POV-Ray : Newsgroups : povray.general : selecting several thousand lines in pov file Server Time
31 Mar 2026 09:54:53 EDT (-0400)
  selecting several thousand lines in pov file (Message 1 to 10 of 35)
Subject: selecting several thousand lines in pov file
Date: 16 Sep 2003 09:20:26
Message: <3f670e1a$1@news.povray.org>
Is there an easier way to do this? I have about 9,000 lines, one of several
mesh2 objects, in a pov file, that I want to select in order to copy and
paste to another pov file, which also contains several mesh2 objects. The
only would I know to do this is to start selecting and scroll, and scroll,
and scroll.......and scroll until an eternity later I finally have the whole
thing selected. It seems like one ought to be able to tell Povray to "select
from line 8605 to line 17361" and it would be done, but I can't find any way
to do that, nor can I find anything in the documentation about it. Am I
stuck doing it the hard way?
Steve Shelby
Subject: Re: selecting several thousand lines in pov file
Date: 16 Sep 2003 09:29:38
Message: <3f671042@news.povray.org>
Steve Shelby wrote:
> Hi,
> thing selected.
If I'm understanding what you're asking, how about this? Select the first
line, then page/scroll down until you find the last line, and SHIFT-click on
the last line. This should select everything between the two points.
Hope this helps.
Date: 16 Sep 2003 09:34:11
Message: <3f671153$1@news.povray.org>
Steve,
That's what I'm doing now. The problem is that it takes 5-10 minutes to
scroll down that many lines.
Steve
"Steve Martin" <ecp### [at] bellsouthnet> wrote in message
news:3f671042@news.povray.org...
on
> Hope this helps.
Date: 16 Sep 2003 09:41:49
Message: <144emv44qg57n5inl0fjpkc6f52le1acl5@4ax.com>
On Tue, 16 Sep 2003 08:20:24 -0500, "Steve Shelby" <ssh### [at] rexnetnet> wrote:
> Hi,
You can do this in general way applying method like in... CSG object.
Applying intersection can be replaced with applying difference if you
understand what I mean :-)
BTW: what about asking gui specific question in gui specific group ?
ABX
Date: 16 Sep 2003 10:39:11
Message: <3f67208f@news.povray.org>
  If you grab the scrollbar at the right and drag it down, it shouldn't
take too much. That's what the scrollbar is for.
Date: 16 Sep 2003 11:37:02
Message: <3f672e1e$1@news.povray.org>
If the file is very large it is difficlt to do this accurately.  One
thing I try is to devise a strategy where I select off the topmost block
and either delete it or copy it.  That way I can use the Find to get to
the middle point, mark it then 'scroll bar' quickly to the top and Shift
click there to select the block.
Date: 16 Sep 2003 12:25:29
Message: <jrdemv8brfoighaectslio426naeab03e9@4ax.com>
In case you didn't here is sequence of keys needed to cut lines from 8605 to
17361 within POV-Ray for Windows editor assuming your file is open and active
Ctrl+G
      8
       6
        0
         5
          Enter
               Shift+Ctrl+Home
                              Del
                                 Ctrl+G
                                       8
                                        7
                                         5
                                          6
                                           Enter
                                                Shift+Ctrl+End
                                                              Del
where 8756 is 17361-8605 :-)
ABX
Date: 16 Sep 2003 12:54:59
Message: <3f674063$1@news.povray.org>
Wouldn't it be easier to just put the several thousand lines
in a separate .inc file?  Then you only need to move one line
in the .pov file. ;)
Date: 16 Sep 2003 13:20:31
Message: <jerry-C52202.10202816092003@netplex.aussie.org>
In article <3f670e1a$1@news.povray.org>,
>Hi,
>Steve Shelby
#!/usr/bin/perl
while ($ARGV[0] =~ /^-(start|end)=([0-9]+)/) {
   $cmd = $1;
   $number = $2;
   if ($cmd eq 'start') {
      $startline = $number;
   } else {
      $endline = $number;
   shift;
while (<>) {
   $line++;
   print if ($line >= $startline && ($endline<= 0 || $line <= $endline));
Save it as "clip" and ensure however you do so for your OS that it is
executable.
Use as (on Unix)
clip -start=xx -end=xx filename
On Mac OS X, for example, I might use:
clip -start=8605 -end=17361 meshes.pov | pbcopy
And then I could paste those lines into another document.
On Linux, I might use:
clip -start=8605 -end=17361 meshes.pov > wantedmeshes.pov
to put those lines into a file called "wantedmeshes.pov"
I don't know the syntax for using perl on Windows, but it would probably
be similar.
Leave out -start to start at the beginning, and leave out -end to go to
the end. You can do multiple files, but it will start counting from the
first file and continue on counting through subsequent files, which
probably isn't generally what you want.
Jerry
"Give a man a fish and you feed him for a day. Teach him to fish, and you've
depleted the lake."--It Isn't Murder If They're Yankees
(http://www.ItIsntMurder.com/)
Date: 16 Sep 2003 14:33:47
Message: <3f67578b@news.povray.org>
news:3f670e1a$1@news.povray.org...
Copy the file into a spreadsheet (e.g. Excel), do the job there and copy the
result back.
Actually I often use Excel for this sort of job.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
