POV-Ray : Newsgroups : povray.general : why the hexgrid constants? Server Time
12 Jun 2026 17:16:46 EDT (-0400)
  why the hexgrid constants? (Message 1 to 8 of 8)
Subject: why the hexgrid constants?
Date: 23 Aug 2003 01:12:02
Message: <3f46f7a2@news.povray.org>
7.4.5 Focal blur hexgrid constants
Hex_Blur1 = 7
Hex_Blur2 = 19
Hex_Blur3 = 37
I have two questions about this:
1. What are they used for?
2. I'd like to know how I might calculate Hex_blur4, Hex_blur5 etc etc
3. When using focal blur, does blur_samples 8 look worse blur_samples 7?
Apache
Subject: Re: why the hexgrid constants?
Date: 23 Aug 2003 02:24:33
Message: <3f4708a1@news.povray.org>
> Hex_Blur1 = 7
> Hex_Blur2 = 19
> Hex_Blur3 = 37
I don't know what they are, but I used my TI-86 to find that the points
(1,7), (2,19) and (3,37) fit on the curve y = 3x^2 + 3x + 1 where x
would be the x in Hex_Blurx and y would be the constants.
According to the above equation, Hex_Blur4 would be 61, Hex_Blur5 would
be 91 and Hex_Blur6 would be 127.
I used the quadratic fit because it gave 7, 19 and 37 extactly.  The
other fits like linear and logrithimic gave correlations of .99 or .97.
Brendan
Date: 23 Aug 2003 05:45:01
Message: <web.3f4736efa23a4606cc6f45bb0@news.povray.org>
Brendan Ryan wrote:
>> Hex_Blur1 = 7
>> Hex_Blur2 = 19
>> Hex_Blur3 = 37
>Brendan
Um, a quadratic fit with only three points will ALWAYS fit those three
points exactly.  When your fit model has the same number of points as your
data set, the model will always fit exactly and yet will be basically
meaningless.  Or to be more blunt, the parabola found here is no more
meaningful than the line you'd get from fitting a set of two points.  It
might be the best you can do, given the limited data set, but there's no
reason to believe it reflects the underlying structure.
Date: 23 Aug 2003 06:26:28
Message: <3f474154$1@news.povray.org>
I was about to say that. I think I'll figure it out myself. I'll let you
guys know when I'm done.
Date: 23 Aug 2003 10:35:58
Message: <3f477bce@news.povray.org>
Oh sorry about that, I wasn't thinking. :(  It takes 2 points to define
a line and 3 for a parabola, how could I have forgetten. :(
Brendan
Date: 23 Aug 2003 14:38:14
Message: <3f47b496@news.povray.org>
Brendan Ryan wrote:
>> Hex_Blur1 = 7
>> Hex_Blur2 = 19
>> Hex_Blur3 = 37
>> etc 3. When using focal blur, does blur_samples 8 look worse
>> blur_samples 7?
> points (1,7), (2,19) and (3,37) fit on the curve y = 3x^2 + 3x + 1
> where x would be the x in Hex_Blurx and y would be the constants.
> would be 91 and Hex_Blur6 would be 127.
Thinking about what hexgrid might mean points in the direction that this
equation is correct. (Monospace font needed to correctly view the ASCII
art below.)
* * *  X=1, Y=7
* * * * *  X=2, Y=19
* * * * * * *  X=3, Y=37
Try making bigger ones, and you'll see that they fit the equation
perfectly...
Rune
rune|vision:  http://runevision.com **updated Jul 25**
POV-Ray Ring: http://webring.povray.co.uk
Date: 24 Aug 2003 11:00:43
Message: <3f48d31b@news.povray.org>
And now for the usage of those values..... what's the use of those values?
Date: 27 Aug 2003 04:11:37
Message: <uvookv4pkhnnaq2mbo0lc5gjj5opvtn2ge@4ax.com>
On Sun, 24 Aug 2003 17:00:39 +0200, "Apache"
I think there is a special provision in the source code for these
numbers, meaning that if you use a hexagonal number of blur_samples,
they will not be distributed randomly but rather in a regular
hexagonal pattern.
Peter Popov ICQ : 15002700
