POV-Ray : Newsgroups : povray.general : Subsurface Scattering Server Time
18 Sep 2025 11:14:07 EDT (-0400)
  Subsurface Scattering (Message 1 to 10 of 23)
Subject: Subsurface Scattering
Date: 11 Jul 2003 20:10:08
Message: <3f0f51e0$1@news.povray.org>
Does anyone know if this amazing lighting effect is being developed for
povray in any way?
Subject: Re: Subsurface Scattering
Date: 12 Jul 2003 04:12:47
Message: <3f0fc2ff@news.povray.org>
3f0f51e0$1@news.povray.org...
for
> povray in any way?
Filling an object with very dense scattering media makes a good subsurface
scattering effect. The texture of the object must be part transparent so
that both the surface pigment and the media inside are visible.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 12 Jul 2003 04:31:21
Message: <hghvgv4edfl827m73890gfmg66ukc73imo@4ax.com>
On Sat, 12 Jul 2003 10:12:41 +0200, "Gilles Tran" <git### [at] wanadoofr>
In addition to that, if your object seems fuzzy at the edges (might
happen no matter how dense the media inside it is), or if the shadow
is too soft and gives away the media inside, put an opaque
interior_texture to your object - best use the same as the exterior
texture sans the filter/transmit. For more detail and some examples,
see http://news.povray.org/povray.binaries.images/28847/ (shameless
plug :) )
Peter Popov ICQ : 15002700
Date: 12 Jul 2003 10:27:07
Message: <3f101abb@news.povray.org>
Thanks, I will try that.
> Personal e-mail : pet### [at] vipbg
> TAG      e-mail : pet### [at] tagpovrayorg
Date: 14 Jul 2003 02:06:58
Message: <3f124882$1@news.povray.org>
for
> povray in any way?
Am I the only one who never could tell the difference between something with
subsurface scattering and something without it?
I can see the difference when dense media is used within an object, but is
this really the same exact effect? And why would human skin have it? *My*
skin certainly isn't very transparent.
 - Slime
[ http://www.slimeland.com/ ]
Date: 14 Jul 2003 10:21:02
Message: <3f12bc4e$1@news.povray.org>
Okay, this is a very good question.  Many people don't spot it right off, so
here is a simple test you can do that will show you how it looks and what it
does.
    Do you own a red laser pointer?  Using a dark card, go in a darkened room
and place the card against your skin, edgewise.  Now, shine the laser pointer on
the skin on the other side of the card- not the part of the skin you are looking
at.
    When you see the red, diffuse glow under the card, you are seeing subsurface
scattering.  But you probably knew that.  In looking at the surface of, say, a
mannequin, you will see that the shadows are very hard and there is no
subsurface scattering.  With real flesh, there is considerable softening of the
shadows and a really significant amount of light diffusion beneath the surface.
    Skin is actually transparent to a number of frequencies, but in visible
light, it tends to be right in the red end of the spectrum.  If you model skin
with an internal red scattering, or a red diffuse medium, it looks far more
natural when light falls on it.  Instead of that blocky, plastic look, it has
the depth and softness that we expect.
    Seeing some of your renders in this group, I know that you are aware of how
the little details make or break an image.  This is one of those things that
really makes people look realistic.
    Oh, I tend to use a pale orange sort of color when playing with skin
subsurface scattering.  Use white light for the experiment above and you will
see that this is the dominant color that appears to the human eye.
Cheers!
Chip Shults
Date: 15 Jul 2003 15:00:39
Message: <3f144f57@news.povray.org>
"Gilles Tran" <git### [at] wanadoofr> wrote in message
news:3f0fc2ff@news.povray.org...
Do you have any sample-code of this? I'm struggling for this at the moment,
and rather working in the dark.
Date: 15 Jul 2003 15:56:08
Message: <3f145c58@news.povray.org>
3f144f57@news.povray.org...
moment,
Try the code below. Left sphere is with subsurface scattering.
Note that it shows one problem I had with the ISS image when I used this on
the kid's arm, which is that the dark (densest) parts tend to be quite black
and do not react to radiosity. The only solution I found is by using
emission, which caused other problems and then I ran out of testing time.
It's also a problem with clouds, but it can be camouflaged by fog... I guess
that until we get real blurred transluscency there's no permanent
solution... unless I missed something obvious that is.
global_settings{
    assumed_gamma 1
    radiosity{media on}
  location  <0,1,-4>
  direction z
  look_at   y
sphere{0,1
    texture{
        pigment{rgbf <1,0.6,0.2,1>}
        finish{ambient 0 diffuse 1 specular 0.2 roughness 1/200 }
    hollow
    interior{
        media{
            scattering {1 rgb 4}
    translate y
    translate -x*1.1
sphere{0,1
    texture{
        pigment{rgb <1,0.6,0.2>}
        finish{ambient 0 diffuse 1 specular 0.2 roughness 1/200}
    translate y
    translate x*1.1
plane{y,0 texture{pigment{rgb 1} finish{ambient 0 diffuse 1}}}
light_source {0  color rgb 1 translate <-1,1,1>*1000}
- Posters
Date: 15 Jul 2003 16:42:39
Message: <3f14673f@news.povray.org>
news:3f145c58@news.povray.org...
Many thanks. Excellent service. This newsgroup looks ripe for privatisation.
Date: 15 Jul 2003 18:40:16
Message: <3f1482d0$1@news.povray.org>
3f14673f@news.povray.org...
privatisation.
True enough, I can't wait to have our first POV-Ray accidents once the
development is subcontracted to the lowest bidders/highest bribers using
temporary and expandable workers with prior expertise in fruit picking  ;)
G.
- Posters
