POV-Ray : Newsgroups : povray.general : Proof: 2 x 8 bit textures and interpolation Server Time
11 Jan 2026 03:53:58 EST (-0500)
  Proof: 2 x 8 bit textures and interpolation (Message 1 to 3 of 3)
Subject: Proof: 2 x 8 bit textures and interpolation
Date: 4 May 2003 16:23:01
Message: <3eb576a4@news.povray.org>
[Talking about "16 bit image map pattern not working with isosurface"]
Christoph Hormann wrote:
>Note this is probably an extremely bad idea since it does not work with
>interpolation
I dare to object...
I think I have the mathematical proof that there is no problem
with interpolation even when using two separate 8 bit images instead
of one 16 bit set. You just have to use bilinear interpolation on
both of them:
Consider we have 16 bit topography data split into two 8 bit sets
with low and high byte of the values.
Look at two pixels a,b next to each other:
  a = a_lo/256 + a_hi
  b = b_lo/256 + b_hi
Normal linear interpolation would do just that:
  val = p * a + (1-p) * b
But using two separate textures, they get interpolated separately:
  val_lo = p * a_lo + (1-p) * b_lo
  val_hi = p * a_hi + (1-p) * b_hi
Then, these get composed to the real value as used in the isosurface:
  val = val_lo/256 + val_hi
      = [ p * a_lo + (1-p) * b_lo ]/256 + p * a_hi + (1-p) * b_hi
      = p * (a_lo/256 + a_hi) + (1-p) * (b_lo/256 + b_hi)
      = p * a + (1-p) * b
...and that's just what we want.   -- q.e.d.
Bilinear interpolation is just the same in two directions.
Incorrect? Any comments?
Cheers,
Wolfgang
Subject: Re: Proof: 2 x 8 bit textures and interpolation
Date: 4 May 2003 16:59:00
Message: <3EB57F13.D7457A20@gmx.de>
> >interpolation
> I dare to object...
> both of them:
If you read the citation in my reply you cite here:
> > I busted my head over this one too for a while. I ended up using TGA's of
> > the 16-bit-for-height_field flavor and extracting the MSB and LSB by
> > function{pigment_foo(x,y,z).red+pigment_foo(x,y,z).green/256}
> > which is probably where you are almost at anyway.
> interpolation and using not interpolated image maps will result in
> infinite gradients in the function.
you can see it refers to using a TGA like it is used for 16 bit
heightfields.  I really thought this was clear.  No need to make that much
fuzz about it because everyone who has ever tried this with interpolation
will immediately recognize it is a bad idea.
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Date: 4 May 2003 17:10:38
Message: <3eb581ce@news.povray.org>
Ah, I see.
I', very sorry for the misunderstanding.
Wolfgang
