POV-Ray : Newsgroups : povray.general : Black and white sky through transparent object Server Time
2 Mar 2026 21:27:32 EST (-0500)
  Black and white sky through transparent object (Message 1 to 4 of 4)
Subject: Black and white sky through transparent object
Date: 4 Sep 2003 22:59:23
Message: <3f57fc0b@news.povray.org>
I created a window with a rgbf  pigment.  When look at the window straight
on the sky is correct, but at an angle the sky is balck and white.
Does anybody know the reason for this problem and a correction for it.
Ky
Subject: Re: Black and white sky through transparent object
Date: 4 Sep 2003 23:33:38
Message: <3F5803C3.6804488A@pacbell.net>
From your description it would be difficult to diagnose without seeing
some of your source code that would illustrate the problem.
You might try adding:
global_settings { max_trace_level 5 }
to your scene file and see if that fixes your problem.
Ken Tyler
Date: 5 Sep 2003 17:47:38
Message: <3f59047a$1@news.povray.org>
"Ken" <tyl### [at] pacbellnet> wrote in message
news:3F5803C3.6804488A@pacbell.net...
straight
> Ken Tyler
Max-trace_level 5 didn't work but anything above 6 did.
Thanks
Date: 5 Sep 2003 18:01:45
Message: <3f5907c9$1@news.povray.org>
Well, max_trace_level 5 is actually the default,
so just specifying wouldn't help. Naturally, 6
is one level further and improves black areas,
unless they are produced by even more
raytracing depth of reflections/transmission/refractions.
Just 2 cents.
Tim
Tim Nikias v2.0
Email: tim.nikias (@) gmx.de
> straight
> > Ken Tyler
> Thanks
Version: 6.0.515 / Virus Database: 313 - Release Date: 01.09.2003
