784514$1@news.povray.org>
"ABX" <abx### [at] abxartpl> wrote in message
news:0ucgnv8qrdk01tuv4b2hma6fbja83mt8uk@4ax.com...
Thank you, ABX, and, yes, Warp, you are correct. I realized my mistake
when reading through the threads posted by ABX. I did try Pyvon this
weekend, but had some problems. I posted these problems in p.unix for
Fabien.
 -Shay
Date: 29 Sep 2003 11:43:28
Message: <3f785320$1@news.povray.org>
In article <3f78338d$1@news.povray.org> , "Shay" <sah### [at] simcopartscom> wrote:
You never could.  You could in some old version of MegaPOV
It was not added to POV-Ray 3.5 because it fundamentally breaks the way
POV-Ray works and exposed a lot of things to users they should not have
access to.  In particular, the rules which options would be allowed and
which were not allowed.  It also made the files uncontrollable by INI files.
In short, it caused only problems.
    Thorsten
e-mail: tho### [at] trfde
Date: 29 Sep 2003 13:44:02
Message: <3F786F57.3050804@hotmail.com>
Not for me it didn't. The ini_option feature allowed me to switch
between dissimilar types of scene files(e.g. a height_field data file
and a scene file using a the height_field).... without ever having to
screw with the command line.
It seems to me, a simple toggle can be placed somewhere allowing the
ini_option feature to be activated.... for those of us who like to use
it. It could be off by default.
Samuel Benge
stb### [at] hotmailcom
Date: 29 Sep 2003 18:18:03
Message: <3f78af9b@news.povray.org>
In article <3F7### [at] hotmailcom> , Samuel Benge
That doesn't say anything the feature having problems, only that you never
saw a problem when using it.  And you didn't see a problem because you never
tried to use it in every possible way; if it had been included in an
official version, all the bugs it had would have had to be fixed, and some
are unfixable due to what the feature does (or would require POV-Ray to do)
is, well, impossible.  But all this has been discussed before...
    Thorsten
Date: 30 Sep 2003 12:20:34
Message: <3F79AD47.3040301@hotmail.com>
Oh well. That's okay. I can just store the ini options as commented code
and paste them into the command line as needed.
Samuel Benge
Date: 30 Sep 2003 12:36:48
Message: <3f79b120$1@news.povray.org>
news:3F7### [at] hotmailcom...
Note that the Windows version has a feature to do that.
See manual 1.10.11.3.4  Copy "..." to Command-Line
Just right click on a comment that looks like a command line and choose from
the menu.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 30 Sep 2003 17:51:51
Message: <3F79FAEC.8090400@hotmail.com>
Thank you! Works like a charm :)
> the menu.
> G.
Samuel Benge
