POV-Ray : Newsgroups : povray.general : Adding two images via functions...? Server Time
31 Mar 2026 16:38:39 EDT (-0400)
  Adding two images via functions...? (Message 1 to 7 of 7)
Subject: Adding two images via functions...?
Date: 16 Jun 2003 19:36:40
Message: <3eee5488@news.povray.org>
What I'm trying to do is following:
I've got two images, one in grayscale,
the other just some image. I want to
add the grayscale to the other image, so
that white areas of the grayscale are white
in the combination, and black won't change
the colored image.
There has got to be some way to do this
and to use that function as a pattern (along
with colors and all), so that I may map the
resulting function using uv-mapping onto
two triangles which cover exactly the camera's
field of view.
Thus I want to create a method of combining
specularity-image (made by my latest macros)
with an image (which has no specularity components),
and still do it all in POV.
Any hints, code-snippets, links?
Tim Nikias v2.0
Email: Tim### [at] gmxde
Subject: Re: Adding two images via functions...?
Date: 17 Jun 2003 03:50:47
Message: <3EEEC8AA.60709@informatik.uni-freiburg.de>
> the colored image.
Let eps be small enough. I usually use
   #declare eps = 1e4;
Apply the gray picture as a texture to a plane and add:
   pigment_map {
     [0 rgbt <0,0,0,1-eps>]
     [1 rgbt <1,1,1,1-eps>]
   finish {ambient 1/eps}
There should be a way to do that without the pigment_map,
but I am unsure enough about above syntax. Hope the idea
made it through, though...
merge{#local i=-11;#while(i<11)#local
i=i+.1;sphere{<i*(i*i*(.05-i*i*(4e-7*i*i+3e-4))-3)10*sin(i)30>.5}#end
pigment{rgbt 1}interior{media{emission x}}hollow}//  Mark Weyer
Date: 17 Jun 2003 06:08:44
Message: <3eeee8ac$1@news.povray.org>
I'm doing it like this now:
 #local _I=function{pigment{_ImagePigment}}
 #local _Image=texture{
  pigment{function{_I(x,y,z).x}
   color_map{[0 rgbt <1,1,1,1>][1 rgbt <1,1,1,0>]}
   poly_wave _Exponent
  finish{ambient _Brightness diffuse 0}
And it works fine. Thanks for the suggestion though,
even though that one didn't work, it got me to the right
place.
Tim
Tim Nikias v2.0
"Mark Weyer" <wey### [at] informatikuni-freiburgde> schrieb im Newsbeitrag
news:3EE### [at] informatikuni-freiburgde...
> > the colored image.
>    #declare eps = 1e4;
>    pigment_map {
Date: 17 Jun 2003 07:17:03
Message: <3eeef8af$1@news.povray.org>
I'm trying to combine all three color componentes
now. So that I might take any image, and black=transparent,
white=non-transparent, and every color in between will
get transparency based on total brightness... Sort of like
a color overlay. Anyone know how to do that?
Tim Nikias v2.0
>    poly_wave _Exponent
> place.
> Regards,
> Tim
> Tim Nikias v2.0
> Homepage: http://www.digitaltwilight.de/no_lights
> > > the colored image.
> >    #declare eps = 1e4;
> >    pigment_map {
Date: 17 Jun 2003 16:46:16
Message: <3EEF7E13.F4C7D223@hotmail.com>
> the colored image.
> field of view.
// the grayscale
#local pigM=pigment { image_map { png "mymask.png" } }
// the overlaid picture
#local pigP=pigment { image_map { png "mypic.png" } }
// this combines them
pigment { pigment_pattern { pigM }
  pigment_map {
    [0 pigP]
    [1 pigM]
Hope this helps,
John
Date: 17 Jun 2003 16:55:20
Message: <3eef8038$1@news.povray.org>
Thanks! Got to try it first, but it looks like what
I want.
Personally, I'm not too sure about others, but I
find the documentation doesn't cover functions
well enough as it does all the other sections. Perhaps
someone could work on this? I'm obviously not
the guy for that though... :-)
Tim Nikias v2.0
> > the colored image.
> > field of view.
> // the grayscale
>   pigment_map {
>     [0 pigP]
>     [1 pigM]
> Hope this helps,
> John
Date: 18 Jun 2003 03:26:36
Message: <3EF01480.9090402@informatik.uni-freiburg.de>
>   pigment_map {
>     [0 pigP]
>     [1 pigM]
I thought it should be addition? So, if pigP and pigM are both at 1/2,
I would have expected an outcome of 1. This gives an outcome of 3/4.
