POV-Ray : Newsgroups : povray.general : Writing binary files with POV script Server Time
23 May 2026 01:14:06 EDT (-0400)
  Writing binary files with POV script (Message 1 to 10 of 17)
Subject: Writing binary files with POV script
Date: 22 Aug 2003 04:35:18
Message: <3f45d5c6$1@news.povray.org>
I would like to generate a df3 file directly from a pov script,
generating it from pigments, a bit like Gilles' makecloud macro. But I
had a look at the documentation, and it seems that you can only output
text to a file.
So I was wondering if there was a trick to do it, and if not, if it's
going to be implemented in some next POVray version.
JC
PS: I know I can generate images with povray and make a df3 file with
some utility, but I already have too much utilities installed and I'd
like to do it in one step.
Subject: Re: Writing binary files with POV script
Date: 22 Aug 2003 04:50:11
Message: <n1mbkv84lo46jhm5o66kjpdlso1ridpfov@4ax.com>
On Fri, 22 Aug 2003 10:35:17 +0200, "JC (Exether)" <no### [at] spamfr> wrote:
> text to a file.
It was discussed a few times. It is not possible to make binary files.
> JC
See text format called extended density_file format at
http://staff.aist.go.jp/r-suzuki/e/povray/iso/df_body.htm
ABX
Date: 22 Aug 2003 04:51:39
Message: <3F45D99B.9A2BD0BB@gmx.de>
> text to a file.
This patch can read text density files.
Last updated 17 Jun. 2003 _____./\/^>_*_<^\/\.______
Date: 22 Aug 2003 07:27:47
Message: <3f45fe33@news.povray.org>
  The reason for this is that due to how POV-Ray (well, actually C)
internally works, you can't write the byte value 0 to a file (any other
value is writable).
  In order to be able to write any byte values (including 0) to a file,
a specialized function would have to be added. Perhaps someone could make
a patch...
  (The reason why 0 is not writable is because in C's string-handling
functions it marks the end of the string. The writing C function will
stop at that point and will not write the 0 nor anything which comes
after it. In order to write raw binary data, a different C function
needs to be used (which is not a string function). There's no feature
in the POV-Ray scripting language which would use such function and
thus this is not possible currently.)
Date: 22 Aug 2003 07:28:56
Message: <3f45fe78@news.povray.org>
By the way, in theory it could be possible to write a DF3 file from
POV-Ray as long as it doesn't contain any 0 byte... :)
Date: 22 Aug 2003 13:35:17
Message: <3F46544F.A3AF6F80@hotmail.com>
> text to a file.
> JC
I suppose that you could use chr() to write the bytes to the file.
John
Date: 22 Aug 2003 14:11:57
Message: <3f465ced$1@news.povray.org>
How about this:
Use the existing file output functions to write
a hex-ASCII version of your file, and then, in
a POV INI file, use the Post_Scene_Command or
Post_Frame_Command directive to execute a
converter app to turn the text into binary form.
Ray Gardener
Daylon Graphics Ltd.
"Heightfield modeling perfected"
http://www.daylongraphics.com
"JC (Exether)" <no### [at] spamfr> wrote in message
news:3f45d5c6$1@news.povray.org...
> text to a file.
> JC
Date: 23 Aug 2003 07:53:31
Message: <Xns93E04FFEDA04CPOVMIKA@204.213.191.226>
"Ray Gardener" <ray### [at] daylongraphicscom> wrote in
news:3f465ced$1@news.povray.org:
> How about this:
> Ray Gardener
>> text to a file.
>> JC
Being from the Unix arena, there is always a way even when it seems
impossible. Bright idea Ray!
(MIKA) Marc Champagne
marcch.AT.videotron.DOT.ca
Montreal, CANADA
Date: 24 Aug 2003 19:20:41
Message: <3f493f8c.4383761@localhost>
>text to a file.
For years I've been wishing that binary file read/write commands
would be added to povray (I once has a pov-script that was
rendering audio data to a text file.  I ended up writing it as
something like a uuencoded file and then having a separate
program to in turn convert that text file to the wave file).
However, it might is best that vinary I/O not be added.
Consider the ability to have a pov-script that in turn writes
a (binary) .exe file containing a virus?  Or what is to stop
povray from overwriting the system password file, or
command.com?
Date: 24 Aug 2003 19:53:19
Message: <3f494fef$1@news.povray.org>
> command.com?
The very same thing that prevents the text I/O feature of POV
from overwriting command.com with a text file: the inherent
pure-hearted goodness of the POV community. ;)
