POV-Ray : Newsgroups : povray.general : lining up an object with a vector Server Time
4 Mar 2026 03:28:19 EST (-0500)
  lining up an object with a vector (Message 1 to 3 of 3)
Subject: lining up an object with a vector
Date: 3 Oct 2002 04:45:58
Message: <3d9c03c6@news.povray.org>
Hi all.
How can I rotate an object so that it's up-coordination <0,1,0> lines up with a
given vector?
JM
#macro J(M)V()<V(),V(),V()>#if(M)J(M)#end#end#local _=20;#macro V()asc(substr
("IIMYKIIYMMKQOIMYQEEYSCEYUEGQWEHYYIGQ[HEY]IGY_JGQaJEYcKGYeKGQgLEYiMKIs#K ",
73-M,1))/2-36.5#declare M=M-1;#end#local a=spline{cubic_spline J(72)}#while
(_)sphere{a(_).1pigment{rgb(a(_)+(x+y)*3.5)}}#local _=_-.02;#end//JM
Download 'Jan Maarten van der Valk.vcf.txt' (1 KB)
Subject: Re: lining up an object with a vector
Date: 3 Oct 2002 05:11:31
Message: <3d9c09c3$1@news.povray.org>
"Jan Maarten van der Valk" <jm.### [at] hccnetnl> schreef in bericht
news:3d9c03c6@news.povray.org...
a
> given vector?
Found the answer myself after reading the 'Constrained motion' thread in p.a-u.
The Axis_rotate_Trans macro does the trick.
    Axis_Rotate_Trans(VPerp_To_Plane(y,Norm), VAngleD(y,Norm))
where Norm is the vector the object should be aligned with.
Cheers,
JM
Date: 3 Oct 2002 10:09:15
Message: <chrishuff-20E450.10061103102002@netplex.aussie.org>
In article <3d9c09c3$1@news.povray.org>,
> p.a-u.
That is a very odd way to do it, since if you know about
Axis_Rotate_Trans() you should know about the other macros in that
file..."Point_At_Trans(Norm)" should do the job fine.
http://tag.povray.org/
