POV-Ray : Newsgroups : povray.general : Creating a ripple effect Server Time
18 Sep 2025 22:22:33 EDT (-0400)
  Creating a ripple effect (Message 1 to 8 of 8)
Subject: Creating a ripple effect
Date: 21 Feb 2003 02:42:59
Message: <3e55d883@news.povray.org>
How can I create ripple effect like when a helicopter is flying above a
water surface?  I could use the "ripples" pattern but I don't want the whole
water surface to become rippled.  I want the ripples to gradually fade away
from the center.  I also don't want the ripples to originate exactly from
the center because that is not realistic when a helicopter is flying
overhead.  The ripples should around the perimeter of the helicopter.
Subject: Re: Creating a ripple effect
Date: 21 Feb 2003 03:41:26
Message: <3e55e636$1@news.povray.org>
Check out this java applet and you can swipe some code from it.  Surely this
can be adapted to a surface normal routine!
http://www.visionariamedia.org/java/java.htm
Cheers!
Chip Shults
Date: 21 Feb 2003 04:57:56
Message: <3E55FB1A.4000802@informatik.uni-freiburg.de>
There are two approaches I know of: Normals and isosurfaces.
I am usually not satisfied with normals.
My approach would be to make the water an isosurface. The isosurface
function would be a sum of elementary ripples. One elementary ripple
has the form
   sin(sqrt(pow(x-center_x,2)+pow(y-center_y,2))*2*pi/wavelength+phase)*amplitude
or, if the ripples should be parallel (e.g. those that are there even
if the helicopter is not),
   sin((x*dx+y*dy)*2*pi/wavelength+phase)*amplitude
where (dx,dy) is the direction of the wave movement.
The whole isosurface function would be
   ripple_1(x,y)+...+ripple_n(x,y)+z
I assume here that z is up.
If this is for an animation, choose
   phase=phase_0-clock*speed*2*pi/wavelength
The speed of all elementary waves should be equal.
If you want to turn that into a normal pattern (for render speed that
would be), the normal is the gradient of the isosurface function, i.e.
   cos(sqrt(pow(x-center_x,2)+pow(y-center_y,2))*2*pi/wavelength+phase) *
   vnormalize(x-center_x,y-center_y,0)*2*pi/wavelength * amplitude
   cos((x*dx+y*dy)*2*pi/wavelength+phase) * (dx,dy,0) * amplitude
   normal_1(x,y)+...normal_n(x,y)+(0,0,1)
merge{#local i=-11;#while(i<11)#local
i=i+.1;sphere{<i*(i*i*(.05-i*i*(4e-7*i*i+3e-4))-3)10*sin(i)30>.5}#end
pigment{rgbt 1}interior{media{emission x}}hollow}//  Mark Weyer
Date: 21 Feb 2003 05:15:17
Message: <6rub5v0r4c8664lj13e41cpvsk033ohjgj@4ax.com>
On Fri, 21 Feb 2003 11:10:34 +0100, Mark Weyer
http://www-public.tu-bs.de:8080/~y0013390/pov/water/
ABX
Date: 21 Feb 2003 06:27:53
Message: <3e560d39@news.povray.org>
"DL" <dav### [at] hotmailcom> wrote in message
news:3e55d883@news.povray.org...
whole
away
Okay. This is what I'd do...
global_settings {
    number_of_waves 5
#declare S=0.09; // ripples scaling
#declare N0=normal {ripples 0}
#declare N1=normal {ripples 0.9
    phase -clock*3 // spread outward when animated
  turbulence 0.3 scale S}
#declare N2=normal {ripples 0.3
  turbulence 0.9 scale S/1.5}
plane {y,0
 pigment {rgb 1}
normal {
    spherical
        normal_map {
[0 N0] // this is the outermost edge
[1/6 N2] // less wavy water
[1/2 N1] // more wavy water
[2/3 N2] // less wavy water
[1 N0] // this is the center
scale 2 // adjust overall size here
 finish {specular .5}
You could also make a pigment to match this by following the same principal,
if you needed frothing water for example.
Maybe I'm giving too simple an answer but then that's about all I'm good
for.
Farewell,
Date: 21 Feb 2003 06:33:02
Message: <3E561163.6050309@informatik.uni-freiburg.de>
> has the form
This formula for central ripples did not take perishing into account.
Here is a corrected version:
   sin(r*2*pi/wavelength+phase)*amplitude/r
where r is the distance from the center and the amplitude is at r=1.
Ideally we would have
   r=sqrt(pow(x-center_x,2)+pow(y-center_y,2))
However this would be unrealistic for small r (It would be like
causing a wave by pushing water up with a needle 1km long and
1mm thick.). Hence a correction:
   r=sqrt(pow(x-center_x,2)+pow(y-center_y,2)+pow(r_0,2))
For the gradient this turns to:
   cos(r*2*pi/wavelength+phase)*amplitude/r*2*pi/wavelength*dr -
   sin(r*2*pi/wavelength+phase)*amplitude/pow(r,2)*dr
where
   dr=<x-center_x,y-center_y,0>/r
As ABX has pointed out, there are more elaborate solutions
for this in Christoph Hormann's tutorial. However, the gradient
I gave you for this case was wrong. It should be
   cos((x*dx+y*dy)*2*pi/wavelength+phase)*amplitude*2*pi/wavelength*<dx,dy,0>
Hope I got it right this time ;-)
Date: 26 Feb 2003 01:21:53
Message: <3e5c5d01$1@news.povray.org>
What is r_0?
Date: 3 Mar 2003 05:58:20
Message: <3E633857.2080805@informatik.uni-freiburg.de>
> What is r_0?
1. Technically we have a 3D-wave that is centered at
    (center_x, center_y, r_0). Of this wave we take only
    the slice with z=0.
2. Before the correction, amplitude has been the height (or half
    of the height) of the wave. Now the height varies, being
    maximal at (center_x, center_y). Its value there is
    amplitude/r_0.
    On the other hand r_0 determines how fast the wave diminishes.
    Let us say you want to specify the height of the wave (at the
    center) and the distance from the center at which the height
    is halfed. Then choose
    r_0 = distance/sqrt(3)
    amplitude = height*r_0
Hope i got it right
