POV-Ray : Newsgroups : povray.general : Heightfield Type problems. Server Time
24 Nov 2025 11:27:41 EST (-0500)
  Heightfield Type problems. (Message 1 to 9 of 9)
Subject: Heightfield Type problems.
Date: 17 Mar 2003 06:33:06
Message: <3e75b23b.246070110@news.povray.org>
1.	I created a ppm file in PovRay to use as a heightfield. When I used it
in a test scene I got this error.
 File: C:\Graphics\Moray For Windows Beta\PovScn\type02.pov  Line: 86
  height_field {
    ppm  "C:\data\images\type010.ppm" <----ERROR
Parse Error: Unsupported number of colors (0) in PPM image.
Returned from renderer with error status
It seems strange that there is a problem reading from a file that PovRay
generated itself.
2.	Another problem is with the pgm format. If the file (in ASCII) has a
comment character "#" I get this error.
Parse Error: Invalid width or height read from PPM image.
If I use ASCII format I can edit out the comment lines so it's no bid deal but
it would be nice not to.
Regards
Subject: Re: Heightfield Type problems.
Date: 17 Mar 2003 07:46:33
Message: <3E75C3A8.411EA06E@gmx.de>
Yes, there are a lot of things broken about ppm/pgm support in 3.5.  Until
now i found:
- comments are not allowed *before* the width and height values in either
pgm or ppm.
- ppm reading support strongly broken (problems with the 'depth' value)
- continued trace of ppm does not work
- 16 bit binary pgm not supported although allowed in pgm specs (this has
never been supported though)
Parts of it have already been reported in:
Subject: ppm bug
Date: 28 Dec 2002 10:16:11 -0500
Reply-To: ing### [at] tagpovrayorg
To: bug### [at] povrayorg
Newsgroups: povray.bugreports
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
Date: 17 Mar 2003 07:52:09
Message: <3e75c4f9@news.povray.org>
  A temporal work-around would be to simply convert the ppm file to
another format supported by POV-Ray (eg. png).
Date: 17 Mar 2003 08:06:07
Message: <3e75c83f$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3e75c4f9@news.povray.org...
Looks more like a temporary work-around to me. A temporal work-around would
presumably involve a time-machine and a copy of 3.52 ;)
Date: 17 Mar 2003 08:27:46
Message: <3e75cca0.252827416@news.povray.org>
On Mon, 17 Mar 2003 13:46:32 +0100, Christoph Hormann <chr### [at] gmxde>
>now i found:
>pgm or ppm.
>Subject: ppm bug
>From: ingo <ing### [at] tagpovrayorg>
>Christoph
Thanks for the reply, I should have checked before posting. As iit has been
reported NFAR
>POV-Ray tutorials, include files, Sim-POV,
>HCR-Edit and more: http://www.tu-bs.de/~y0013390/
Regards
Date: 17 Mar 2003 08:28:45
Message: <3e75cd56.253009328@news.povray.org>
Thanks for the "earthly or secular :-)" tip but I was just checking something
for the Moray Beta test when I came across this.
PS I liked your "Why is English so hard to learn" thread in Off topic
Regards
Date: 17 Mar 2003 08:43:09
Message: <3e75d0ed$1@news.povray.org>
In article <3e75c4f9@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
Given that it is generated with POV-Ray in the first place, generating it in
a reasonable compressed format like PNG directly makes more sense anyway.
    Thorsten
e-mail: tho### [at] trfde
Date: 17 Mar 2003 10:05:50
Message: <3e75e44e@news.povray.org>
  You are probably right. :P
Date: 25 Apr 2003 11:40:08
Message: <web.3ea955fcddef4d9036ddc6200@news.povray.org>
   Just in passing, it has been my experience that most programs do not
support all the features of the NetPBM suite. In particular, the 16-bit
option and the ASCII option. Many programs put restrictions and limits
on the header that do not exist. The original intent was to make the
format as flexible and easy to read as possible.
Thanks,
julian
