POV-Ray : Newsgroups : povray.general : "Semiorthographic" camera? Server Time
16 Jan 2026 17:30:29 EST (-0500)
  "Semiorthographic" camera? (Message 1 to 8 of 8)
Subject: "Semiorthographic" camera?
Date: 15 Jun 2003 08:33:20
Message: <3eec6790@news.povray.org>
Hi!
The following scene doesn't look very nice, because the spheres are
distorted:
camera
 location z * -3
 up y * 0.5
 right x * 4
light_source { z * -10, rgb 1 }
#declare I = -5;
#while(I <= 5)
 sphere { x * I, 0.3 pigment { color rgb 1 } }
 #declare I = I + 1;
(Render with "+W800 +H100"!)
I'd like to have a "semiorthographic" camera, i.e. one that is horizontally
orthographic but vertically perspective. This is similar to cylindrical
projection, type 4 ("horizontal cylinder, viewpoint moves along the
cylinder's axis") except that is shouldn't be projected onto a cylinder but
onto a plane.
Does anyone have an idea how to achieve this?
Thank you in advance,
Felix Wiemann
Subject: Re: "Semiorthographic" camera?
Date: 15 Jun 2003 09:20:34
Message: <3eec72a2@news.povray.org>
  Try the ultra_wide_angle or panoramic cameras to see if they do what
you want. (I think you need to specify an angle in them for them to
work correctly.)
Date: 15 Jun 2003 09:41:40
Message: <3eec7794@news.povray.org>
>> horizontally orthographic but vertically perspective.
> work correctly.)
That curves objects with straight edges (e.g. boxes), so it isn't really
suitable.
light_source{0#macro L(K,H,W)sphere{H.5}sphere{K.5}sphere{W.5}cylinder{
H,K.5}cylinder{H,W.5}#end 3}union{L(0v*-2<2,-2>)L(y*-3z-v*5z*3-y)L(-y*3
0u*3)L(y*-3v*-5-z,z*-3-y)rotate-v*clock pigment{rgb.5}translate<0,2,9>}
// +KFF200 +KF720 +W120 +H90 -F -A -GA -P
Date: 16 Jun 2003 04:13:31
Message: <3EED7C7D.30609@informatik.uni-freiburg.de>
> onto a plane.
Somebody, I think it was ABX, wrote a patch for user-defined cameras.
merge{#local i=-11;#while(i<11)#local
i=i+.1;sphere{<i*(i*i*(.05-i*i*(4e-7*i*i+3e-4))-3)10*sin(i)30>.5}#end
pigment{rgbt 1}interior{media{emission x}}hollow}//  Mark Weyer
Date: 16 Jun 2003 08:40:41
Message: <3eedbac8@news.povray.org>
Mark Weyer wrote:
>> horizontally orthographic but vertically perspective. This is similar to
>> cylindrical projection, type 4 ("horizontal cylinder, viewpoint moves
>> along the cylinder's axis") except that is shouldn't be projected onto a
>> cylinder but onto a plane.
Sorry, I can't find it. Do you have an idea what words to search for or
where to search it?
Date: 16 Jun 2003 10:34:09
Message: <3EEDD5B1.1090306@informatik.uni-freiburg.de>
> where to search it?
See thread
   user_defined camera sample
by ABX from Feb 18 2003 in povray.binary.images
Date: 18 Jun 2003 03:40:35
Message: <3EF017C7.5000604@informatik.uni-freiburg.de>
> onto a plane.
Another idea, without patches:
Start with a cylindrical type 4 camera.
Surround it with a cylinder of small radius (but not too small, rays
from the camera should be able to reach the cylinder).
Make the cylinder transparent, but give it an ior.
Then adjust the gradient such that the rays go off in the direction
you want them to.
This is not an exact solution, only an approximating one. The camera
rays _after_ refraction do not start exactly at the cylinder's axis.
But if the radius is small enough, the difference is also. Maybe you
can remedy exactness with a second cylinder.
Date: 3 Nov 2003 10:00:01
Message: <web.3fa66c94cb6f253f237877840@news.povray.org>
I think this is what you get "in the real world" using a line scan camera
moving horizontally with the scan line positioned vertically.
