POV-Ray : Newsgroups : povray.general : Converting function syntax to 3.5 Server Time
28 Dec 2025 12:44:26 EST (-0500)
  Converting function syntax to 3.5 (Message 1 to 3 of 3)
Subject: Converting function syntax to 3.5
Date: 30 Jan 2003 19:14:39
Message: <3e39bfef@news.povray.org>
So I've got this scene written for MegaPOV 0.7 with the following code
in it:
#declare worldnet5 = function
   pigment
     marble
     color_map
       [ 0.0 color rgb 0 ]
       [ 1.0 color rgb 1 ]
     rotate <0, 0, 90>
#declare worldnet7 = function { pigment { radial frequency 48 turbulence
4 } }
#declare worldnet9 = function { (min(worldnet7+.9, worldnet5) *
(worldnet7 * worldnet5)^3) * 100 }
...and I was trying to make it work in POV-Ray 3.5. Well, changing the
power operator to pow() was a no brainer, but it kept giving me parsing
errors for worldnet9, no matter how I tried to fix it. Finally I gave up
and looked through the documentation to see exactly what was going
wrong. The documentation is far from easy reading, but the impression
that I got was that what I'm trying to do may not be possible at all.
As far as I'm concerned, whoever changed functions for 3.5 butchered a
perfectly good syntax.. but that's not the point, the point is, *is* it
possible to write this function in 3.5, and if so, how should it look?
-Xplo
Subject: Re: Converting function syntax to 3.5
Date: 30 Jan 2003 23:44:05
Message: <FUtWaKAF7fO+Ewgl@econym.demon.co.uk>
>in it:
>   pigment
>     marble
>     color_map
>       [ 0.0 color rgb 0 ]
>       [ 1.0 color rgb 1 ]
>     rotate <0, 0, 90>
>4 } }
>-Xplo
The syntax is
#declare worldnet9 = function { (min(worldnet7(x,y,z).grey+.9,
worldnet5(x,y,z).grey) * pow((worldnet7(x,y,z).grey *
worldnet5(x,y,z).grey),3)) * 100 }
I know the syntax is slightly more complicated, but that's the price you
have to pay for the considerably increased functionality.
Mike Williams
Gentleman of Leisure
Date: 31 Jan 2003 08:37:55
Message: <3E3A7A8D.8010705@nodomain.com>
> in it:
>   pigment
>     marble
>     color_map
>       [ 0.0 color rgb 0 ]
>       [ 1.0 color rgb 1 ]
>     rotate <0, 0, 90>
> 4 } }
Hello Xplo,
If you have a look at http://www.econym.demon.co.uk/isotut/index.htm you
will find good tutorials that explains the syntax for povray 3.5
All the best
Fidel.
