POV-Ray : Newsgroups : povray.general : Maximum possible extents for POV-Ray scene coordinates? Server Time
23 May 2026 14:57:28 EDT (-0400)
  Maximum possible extents for POV-Ray scene coordinates? (Message 1 to 7 of 7)
Subject: Maximum possible extents for POV-Ray scene coordinates?
Date: 8 Jan 2003 14:35:58
Message: <3e1c7d9e$1@news.povray.org>
Hey all,
    What are the minimum and maximum possible values that any coordinate in
scene space could ever have?
Thanks,
George P
Subject: Re: Maximum possible extents for POV-Ray scene coordinates?
Date: 8 Jan 2003 15:24:50
Message: <3e1c8912@news.povray.org>
In article <3e1c7d9e$1@news.povray.org> , "George Pantazopoulos"
Anything POV-Ray will read as float will be accepted, which means the limits
of an IEEE 754 64 bit floating-point number also apply to POV-Ray on all
supported platform.  But assume practical limits to be at 1.000.000 and 1 /
1.000.000 .
    Thorsten
e-mail: tho### [at] trfde
Date: 8 Jan 2003 15:36:34
Message: <3e1c8bd2@news.povray.org>
> 1.000.000 .
  On the other hand, AFAIK there are some internal limits in POV-Ray.
For example I think that if an object is farther away from the starting
point of a ray than a certain distance, it's not taken into consideration
(a limitation which some people have found and not liked too much, even
though this distance is rather large).
Date: 8 Jan 2003 16:03:06
Message: <3e1c920a@news.povray.org>
In article <3e1c8bd2@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
Hence I mentioned the practical limits.  Nevertheless, i.e. during
transformations there is no problem with any number that fits the IEEE
limits.
Because it prevents them from modeling a start system using one km units ;-)
    Thorsten
Date: 8 Jan 2003 16:34:54
Message: <3e1c997e@news.povray.org>
And if one were ONLY modeling a star system, this wouldn't be a problem.
The problem is when you're trying to model something that has some very
large-scale features as well as small ones (such as any scene on a
realistic Earth); even geologic distances are huge compared to a
building, let alone the petals on a flower.
There are compromises that can be made, of course.. but even so, the
limitation is always hiding there, like a snake in the grass.
-Xplo
Date: 10 Jan 2003 12:41:01
Message: <3e1f05ad$1@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3e1c8912@news.povray.org...
//--run this code:--//
union{
        #declare toothblob=blob{threshold 0.7 cylinder{0,y,1,1 }pigment{rgb
1} finish{ambient 1}}
        object{toothblob scale 1e6 translate <-1e6,1,1.03e7> }
        object{toothblob scale 1e6 translate < 1e6,1,1.04e7> }
Date: 10 Jan 2003 14:04:58
Message: <3e1f195a$1@news.povray.org>
In article <3e1f05ad$1@news.povray.org> , "Greg M. Johnson"
Why would I?
    Thorsten
